Squealing sound when car turns on!
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2586
Printed Date: 26 April 2025 at 4:46am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Squealing sound when car turns on!
Posted By: InfernoFiero
Subject: Squealing sound when car turns on!
Date Posted: 19 July 2011 at 1:26am
Hello,
The Fiero squeals which may last just a few seconds when I
turn on the car. I notice the sound comes from the back of
the car...
Is this a waterpump issue?
Date Posted: 19 July 2011 at 8:11am
Sounds like a loose or worn belt.
What was the final outcome with your http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2557&KW - coolant issue and with your http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2549&KW - leaky sunroof ?
Date Posted: 19 July 2011 at 8:35am
Patty is spot on. It is a belt due to some cause or another, and if you were leaking coolant in that area, that seems like the most probable culprit.
Date Posted: 20 July 2011 at 12:43am
Hello,
I finally fixed the leaks by drilling the holes in each
of the sunroof drains, but just much more clearly so no
rubber was in the way. I put the comment in that post so
if my page ever pops up in GOOGLE it give some sort of
hope to the person viewing it.
That being said, I have not been able to do the coolant
burping yet, as I have been far too busy! I will do it
this weekend for sure (oh wait, I'm working then too)!
Anyways, I am extremely confused when you both say that
the belt could be the issue. I bought the Fiero under the
impression that there was NO belt. That's what the seller
told me, and being skeptical I researched this online.
http://tinyurl.com/3kv4sjg - This website says
there is no belt or chain!
Date Posted: 20 July 2011 at 12:49am
InfernoFiero wrote:
Anyways, I am extremely confused when you both say that the belt could be the issue. I bought the Fiero under the impression that there was NO belt. That's what the seller told me, and being skeptical I researched this online... |
I'm honestly beginning to suspect that you're just trying to yank our chains.
You're telling us that when you look at your engine you can see NO belt on it?
It's no wonder then you have overheating (and no doubt charging) issues!
Date Posted: 20 July 2011 at 12:58am
No, I am being completely genuine with my shock. I was
under the impression that it was gears to gears as
explained in the link as opposed to having a belt! At first
I was skeptical though, because a car without any
belt/chain was a first for me. I didn't look to notice any
belt, but I guess we have a belt then!!! AHHHHHHHH!
Date Posted: 20 July 2011 at 1:01am
No one here has made any reference to a timing belt.
Date Posted: 20 July 2011 at 1:08am
I thought you guys were talking about the timing belt. My
bad. Tomorrow I'll try to find the belt you guys are
talking about. I thought there was only one belt for cars
and that being the timing belt . What does this belt you
guys are referring to do?
Date Posted: 20 July 2011 at 1:15am
InfernoFiero wrote:
What does this belt you guys are referring to do? |
Have a look at your engine and you tell us. Seriously. Consider this a little test to see how genuine you are in your desire to work on a car.
Date Posted: 20 July 2011 at 8:40am
Aw Patty, at least throw him a bone. The belt is located on the "nose" of the crankshaft, far over to the passenger side.
Date Posted: 20 July 2011 at 2:44pm
I appreciate your help guys, thanks!
Posted By: karnak
Date Posted: 20 July 2011 at 10:39pm
If you do find the belt then you can check it to see if it is tight but not
too tight (motor off). Espically if it is a v belt . If you over tighten it it
via the alternator bracket, then the belt might not squeak but the
tension you apply may either damage the belt or hurt the alternator
or water pump. A water pump or alternator that is starting to fail can
lead to squeaking also but would likely be more constant. Rain that
comes thru the vent can make the belt squeak. I recomend a shot of
belt dressing on it first (comes in an aerosol can) is a reasonable
starting point
If it is not a v belt and is a serpentine belt then replace it
Gary
Date Posted: 27 July 2011 at 5:13pm
Hello,
I ended up buying belt dressing like suggested by karnak
and left the car on and sprayed it at the same spot for a
few seconds. No squeaks ever since!
Thank you guys for help!
Date Posted: 28 July 2011 at 3:46pm
The belt is squealing again, so I will now replace the
belt. If the squealing returns, I guess I will have to
replace the belt pulleys as I do see some rust on them.
Date Posted: 28 July 2011 at 4:35pm
Have you adjusted the tension on the belt yet? You may want to try that first before replacing it.
------------- 88 Formula 5 speed
Date Posted: 28 July 2011 at 5:59pm
I'm a little worried that I might over-tighten the tension!
Am I supposed adjust the tension to the point where there
should be no more than 1/2" of deflection when pressure is
applied with your thumb?
Date Posted: 28 July 2011 at 11:46pm
Don't worry too much about it. I'd guess that it would take quite a bit of pressure before anything bad came from it. Just start off by making it a little bit tighter, then if it still squeaks, do a little bit more, etc.
Date Posted: 29 July 2011 at 9:14am
Yes, the easiest way is as Colby says. Just snug it up, start it, listen, and tighten it little by little until you find the right tension. And the half an inch deflection is typically accurate if you want to try and go that route too.
Date Posted: 01 August 2011 at 6:07pm
Alright thanks, and is the only difference for the
accessory belt for a Fiero with A/C just be a bit longer in
length than the belt for a non A/C Fiero?
Edit: Nevermind, they are the same length.
I managed to replace the belt, and my car isn't squeaking
anymore, and I feel a significant difference in power. My
acceleration is much more quicker, and my rpm at start up
doesn't go higher than 1.5 (usually was around 2)!
Date Posted: 02 August 2011 at 9:03pm
Hm. 1.5 is still rather high, it should be down around 1-1.2
Date Posted: 22 September 2011 at 11:23pm
So ever since replacing the sepertine belt there was no squeaking whatsoever during the dry summer. Now, with the recent rainy days, it is starting to squeak again, worse and worse. I'll try to tension it as a temporary solution if that, but any reason why the belt is so sensitive to water?
Date Posted: 23 September 2011 at 1:42am
My '84 duke is the same way. It ticks me off.
By the way, it's not a serpentine belt on your '84, unless you've had an '87 or '88 duke dropped in there.
It's just a V-belt.
Date Posted: 23 September 2011 at 3:13pm
| Temperature affects how much grip is available. It tends to rain on colder days, and colder temperatures increase the chances of the belt slipping.
Also a factor is the water itself, obviously. I'm sure you know yourself, but a wet belt has much smaller coefficient of traction available (Consider you tire's grip in the rain).
And the last factor is the wear of the belt itself. As it ages, it's going to wear away the "inside" of the belt, which will effectively increase its length ever-so-slightly.
Obviously those two things create a bit of a double standard: You want it tight enough to prevent slippage during cold, damp weather. But the tighter you make it, the more drag you apply to the motor, wasting efficiency. One such solution is spring-loaded tensioners (often called automatic tensioners) which will apply more tension as the belt wears (Negating the wear on the belt) and will often push more of the belt around high-load accessories (Water pump and alternator).
Date Posted: 23 September 2011 at 3:44pm
Romeo wrote:
One such solution is spring-loaded tensioners (often called automatic tensioners) which will apply more tension as the belt wears (Negating the wear on the belt) and will often push more of the belt around high-load accessories (Water pump and alternator). |
I would love to have an auto-tensioner on my duke ( http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1790&KW - like I have on my GT ), but there is nothing available (as far as I know) for an '84-'86 duke with a V-belt. Heck, even a simple idler pulley would help if it could provide additional belt wrap around the alternator pulley.
Date Posted: 24 September 2011 at 8:41am
The tensioner is a great idea. I just have to find one that fits somehow.
When I go through some water I get a splash and then she slips. My splash guards are almost rotted out so that's why.
It sucks cause my voltage goes down, and it causes a ripple through the whole thing: lights, ignition, etc.
------------- 86 SE 3.4
Date Posted: 24 September 2011 at 2:31pm
Looky what I found. I had forgotten about this thread.
http://www.fiero.nl/forum/Forum2/HTML/112118.html - Has anyone ever designed/made an idler arm/pulley for the '84-'86 duke?
