WTD: manual swap parts (F23)
Category: Buy / Sell
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2779
Printed Date: 20 April 2025 at 11:18pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: WTD: manual swap parts (F23)
Subject: WTD: manual swap parts (F23)
Date Posted: 12 December 2011 at 8:26am
I need some parts for my f23 swap. and by "some" I mean pretty much
everything an auto wouldn't have. So if anyone has something they no
longer need or a good source let me know.
What I still need:
Clutch switch connector
Mounts?
Clutch
Flywheel
Pressure plate
deckid torsion bars
Already got:
Shift cables
Shifter
Center console
Axles
Clutch pedal
Brake pedal
Clutch line
The trans itself I will get from pick a part unless someone knows a
better source.
Date Posted: 05 February 2012 at 4:43pm
Anybody have the connector that plugs into the clutch switch? I have the switch itself, but no way of plugging the wires into it.
Also, the little clips that hold the shift cables into the brackets, I need 3 more, only one on the auto was the right size.
Those are the last pieces I need to get the interior back together.
Let me know,
Thanks
Date Posted: 22 February 2012 at 9:25pm
For those that have done manual 3800 swaps, where did you get your flywheel? I have heard bad things about the cheap aftermarket brands being porous once machined, and don't wanna spend hundreds on an aluminum one.
Posted By: finallall
Date Posted: 26 February 2012 at 6:00pm
I got mine from West Coast Fieros. I took over 1 month to
get here (Edmonton) but it's a quality unit and cost me
lass then $300.
Date Posted: 04 March 2012 at 7:29pm
$300 is a little too steep for me right now.
Looks like I need some decklid torsion bars came out this morning and one was snapped. I have a wing so they will need to be the stronger ones.
Date Posted: 05 March 2012 at 3:12am
As long as the fenders don't fall off during the night, you're good...:)
