Anyone know anything about fixing Fords?
Category: General Car Chat (Not Fiero Specific)
Forum Name: Car Talk thats not a Fiero
Forum Description: If your car is not a Fiero and you are not part of the PPPCC and you need to bring something up, this is the place for it.
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2643
Printed Date: 06 June 2025 at 3:25am
Topic: Anyone know anything about fixing Fords?
Subject: Anyone know anything about fixing Fords?
Date Posted: 20 August 2011 at 10:54pm
I just got back from a short five day trip to Vancouver Island (Port Alberni, Long Beach, etc) with my girlfriend and her two kids and the hound (Frankie). We used her car, a 2001 Ford Taurus wagon with the Duratec DOHC 3.0 engine. Nice car, however...
The Check Engine Light came on, and stayed on. How do I access the codes on this thing? Is there a "paperclip" trick (as with the Fiero)?
Also, it sounds like the clutch bearings (or something along those lines) on the A/C compressor are self destructing. What a racket!
I'll be googling this, but just in case anyone has any advice to offer, I thought I'd ask here. Thanks.
Date Posted: 21 August 2011 at 4:35pm
If an OBD II scanner needs to be used to retrieve the codes, can anyone recommend an inexpensive one to use?
Posted By: karnak
Date Posted: 21 August 2011 at 9:07pm
i am not sure about the fords but i have, on a newer dodge, turned on, then off, then quickly on again, the ignition switch. not starting the car. a light in the dash started to flash...
i do hope there is a quick thing like that for you...
Date Posted: 22 August 2011 at 3:11pm
Gary, it appears that an OBD II reader is required to access the codes on a Ford. Apparently some of the better units also have a way of "diagnosing" the problem (as opposed to simply displaying a code number).
Anyone have any advice on these units? I suppose it wouldn't hurt for me to buy one, as I believe they'll work on most cars made since (and including) 1996.
Date Posted: 22 August 2011 at 10:05pm
I have a scangauge II in my MINI that is supposed to be able to reset codes.
But I'm not sure how to do it on a Ford.
Oh...I found the instructions here....
http://www.scangauge.com/wp-content/uploads/documentation/sgii-legacy/SGII_UM_5-0.pdf - Scangauge II user manual
Date Posted: 22 August 2011 at 10:25pm
I have a scangauge II in my MINI...
Ken, so I take it that this Scangauge II is mounted and connected full-time in the MINI then? Do you find it beneficial to be used in this manner?
Date Posted: 22 August 2011 at 10:32pm
Actually, Patrick,
The scanguage is mounted by velcro to the dash of my car.
I use it for the gauges.   I currently have it set up to measure Intake air
temp, coolant temperature, intake boost, and ignition timing. There are
other gauges that can be programmed also.   I haven't had to a check
engine light happen on the MINI yet, so whenever I do a scan, it says no
codes found. But it does read codes and you can reset some of them with
the scangauge.
I mounted it with velcro for the case where somebody has a car problem
and I can just pull it out and use it.   But have never had to so I'm a bit
rusty in know what to do.   It looks like you just hook it up and wait for
the scangauge to sync with the computer in your car.
Date Posted: 22 August 2011 at 10:46pm
I mounted it with velcro for the case where somebody has a car problem and I can just pull it out and use it. But have never had to so I'm a bit rusty in know what to do. It looks like you just hook it up and wait for the scangauge to sync with the computer in your car.
When I get Anne's car mobile again, any chance we could plug your Scangauge II into her Taurus and pull the codes?
I said "when" I get her car mobile again because the very first time Anne went to use her car after we got back, the A/C compressor seems to have seized. (I haven't seen the car myself yet.) The single serpentine belt won't turn (or has snapped) and therefore nothing (alternator, water pump, power steering) works. We were very lucky we made it home from the Island!
Off to Pick-a-Part in the morning...
Oh....I guess I should answer your question.
Boost - That's how well the supercharger is working. If my belts are slipping
or something is misaligned, boost will be down. For a normally aspirated
engine, the gauge is converted to measure vacuum, the ability of your
car's engine to suck air in through the intake.
Ignition timing - no reason, really. With ECM's controlling that, the only
issue might be if you have short somewhere. Useful if you have a custom
tune.
Celsius water temp (as opposed to Fahrenheit water temp). - my car's
generation of MINIs have a reputation of radiator fans failing due to the
power steering motor being on the same circuit and mounted on the
bottom of the car.   If my car is going to overheat, I'll see it before it
blows.
Celsius Intake Air. THe MINI is supercharged and the intake air is cooled
via an intercooler before entering the engine.   The efficiency of the
cooling (especially in the summer) can be monitored by this gauge.
Those of you racing your Fieros on the Autocross will find most of these
measurements beneficial as they all affect the ability of your engine
making power.
Date Posted: 22 August 2011 at 10:51pm
in your car.
Island!
Yah...sure.   Let me know and pop on by. It shouldn't take 5 minutes to
hook it up and see what codes have been thrown.
Date Posted: 22 August 2011 at 11:24pm
Yah...sure.   Let me know and pop on by. It shouldn't take 5 minutes to hook it up and see what codes have been thrown.
Thanks Ken, it might be a few days. It's going to depend how I make out with trying to replace the A/C compressor.
Date Posted: 31 August 2011 at 6:19pm
I finally got Anne's car functional again. I got an A/C compressor (with pulley and clutch) from Pick-a-Part and dropped it in.
Yeah, "dropped it in". If only it had actually been that easy!
Ken, I've sent you an email.
Date Posted: 31 August 2011 at 11:43pm
That's good to hear.
Date Posted: 01 September 2011 at 11:49am
Congrats old fellow.
Date Posted: 01 September 2011 at 12:49pm
Thanks guys.
I still need to pull the codes to find out why the Check Engine Light is on. The car seems to run just fine, but...
Date Posted: 01 September 2011 at 1:10pm
Hate those Butts...lol
Posted By: karnak
Date Posted: 01 September 2011 at 1:41pm
did you put the AC compressor in backwards...?
Date Posted: 01 September 2011 at 8:48pm
It might've been easier to install that way!
What a miserable job, for something that really should've been quite simple.
Date Posted: 20 September 2011 at 6:35pm
Patrick, since the Ford runs fine and the code comes back right after resetting, I suspect the battery is bad. It might have enough juice to turn the starter motor, but it is possible the voltage is low. A plate inside the battery might have gone bad.
The P1633 code just indicates low battery voltage.
The P0000 code means all the other sensors appear to be fine.
Date Posted: 20 September 2011 at 7:14pm
Ken, thanks for hooking your code reader up to Anne's Taurus.
The next time I'm by Anne's place I'll have my multimeter with me to take some readings off the battery and alternator.
Date Posted: 21 September 2011 at 5:10pm
...The next time I'm by Anne's place I'll have my multimeter with me to take some readings off the battery and alternator.
You should do it soon. If the battery is still actually holding a charge (it appears to be), it is putting out the wrong voltage.   When the rains come, the battery will drain rapidly.
Date Posted: 21 September 2011 at 5:58pm
Rain? What rain?
< Patrick looks out window >
What the heck ??!!!
Date Posted: 22 September 2011 at 7:56pm
Date Posted: 04 October 2011 at 12:28pm
Ken, I was able to get a reading from Anne's car on the weekend. Before I started it (after it had sat for 24 hours), the battery read something like 12.6 volts. After starting it, the reading was 14.4 volts. I suspect the battery and charging system are fine.
That's great, but now I've still got to figure out why her 2001 Taurus wagon with the 3.0 Duratec DOHC engine is throwing those codes.
Her engine runs fine, but it does do one odd thing. While it's sitting there idling smoothly in PARK, every couple of minutes or so, you'll hear this relatively loud "Bink!" sound. Just once. It's like a small hammer hitting a small anvil. No thud, just a metallic "Bink!". Happens a single time, until a couple minutes later.
Anne says it does this while she's driving as well, and that the engine shudders at the time of the sound. I'm not 100% sure she's experiencing the same thing as what I've observed. It's never done it while I've driven her car.
At first I thought it was possibly a valve kissing a piston, as it seems to me this is what it would sound like. But the engine runs fine, and it only happens once each time.
I'm now wondering if it's possible the ignition timing all of a sudden gets too far advanced just for a split second, and it's actually a single loud "Ping" I'm hearing before the ignition timing automatically backs off again.
I have no idea if this is even possible, but I know nothing about these engines and how they may or may not be controllled by their ECMs.
Date Posted: 04 October 2011 at 5:20pm
Want to borrow my scan-tool?
As for your ignition idea, it does fit the idea, and I know the modern Ford engines all run an ignition system that keeps on advancing until it detects knock, then backs off one degree. I don't think the last gen Tauri had them though... Could just be that the spark plugs are too hot a heat range. They'd get hot, pre-ignite the mixture, then cool off again. Just a guess, mind you.
Date Posted: 04 October 2011 at 6:26pm
I might've found the problem and solution  http://www.allfordmustangs.com/forums/4-6l-tech/82577-obd-ii-codes-p1633-p0511-any-ideas-what-start.html - Here .
Quote
P1633 - Keep Alive Power Voltage Too Low Indicates that the Keep Alive Power (KAPWR) circuit has experienced a power interrupt.
Possible causes:
Open KAPWR circuit
Damaged PCM
Intermittent KAPWR Circuit
KAPWR is supplies from fuse 21 - 5 amp in the Central junction box (interior fuse panel). It is hot at all times.
Quote Had the same problem with my daily driver '05 Taurus with the flex fuel engine.
Same a/c problem and the same codes.
After wringing out the wiring with a multi-meter and coming up unfulfilled and highly frustrated, I googled the problem and ended up on this site. I read your thread and said to myself "could it really be that simple?"
Ten minutes later, with a fresh fuse installed and the problem disappeared... thanks bud!
Seems to be too much of a coincidence that the people posting in that thread all had A/C compressor clutch problems (as did Anne's Taurus) immediately prior to throwing this code!
I'll be checking those fuses the next time I'm at Anne's place. Who knows, maybe this has something to do with that odd noise I reported as well (if it has something/anything to do with how the ECM/PCM controls things).
Date Posted: 04 October 2011 at 6:29pm
If fuse replacement doesn't solve this problem... Yes!
Thanks dude.
Date Posted: 04 October 2011 at 9:29pm
No problem. That's what young, awesome, attractive, intelligent friends are for.
Date Posted: 10 October 2011 at 1:40pm
Woo hoo!
I checked the fuses in Anne's Taurus and discovered that the 10A fuse for the A/C compressor clutch and the KAPWR circuit had indeed fried. Put in a new fuse and the Check Engine Light is gone!
Seems like kind of a dumb idea to put the A/C compressor clutch and the "keep alive" power for the PCM/ECM on the same electrical circuit, but anyway, I now know about it. (I don't have the A/C compressor clutch connected electrically as the system needs to be re-charged, so I wasn't aware that the A/C compressor clutch wasn't getting any power and therefore hadn't suspected that any fuses had failed.)
It's too early to tell if this has also resolved the "Bink!" sound coming from the engine, but I'm hoping it was just an ignition timing issue caused by the PCM/ECM having to re-adjust and re-learn settings (including ignition timing) every time the car was turned off and then on.
I want to thank Ken again for putting his code reader on Anne's Taurus and pulling the codes so I at least knew where to start in regards to rectifiying the problem.
Date Posted: 10 October 2011 at 2:03pm
My pleasure. Glad you figured it out.
Anybody else needing read codes off their OBD II port are welcome to pop by if you need your codes read.
Date Posted: 17 October 2011 at 10:32pm
I'm delighted to report (after driving Anne's Taurus this past weekend) that the "Bink!" sound is indeed now gone!
I'd love to have this Ford 3.0L DOHC Duratec engine in a Fiero. It's 200 HP, with an aluminum block and heads, and four valves per cylinder. This engine really makes a full size Taurus wagon move. It would be a great upgrade in my '84 from a duke.
Date Posted: 17 October 2011 at 11:59pm
How dare you suggest such a transgression!
A Ford motor in a Fiero, you watch your tongue. The only Ford motor I would want to see in a Fiero is the new Scorpion diesel.
On topic though, if you like the Duratec, you should try and drive the SHO Taurus one day. Same motor, but it has a short ram and a long ram intake, so it builds torque, then swaps over and makes HP galore.
Date Posted: 18 October 2011 at 12:45am
Yeah, and I'm not even a Ford fan.
Anne's Taurus wagon even sounds good when I put my foot into the accelerator. Maybe I should autocross it one day.
Date Posted: 18 October 2011 at 9:30am
If you think the 3.0 Ford is a great motor, you would love the GM version of that motor.  The 3.4 DOHC motor, 7000 rpm shift points and well over 200hp.
Date Posted: 18 October 2011 at 1:35pm
Bah, still not as cool as the V6 and V8 SHO engines. Your pick between a 225HP V6 (7000RPM, 3.2L), or the 235HP V8 (7000RPM, 3.4L). Both feature the dual intakes that switch over at 3400RPM.
Yeah. There is a Cosworth/Yamaha V8 with as much displacement as the biggest stroker package for the Fiero.
Date Posted: 18 October 2011 at 2:11pm
...you would love the GM version of that motor.  The 3.4 DOHC motor, 7000 rpm shift points and well over 200hp.
Too bad the GM 3.4 DOHC still has a cast iron block.
I doubt I'll ever swap an "exotic" engine into a Fiero myself, but I imagine it would be great fun to drive a Fiero which has a lot of power.
Date Posted: 19 October 2011 at 11:39am
The DOHC? Always thought it was an aluminum... I think we can all agree that the aluminum block 2.8 from GM beats everything.
Date Posted: 19 October 2011 at 4:54pm
Actually, if somebody can correct me if I'm wrong, all the GM 60deg V6 engines varying from 2.8L to 3.4L are cast iron blocks with many variants (including the Fiero) using aluminum heads.
I don't remember GM ever making the 60deg V6 block in aluminum. Even the 3.1L variant designed in conjunction with McLaren was a cast iron block with aluminum heads.
Maybe for custom race applications, they made one, but not for series production.
I've only ever worked on one GM aluminum engine, the 2.3L L4 used in the Vega/Astre, which was a disaster. GM got it upside down. Aluminum block with cast iron head. The head looked a lot like aluminum so I can understand the confusion.
Date Posted: 19 October 2011 at 7:47pm
Ken and Romeo you are both right.    The aluminum 2.8 blocks were amazing however they were never a production block.  You could buy them from the GM Performance Parts Division.  They were used heavily in the S10 Race Trucks.  The last one I know to exist belonged to Sean Hammit, the major A-SS Hat bastard that now runs the Real Fiero Tech website, which used to be called Pennocks Sucks . com as he was banned from Pennocks for being a rude childish SOB.
I believe most of the 2.8 Alm blocks ended up being bored out to 2.9 liters and having custom steel sleeves.  The bare block weighed I believe just 40lbs.
Date Posted: 20 October 2011 at 1:39am
'Aye, that's the one. Apparently they're a skank to get ahold of, from what I hear. Just makes me want it more.
