Manifold Required - Thoughts?
Category: Buy / Sell
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2534
Printed Date: 07 August 2025 at 3:12am
Topic: Manifold Required - Thoughts?
Subject: Manifold Required - Thoughts?
Date Posted: 24 June 2011 at 10:08am
Hi...
If anyone happens to have a set of manifiolds please let me know...or suggestions?
FS Sprint @ $600USD: http://www.fierostore.com/Product/Detail.aspx?s=95727&d=391&p=1 - http://www.fierostore.com/Product/Detail.aspx?s=95727&d= 391&p=1
or
Westcoast Fiero...NOT CHEAP: http://www.westcoastfiero.com/headers/headers_entry.html - http://www.westcoastfiero.com/headers/headers_entry.html
or
The Truleo, not sure they are in business anymore...: http://trueleo.com/fieroexhaust.htm - http://trueleo.com/fieroexhaust.htm
End of day, I am liking the heat treatment on the Sprint and price, already have the gaskets, just need bolts and install...I am probably missing so much in performance one the car, but the hard starts I need help with one day also...always something...lol
85-88 V6 SPRINT MANIFOLD SET WITH HEAT COATING
Sprint manifolds are sand mandrel bent from heavy gauge steel with flame cut flanges. The manifolds fit exactly to your cylinder head ports while the improved header design and enlarged pipes give smooth power and torque gains throughout the RPM band. Both manifolds are heat coated inside and out, allowing the removal of your factory heat shields. This high tech coating reduces underhood temperatures, enhances flow and increases life and durability. Does not include mounting hardware.
Due to CA CARB emission laws, these manifolds are not legal for sale or use in California.
Part # 95727 Price:$599.95
Date Posted: 24 June 2011 at 11:30am
Well, there's also the option of buying a http://www.jegs.com/p/Hooker-Headers/Hooker-Headers-Dynomax-Exhaust-Tube-Mandrel-Bends/744799/10002/-1 - set of mendrel bends and welding up a set yourself using the existing flanges. Or, you can also speak to exhaust shops about doing that.
As for the heat-treatment, a http://www.canadiantire.ca/AST/browse/4/Auto/AutoBodyRepair1/AutoBodyPaintProtectants/PRD~0473704P/VHT%252BHigh%252BTemperature%252BFlameproof%252BHeader%252BPaint%25252C%252B312%252Bg.jsp?locale=en - ceramic coating  can be done with any header you want, just be prepared for a little time investment. Contrary to that picture, the stuff doesn't dry like spray paint, it has to be cooked (Junk electric ovens work rather well for it). But doing so allows you to select any header you desire. If you want something a bit more durable and much better looking, you can order http://www.techlinecoatings.com/hi-performance/bs-exhaust-system-coatings.html - high-end ceramic coatings in black, grey, chrome, etc...
Hopefully I didn't just make things murkier.
Date Posted: 24 June 2011 at 12:19pm
If you just need some stock manifolds for now I have a set that's just
taking up space. Don't think there's any cracks or anything but I've
never looked.
V6 I assume?
Send me a pm.
Date Posted: 24 June 2011 at 2:39pm
I have been preparing for this Tris, and locally the best price for the ceramic coating way $300...so the Sprints that are an upgrade on air flow and coated at $600 is attractive...the other two also would be a pain to deal with if there was problems, or not as bad as FS
Question would be, can anyone help install these?...yes I'll pay, would like help though
Date Posted: 24 June 2011 at 3:28pm
I wouldn't mind helping out. Would like to see them anyways.
Date Posted: 24 June 2011 at 4:14pm
Honestly Brian you should have a look at the manifolds in our old car.  They're ported and have had the flanges TIG welded.  I put a ceramic coating on them like a year and a half ago and they still look brand new.  Michelle drove the car every day during that time.
I'll give you a set of ported manifolds and ported "Y" pipe with this same black coating on them for $350 exchange.
Date Posted: 24 June 2011 at 4:48pm
Dawg, stock manifolds or who made them?...certainly interested:)
Date Posted: 24 June 2011 at 6:02pm
These are modified stock Fiero parts.  Ask around, it really makes a difference and all the stock heat shields and so on fit perfectly.
In and out in a couple hours....on a perfect day anyway.  If you end up being involved in the job make sure the manifold bolts are removed slowly and carefully.  If you break one, you'll be sorry.
I like to wiggle them back and forth a few times if I feel any resistance as they're coming out.
Cheers,
Date Posted: 24 June 2011 at 6:43pm
Any pics?...very interested as I would like a step up, let's chat
Date Posted: 24 June 2011 at 8:35pm
Any pics?  Does Santa like little elves?  Sure, Dawg's always got pics....:)
Here's a set I just did last week:
"Y" pipe:
Me welding up another manifold:
I think Dave took some pictures of before and after porting.  You won't believe what's in there now.  Why they did it that way I don't know.  They spend a ton of effort making durable stainless exhaust parts and then leave huge obstructions inside.  Huh?
Oh well, old Dawg fixes it all up for ya...
Date Posted: 24 June 2011 at 9:07pm
Can you do one like the other with more air flow?...we'll talk:)...lol
Date Posted: 24 June 2011 at 10:58pm
You mean build from scratch?  Nope, just not set up for it.
Besides, the difference between ported stock and after market headers would be minimal I think.  You would notice the most change in the high RPM ranges only.
Those tuned headers take up a lot of room also.  Have a good look at them.
Cheers,
Date Posted: 27 June 2011 at 12:09pm
That's where I need more power is the 3500RPM and above when I am hammering in 2nd gear on a autox, my engine is starving for air and power at times (depending on course layout and long slaloms).
Choices...let's see how the final bill is, Fiero back in the shop as there was a trans leak...nice
Date Posted: 27 June 2011 at 1:44pm
God damn transmission. I'm hoping it all works out in the end, bud.
Date Posted: 27 June 2011 at 5:00pm
lol...I know man, depressing
Posted By: Linlor
Date Posted: 06 July 2011 at 12:53pm
In my experience with headers, especially tuned ones, I find porting out the stock Fiero manifolds is the best way to start looking for more air flow.  Cheapest, and easiest way to get more air flow for an otherwise stock 2.8 engine.
You are not going to get, again in my experience, great changes in numbers from tuned exhaust if you haven't changed out or upgraded your intake mainfold as well.  2.8's are well known for starving the engines at higher rpm due to the flow direction changes in the intakes and the small exhaust outlet openings in the manifolds.
My opinion would be to have Dawg do the stock exhaust manifolds first and see how it works from you and then start working your way into other, more expensive, options.
My thoughts anyway.  Good luck with your decision and I would be interested in hearing how much better your rpm ramp up will be if you do go with the ported exhaust first.
Better off to upgrade ither suspension pieces versus engine for autox as you seldom get over 100 km/hr so better cornering helps shave seconds more than engine updates.  My brother is crawling down that $1000 per second slope with his autox 280z.  He has lots of power but can't keep the power on the road with the suspension so he is working his way through paycheques for camber adjustments and stiffer sway bars etc.....  I just concentrate on getting closer to the cones and trying to stay smooth..... ;o)
Don
Ferrari 308 Replica
Prova 5000s Countach Replica
Date Posted: 06 July 2011 at 2:58pm
Thanks for the input Don...certainly have modified everything else and tackle those cones.
Be interesting to see your brothers 280z...what autox does he partake in.
Posted By: Linlor
Date Posted: 06 July 2011 at 9:00pm
Baseman;
We are over here on Van Isle in Victoria. He is a member in Vanisle
motor car club. I have been out a few times in my Porsche Boxster
and have a blast but he eats drinks and sleeps the autox.......
He comes over to Mission usually once a year. Not sure when the
next one is over there this year.
He turboed the engine so lots of power now getting the suspension
set up.
Don
Ferrari 308 Replica
Date Posted: 07 July 2011 at 7:23am
Cheers Don...
The autoX is at the BC Driving Centre in Pitt Meadows, he must be attending track days, I also do with Morrisport, VCMC or UBC...the big one I need to drive (but need to trailer) is in Oregon at OPR...look it up on YouTube, amazing track.
Bass...
