Steering Column and/or A/C work
Forum Name: Build Threads
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=274
Printed Date: 04 July 2025 at 5:27am
Topic: Steering Column and/or A/C work
Subject: Steering Column and/or A/C work
Date Posted: 07 July 2007 at 10:21pm
Hi all,
Well, after almost 2 years...I have wipers
Mark this contact down for any work on any GM or Ford vehical that is steering rack or A/C related...he is awesome.  I am posting the original post from Ron back in December 2006:
This is just a lead to note and keep on file in case you need it sometime.
I found a guy in Langley who is an expert on this stuff.  He does steering columns for local body shops and hot rod builders.  He's especially familiar with GM columns.  He can assemble them with his eyes closed.  He did one once in the dark because the car couldn't be driven and there was no light available.  He took my dissasembled column and replaced the broken part and reassembled it for $60.  He has loads of spare parts.  He buys every column he sees at swap meets (and his back yard looks like it too).  It's his hobby as well as his work.  He loves this stuff.  His name is Russell Townsend.  His phone number is 604-888-9077.
Ron
Date Posted: 08 July 2007 at 11:16am
He did the column in my buddie Jacks Astro van, and Jack said that he was very impressed with him.
I think he's worked on a few others from around here as well!
Date Posted: 08 July 2007 at 12:56pm
Again...any Ford's or GM's...he's the man, and such a down to earth nice guy, he lives on Hudson Bay Street in Fort Langley, the road that leads to the Fort.  He will travel to you within Langley, any further then you have to talk...otherwise bring it to him.
Date Posted: 19 July 2007 at 10:41am
Did you have "PHANTOM WIPERS"?
Date Posted: 19 July 2007 at 1:43pm
No, my wiper switch had to be replaced.  There is a few resistors or whatever...little electronic things that dies which fried the PC board for the intermitten wiper in the motor.  I replaced with a new motor and PC board which ended up being $300...then lead to having to change the switch.
Blair was working on the Phantom Wiper issue, not sure where he is at with it, same fix as Dickmans has but trying to source locally
