Universal Ground problem?
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2490
Printed Date: 25 April 2025 at 1:40pm
Topic: Universal Ground problem?
Subject: Universal Ground problem?
Date Posted: 01 June 2011 at 12:57pm
Well, more amazing tales of how Gretchin just loves to screw up her electrical system... Needing help...
Was on my way home from Canadian Tire today (Was going to pick up tires, but they're too large to fit in my car). Was sitting at a light, and when it green, I let the clutch out and the vehicle died immediately. I don't mean stalled, all the lights were out and everything. Eventually, the lights came back on, but then I couldn't get the engine to fire for a few minutes straight (Would crank, but not quickly enough to turn over). After that, it cranked no problem and fired right up as if nothing were wrong.
I got about twenty feet before the windshield wipers starting going on as fast as they could possibly go and my speedo jumped to 140 KM/H. Now, I'm operating under the assumption these two circuits don't share the same power source (Fuse), but probably ground through the same circuit. Is it possible to have possibly shorted them to power backwards from ground side? That wouldn't have fried the fuses (As most of the current would be wasted in the actual objects) and seems to be the only thing they share in common. It should be noted, other stuff may have been going wrong, but I didn't happen to notice, I was too focused on those two things. It should also be noted, however, that the windshield wipers have a switch in the to interrupt power flow, which was seemingly bypassed by the short.
Any suggestions would be greatly appreciated.
Date Posted: 01 June 2011 at 1:27pm
Man oh man, any excuse not to be embarrassed by a duke (or two) on Sunday!
I wonder if this is related to all the problems you were having a few months ago with your battery and/or charging system?
Date Posted: 01 June 2011 at 3:07pm
I've been wondering that myself. At the moment, it is sort've working, which is actually making it harder to diagnose. Would be nicer if it broke and stayed broken.
But yes, given my horrid history with charging systems, it would seem logical that the two are related. Perhaps a short keeps making the alternators working too hard, which cooks them?
Posted By: orange
Date Posted: 02 June 2011 at 6:23pm
I dont know what your previous problem was particularly but it does sound
like grounding issues. One very important ground to check is the one directly
above the back passenger side wheel, in the wheel well (behind the plastic). I
had this go out due to rust and when i had the heater, blower, head lights,
radio, amp, and a turn signal on, i could turn the key to the off position and
it would still run, i could even take the key out. And it was twitchy like your
sounds. May or may not be even close, i dunno.
Orange 4.9
Date Posted: 02 June 2011 at 6:51pm
That sounds perfectly like my own fault, as it fixed itself after I played around in that area.
Date Posted: 02 June 2011 at 7:35pm
I use a load meter to test all the time,if you know somone that has one its easy to use,an you can nail down whats wrong real fast,with out takeing everything apart.
Date Posted: 02 June 2011 at 10:26pm
OK Tristan, the first part of your message is definitely a bad connection to your battery.
Think about it, the only common denominator to all those things is your main battery cables or possibly one of the main power lines from the engine compartment to the fuse box.
I have run into this a few times in my life and it was always these cheap crimped battery cables we see everywhere these days.  They look good on the outside maybe but inside the crimp there is resistance.
Here's a trick:
Turn your headlights on and maybe even the rear defogger.  Then take a digital volt meter and measure across any of the high current connections.  So stick the pointy end of the meter leads right through the plastic wire covering as close to the connection as possible.  If you read any more than a few milivolts, you've got a problem.  If any of the connections is even a little warm, you've got a problem.
I would do the above and even if I found nothing, I would remove, clean and reconnect all the high current connections.
