Upper ball joint (88)
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2732
Printed Date: 26 April 2025 at 4:49am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Upper ball joint (88)
Posted By: DannyCanuck
Subject: Upper ball joint (88)
Date Posted: 26 October 2011 at 6:52pm
As the title implies, the front-upper ball-joint on my 88 has about 1-2cm of play in and out when I grab the top of
the tire. Can this be fixed (tightened) or do I need to
replace it?
------------- 88 duke, bog standard
Date Posted: 26 October 2011 at 10:47pm
Ball joints are a replacement item. I know people absolutely adore the Rodney Dickman's, so that's a fairly safe bet. I also personally have had great success with the Moogs. Ultimately though, it's totally up to you. Just don't forget to get an alignment after.
Date Posted: 27 October 2011 at 4:53pm
If its in your budget,replace all 4.its an 88 an they are likely org.if that one is gone,the others arn't far be hind it.you don't need a lot of tools to do this job,best to get help from some one that has done this be for.heres a clue to if there org or not,if the balljoint is bolted,its a replacement an easy to change,if riveted then its stock and you just cut the rivets off to change it.lowers you just drive out with a hammer. good luck
OH! don't just undo the nuts an bolts on the upper balljoint,thats could be danger us! theres a big spring there that loads that balljoint,look in to it be for trying this your self,cheers
------------- SNOW MAN
Date Posted: 27 October 2011 at 9:49pm
For the lowers, go to Canadian Tire and rent a ball joint separator if you don't already have one. Makes the job so much easier and it's free.
Date Posted: 28 October 2011 at 5:23pm
If I need to ship them in I'll get all four. Do any of you
know if lordco has them?
Date Posted: 28 October 2011 at 8:19pm
Yes they do, they carry a Delco replacement brand and Moogs. Rodney Dickman's are an order-by-individual item which means they get shipped to your front door.
Date Posted: 28 October 2011 at 9:12pm
Actually, Lordco only sells the lower balls for the 88, so
I guess Rodney will get the money.
