3.5L LX9 Swap into ’86 2M6 4 speed
Forum Name: Build Threads
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2825
Printed Date: 05 July 2025 at 5:08am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: 3.5L LX9 Swap into ’86 2M6 4 speed
Posted By: bcampbell
Subject: 3.5L LX9 Swap into ’86 2M6 4 speed
Date Posted: 10 February 2012 at 10:37pm
Hey I'm new here and new to Fieros. My end goal is to
have a daily drivable Fiero that I can have fun with
autocrossing occasionally. I'm not looking for something
super fast as that's what my other car is for.
I bought my Fiero back in December for $700 and it had a
2.8 in it that was rebuilt in '09 (sticker on the engine)
by Cords Engine Specialists. However after trying lots
of ways to get it running and also discovering cylinder
#1 had >20 psi lower compression than #3 and #5 I decided
to give up on the 2.8. There's minimal rust on the whole
car so I really didn't want to just scrap it.
The LX9 I got is from nfswift on these forums as he
abandoned his swap. As a bonus, I ended up with his LX9
from an '06 G6, aluminium cradle bushings, poly rear
control arm bushings, 3400 coils and ICM, TCE crank
trigger, and 3 exhaust manifolds to play with for $600.
My shopping list right now for remaining necessary parts
includes:
- '88 Flywheel
- 7730 ECM and pigtails
- Knock Sensor
- Rad Hoses
- LX5 Throttle body
- Wiring from crank sensor to ICM
- Either vette fuel filter or 3400 rails and injectors
with regulator (haven't decided yet)
- A tune, obviously
- New motor mounts (don't trust old possibly 25 year old
mounts)
- Alternator (does anyone know if a 3400 alternator will
bolt up?)
Plans include to get the LX9 injectors tested (they've
been sitting for a few years now and I just don't trust
them), making a throttle body adapter plate for the LX5
throttle body, and wiring in a 7730 ECM per Darth Fiero's
instructions available on-line. I also plan on de-
looming the harness and routing the wires in a way that's
ideal for the Fiero. Since my 4 speed clutch is
practically brand new and I don't plan on a lot of WOT
with this engine I'm going to re-use it. Since the LX9
didn't come with a starter I'll most likely re-use the
2.8's starter.
And here's some pics of the car and the new engine:
I want to have this running ASAP and I'm probably gonna
make a parts run to Port Angeles since everything is so
much cheaper in the US. My goal (probably unrealistic)
is to have this started within 3 weeks.
Date Posted: 11 February 2012 at 1:10am
Looks like it's in nice shape for $700. Good deal I think.
Welcome to the group.
Date Posted: 11 February 2012 at 1:26am
Thanks it was my first time painting a car and there's
lots of flaws with the body (been in a front end
accident). However there's minimal rust on the whole
car, the brakes were all done within the last 5000 kms,
and the suspension is not showing any sagging. Most of
the rust I've found so far has been cleaned and coated
with POR-15.
I'm probably gonna try going over it again with rollers
after seeing how well my friend's truck turned out since
I have tons of leftover paint anyways. And eventually
I'll paint the trim in flat black and scrape off the red
overspray on the windows from the PO's paint job .
Date Posted: 11 February 2012 at 10:09pm
Minor update for today, I just took a wire wheel attachment
for my drill and cleaned up the aluminium parts a bit, then
moved the tensioner and swapped its pulley with the idler
below the water pump.
Date Posted: 12 February 2012 at 9:14am
bcampbell, where are you at? On the island somewhere? I was going to help nfswift with his swap (Electronics side) but then he moved on to other things.
If you're looking at the 88 flywheel for the neutral balance, keep in mind you can just get the wieght on a pre 88 flywheel machined off and it's just as good. I did this for my 3.4 swap.
It's 1/2 hr of work and $50. (Actually the guy charged me $25 cash and I gave him $40 and said thanks for doing it, it was his day off).
------------- 86 SE 3.4
Date Posted: 12 February 2012 at 12:26pm
things.If you're looking at the 88 flywheel for the
I did this for my 3.4 swap.It's 1/2 hr of work and $50.
off).Chay |
Ya I live in Victoria and the car/engine is in Cowichan
Bay. As for the flywheel, I can get a brand new one in
the US for $55 so it's not really much more than re-using
the imbalanced one. Plus I can get most of the other
parts I need new there and I'll most likely also buy new
motor/trans mounts ($10 ea, haven't priced them out
here).
Date Posted: 12 February 2012 at 1:01pm
Please don't use stock mounts....... Do yourself a HUGE favor and order a set of dickman trans mounts. It will save you a TON of grief later on.
Date Posted: 12 February 2012 at 2:15pm
mounts.......
Why would stock mounts be inadequate? Wouldn't the stock
G6 use rubber mounts anyways? As long as the mounts are
new, I didn't think it would be a huge deal. Obviously,
I'll need to fabricate a dog bone mount in addition to
the three stock mounts.
Edit: It looks like rodney's transmission mounts use a
standard polyurethane GM transmission mount. I happen to
have one of these leftover from my 89 Firebird project.
How much work would it be to make use of it?
Date Posted: 12 February 2012 at 3:42pm
The Stock Rubber G6 would have been stronger. If you can use G6 mounts great. However the stock rubber Fiero trans mounts IMHO are Junk. Granted my V8 makes 300+lbs of torque, but the fact that I could put a new set of stock rubber trans mounts in, take it out to the street pop the clutch ONCE, and bust a Lordco Anchor mount, I stopped using stock mounts. If I could have used the Cadillac rubber mounts I would have been fine, but the Fiero mounts just can't handle the abuse of an engine swap. Even if you don't drive it hard all the time, if you plan to take it to the road course occasional, a good set of aftermarket mounts will give you a great deal of piece of mind.
Date Posted: 12 February 2012 at 5:07pm
Ok thanks for the info. Unfortunately, I can't really afford to spend
$150+ on mounts right now so that will have to wait for the time being. I
won't drive the car hard just to be on the safe side until if get some
better mounts.
Date Posted: 12 February 2012 at 5:14pm
Anyone here have experience tuning OBD1? I took a look at the
injectors today and they appear to be in great shape, the only thing I'm
wondering is that since if I use an LS1 vette fuel filter to regulate the
pressure, it will constantly be at 58ish PSI. Does this present a tuning
problem since the 7730 computer is designed to work with vacuum
regulated (and thus variable with MAP) fuel pressure? I know I can get
a vacuum regulated aftermarket regulator but I'd rather not spend the
extra cash.
Date Posted: 12 February 2012 at 7:40pm
I have the stuff...prom burner/reader and ostrich ii for tuning, and tunerproRT of course. You'd need a G2 (I think) adapter from moates if you want to borrow it and do it yourself.
What code were you thinking of running in the 7730?
My wideband 02/logger got destroyed though. I have to get a new one!
As far as the reg goes, I've always wondered about the function of that beast. One way to look at it as the load increases it increases the psi to the injectors to help deliver more fuel. But hey, why not just deliver the fuel at a high pressure all the time and cut down the injector pulse width?
My hypothesis is that is has more to do with lowering pressure at idle to better deliver smaller quantities of fuel at low injector pulse widths for emissions.
My guess is that a solid 58 psi will be fine to tune with. You just have to make sure that psi won't overwhelm the injectors, but they are a new type so I'd guess them to be ok at that psi.
As you are creating a map anyway, the regulator can be taken into account with the map.
Other will hopefully chime in with more knowledge.
Date Posted: 12 February 2012 at 8:30pm
IIRC I was planning on running the $A1 code. It would be really sweet if
I could borrow the tuning hardware. I already have a laptop and
tunerproRT and an ALDL cable that should work. One thing I don't have
is a wideband but can't the BLMs be used with data logging? I'll order
a G2 adapter tomorrow if they're not too expensive.
I have some more pics and updates I'll post later tonight.
Date Posted: 12 February 2012 at 11:54pm
So today I got some basics done, pulled off the upper
plenum and throttle body, pulled out the fuel injectors,
took a look at the spark plugs, transferred the oil
filter adapter and pressure sender from the 2.8, and de-
loomed and labelled the 2.8 harness.
After pulling off the upper plenum and the fuel rail I
cleaned up the lower intake a bit as it had dirt and oil
on it. Taking a look at the injectors, they are in great
shape, and I'm having second thoughts about needing to
have them tested. I was expecting to find some dirty or
rusty injectors from sitting so long disconnected from a
fuel system, but appearance wise they are fine.
What do you guys think? Get them tested or not?
I removed the stock 3500 oil filter mount as I have read
it interferes with the Fiero cradle, and took the spin-on
adapter on the 2.8 and installed it on the 3500. I used
a 3/8 Allen socket to remove/install it; I don't think it
was exactly the right size but it's close enough and
that's the only allen socket I have that's nearly big
enough.
As for the oil pressure sender, I'm not exactly sure if I
put it where it's supposed to go, but I saw a plug near
where the oil filter mounts and found that the 2.8's oil
pressure sender threads right in in place of the plug.
Hopefully I got that right :).
I also modified the front engine mount to clear the new
oil pan and test-installed the CPS mount bolted over the
motor mount. So far so good.
I then took a peek into one of the valve covers through
the oil fill cap and checked out the spark plugs that
were in the engine (#1-#6 left to right in the picture).
And then on to wiring. I'm thinking I'll try to use the
whole 3500 injector harness instead of grafting the
individual plugs onto the 2.8 harness. The engine came
with a nearly complete harness so I have the other side
of the connector that plugs in. The harness also has a
plug for the new MAP sensor on it (in addition to the cam
position sensor and CTS). If going this route I will
change the pigtail for the CTS to a 3-wire sensor.
Question: If I switch to a 3 wire sensor, does that mean
I have no wire for the dash temp warning light? The
2.8's gauge sender is a 2-wire while some other early V6s
seem to have just a 1-wire sender. I'm thinking with the
2-wire sender, one wire is for the temp gauge and one is
for the warning light, am I correct? If that's true, I
can probably just wire in a 3-wire sensor and forget
about the warning light.
Finally I labelled and deloomed the 2.8 engine harness in
preparation to be run neatly on the new engine. In the
process I also discovered a problem area in the old
harness where I'm assuming the harness was rubbing on the
alternator belt and it completely cut through the fan
switch wire, cut through the insulation on an alt pigtail
wire, and cut through the insulation on a fuel injector
harness wire. I'll be splicing in new wires to replace
those three (fan switch will become knock sensor wire
anyway). Anyone know if I'll need a new pigtail for my
alternator (I'll probably be getting one off a 3400).
Date Posted: 13 February 2012 at 7:58pm
Picked up a 7730 computer today and an LX5 throttle body
($75 and $65). ECM came with pigtails and the number on
it read 16198262 instead of 1227730 but when I looked up
the number it appears to be an updated number (ECM is a
re-manufactured Delphi unit, so that makes sense).
Throttle body came with an IAC and TPS installed, and I
found some pigtails that will work for them. 1 is from
the 2.8's ICM 4-wire and the other is a 3 wire I found in
my box of leftover wiring from an LT1 swap.
Was about to order a G1 adapter from moates and then
found out shipping was $33! Anyone know a Canadian
business that sells them?
Date Posted: 14 February 2012 at 8:36am
I don't think there is a Canadian business that sells them, but I don't really know. I've never seen it.
$33 is really excessive for a small super light part. What form of shipping did you choose? I use usps, and slow is good for me which usually makes it cheaper. Maybe phone those guys and see what they have to say.
You can't use blm's exclusively. You can use them in closed loop if you want, but not in the power (fuel enrich) areas. In these areas the coorect a/f ratio is too low for the narrowband o2 to measure, and therefore blm's are not updated.
You can borrow my ostrich no problem. I have to tune my own ride what I finally get it ready, but it's a 3rd car so I'm pretty flexible.
One sugestion, you could use $59 (Sy/ty updated code) which is pretty easy to tune and has all the stuff for forced induction should you choose that route later. You would have to grab a 3bar map sensor. You are going DIS right? I suspect you have no choice with the intake. I'm pretty sure they have the settings available to do it.
Check out code59.org.
It's what I'm tuning with for the turbo, so I'm totally biased.
Date Posted: 14 February 2012 at 8:46am
I have an odd question has anyone tried finding an OBDII system that will work on our engine swaps. My Caddy is from what I understand OBD1.5 or a very late OBDI Our club OBDI scanner won't work on my Caddy ECM, as it won't go to a new enough year. (Our old OBDI scanner would work though) I have been reading about OBDII stuff recently and really like the options on the newer systems.
Date Posted: 14 February 2012 at 10:40am
I cna't see any reason why it wouldn't work.You may have to add sensors though (cam and or crank).
It seems like the way to go for custom programming is efi live, or hp tuners.
Date Posted: 14 February 2012 at 11:07am
the newer systems. |
I know there's someone that's used a '98 Venture PCM with
their 3500 swap. The main reason I didn't go that route
is because it's more expensive to tune, wiring is more
involved (although equally as well documented), and
another 24x crank sensor has to be installed on the
engine. I understand the main advantages would be SFI
and a faster, more capable engine controller.
I would also have been interested in installing the stock
3500 PCM but there are zero aftermarket tuning options
right now (HPTuners only lists the '07+ VVT/DoD 3500
engines as being compatible with their software right
now). And of course without the ability to tune the PCM
it expects lots of input from the BCM, like VATS.
Date Posted: 14 February 2012 at 11:12am
I think it might be worth it if you can find an obdii code that runs lean burn/wideband 02 for the extra fuel economy. Also, I think the logging output is vastly improved with obdii.
SFI doesn't do you any good except for a cleaner idle. Big deal.
Date Posted: 14 February 2012 at 11:15am
it.$33 is really excessive for a small super light part.
On the website I selected the cheapest option (USPS).
UPS (1 x 0.6lbs) is listed as $76.15.
therefore blm's are not updated.You can borrow my ostrich
When I tuned my LT1 swap, I just disabled PE mode to tune
these areas and it was successful. However the tune was
already much closer to being correct to begin with
anyway. I know a wideband is definitely the way to go.
It might be possible to borrow one from a friend who's
car is parked right now anyways but I don't think his has
an output for datalogging (just a gauge).
available to do it.Check out code59.org.It's what I'm
tuning with for the turbo, so I'm totally biased.Chay
I'll look into it. I do happen to have a TGP turbo set-
up that I'm trying to sell right now but if I am unable
to sell it I may decide to use it on this engine in the
future.
Date Posted: 14 February 2012 at 11:19am
improved with obdii.SFI doesn't do you any good except for
a cleaner idle. Big deal.Chay
Doesn't the $A1 OBD1 code have a lean burn/highway mode
already?
Date Posted: 14 February 2012 at 11:26am
To be honest, I'm not familiar with that code.
Does it have wideband code in it?
C
Date Posted: 14 February 2012 at 11:39am
Not that I'm aware of, but there's at least one hacked
version of it and it looks like it has wideband ability, in
addition to having MAP tables with smaller (and I'm
assuming more accurate) increments, and the ability to tune
for much higher revving. It's called nAst1.
Date Posted: 14 February 2012 at 2:37pm
Just finished the first step of the wiring harness;
repinning the ECM connectors. On the second page of
instructions, the first direction is to connect a wire to
the A/C pressure sensor (5V reference). I'm assuming since
I don't have A/C I won't need this wire. However in the
7730 pinout this wire is a 5V reference for the TPS sensor.
I just want to check and make sure that the 5V reference
for the TPS sensor will be provided with another already
existing wire.
Date Posted: 14 February 2012 at 3:48pm
These kind of questions...try to get a hold of a schematic for a car that used the '7730 instead of just a repin table. Then you will understand what you are doing.
Like this one: 1991 corsica 3.1:
It seems like what you are talking about is pin A4 (Also known as BA4) which feeds power to the map, and ac pressure sensor. If so, just omit the connection to the ac sensor and you will be fine. Likewise on the ground (B5, or BB5) which is the ground for the tps, iat and ac sensor.
Date Posted: 14 February 2012 at 3:57pm
Having reread your question, it looks like the on the '7730, BA4 and BA5 are both +5 ref.
The table you are working from shows you are supposed to change C14 from the old ecm to BA4 of the new ecm. C14 is the +5V connection to the tps and map, which you are then hooking to the BA4 +5 on the '7730. BA5 is therefore unused in the '7730.
Date Posted: 14 February 2012 at 4:18pm
Ok that's what I thought thanks
Date Posted: 15 February 2012 at 2:01pm
Ok I ordered the G1 package from Moates today, they told
me they could ship it regular USPS for $12.95; they are
going to refund the money from the $33 shipping charge.
I started wiring in the LX9 fuel injector/MAP/CTS harness
today and just had a few things I would like to clarify.
The Fiero harness has two IGN power sources for the
injectors, one for each bank, while the new harness only
has one source. I figure if I just use one of the Fiero
wires (INJ 1), I can just double the fuse to a 10A and
delete the other INJ 2 power wire. Also, I can just take
the ECM signal wires for 1, 3, and 5 and 2, 4, and 6 on
the new harness and splice them into their corresponding
single wires on the Fiero injector harness. The
remaining CSI wires on the Fiero harness are deleted.
MAP sensor wiring is pretty straightforward, 5V
reference, signal, and low reference (ground). CTS I'm
thinking I'll run a 3-wire sensor, have two wires running
through the existing LX9 harness, and have the third wire
going to the gauge seperately.
Date Posted: 15 February 2012 at 3:24pm
Re: Shipping costs...that's a bit more like it!
Re: 10 A fuse: Just make sure that the wire guage is up to it. 10A should be a #16 at the minimum, #14 prefered. If you splice as you've explained above, split 3 injector wires to the +12 harness, and 3 to the ecm switched ground wire that'd be optimal. Then you should have lots of current capability.
What's a CSI??
The guage and ecm coolant temp sensors are separate on the fiero. Don't mix the 2 circuits would be my advice.
The ecm is just a variable resistor which is between an ecm pin and ground. The ecm measures the current flow and determines a temp.
The guage circuit should be untouched??
It looks like this:
The ecm one looks like this:
Date Posted: 15 February 2012 at 3:52pm
CSI=cold start injector no longer used with a 7730.
The power wire for the new injectors in the lx9 harness is of a smaller
gauge than just one (either inj1 or inj2) injector wire from the fiero
harness. I see no reason the wiring should be overloaded. IIRC the
fiero wire was 14 gauge.
As for the CTS, if I used the 2.8 gauge sender on the new engine that
means drilling and tapping another hole for the sender. Some newer
60*V6s use a 3 wire sensor where 2 wires are exactly like a 2 wire ECT
sensor and the third wire drives the gauge, so it's basically just two in
one. This route means I would take the third wire on the new sensor
and splice it into the 2.8 sender wire.
Date Posted: 15 February 2012 at 6:02pm
Ah yes, the good old csi.
14 guage should be fine.
Cool on the CTS. I've not seen a 3 wire, but it sounds like you have it fingered out!
C
Date Posted: 15 February 2012 at 6:41pm
I did want to ask about the gauge sender though. Obviously one wire
on it is the gauge signal, but what's the other wire for? Is it for the
warning light in the gauge cluster? Or is it just a ground?
Date Posted: 15 February 2012 at 7:50pm
Oh and I also meant to ask: would the now unused INJ 2 wire be a
good power supply for a heated o2 sensor?
Date Posted: 15 February 2012 at 10:35pm
Is it for the
ground? |
To answer my own question it appears that one wire is the
gauge signal and one is the warning light switch. I should
just be able to leave the warning light switch wire
unwired.
Date Posted: 16 February 2012 at 12:33am
Just did some reading up on codemask $59 and it looks like
most people running it have boosted engines. For the
foreseeable future I plan on keeping this engine N/A so
I'll probably just stick with $A1. If I wanted more power
I would probably be more inclined to do a cam swap to
maintain some form of fuel economy.
Date Posted: 16 February 2012 at 4:47pm
$59 just give you the option is all.
I was running it n/a and it worked well. Nothing wrong with the $A1 though.
The o2 sensor...not sure. It's just amps and awg though, nothing special. I don't know how much o2 sensors draw.
Date Posted: 18 February 2012 at 12:04am
Nice thing about the heated o2 sensors is that my engine
came with 3 of them. So if one doesn't work I should
still have one that does.
I'm probably going to make a trip to Port Angeles on
Monday or Tuesday to grab at the very least a flywheel
and a knock sensor. Those items are each $100 here and
about $100 combined there so I'll be saving plenty. I'll
also try to grab a 3 wire CTS, radiator hoses (using 3400
swap part numbers mentioned on 60degreev6.com) and a 2001
vette fuel filter. Maybe some fuel injection hose as
well.
Wiring is mostly finished now, I've changed the pigtails
for the TPS and IAC, wired in the knock sensor using the
fan switch pigtail, and connected the wires for the
computer fan control. I still have to do the DIS wiring
and crank sensor. Question about the crank sensor: does
the twisted pair of wires have to be twisted the whole
length of the wires? Cuz where the pigtails connect I'm
not sure it's gonna want to twist perfectly... I've
started routing the wires around the engine but want to
get it back in the car to get everything perfect. I'll
loom it up after I get the engine started.
I'm thinking to mount the coils I'll use the 3500
mounting bracket and drill holes for the 3400 coils and
ICM.
Date Posted: 18 February 2012 at 6:11pm
It's unlikely a bit of untwisting will hurt.
The idea of a twisted pair is that it radiates less noise, and also rejects incoming noise better than parallel run wires.
Try to maintain the same number of twist per foot as the original. A bit or error here or there should be fine.
Date Posted: 22 February 2012 at 9:36pm
Ok so I went to Port Angeles and stayed overnight with
friends there. I spent almost $200 on parts and didn't
get charged any duty so that was nice. I ended up
getting a vette fuel filter, flywheel, oil cap, idler
pulley (one of mine was broken), oil filter (wix), crank
sensor, 3-wire CTS (for 97 Grand Prix, in case anyone is
wondering), and a new front engine mount. When I called
on Saturday they said they would hold a knock sensor for
me but it wasn't there when I arrived. Oh well, I'll
probably find a couple in a JY and hope one of them
works.
Today I installed my flywheel and clutch, I also bolted
up the 2.8 starter; it comes very close to touching the
oil pan but I don't see it being a problem, I just need
to get a shorter bolt because one of the 2.8's bolts is
too long for the new engine. I cleaned up the inside of
the 4 speed's bellhousing and installed the new engine
mount on the cradle. I'm about ready to mount the engine
to the cradle. I couldn't find a part number for a pilot
bearing and didn't see a bearing in the 2.8 so I'm
assuming that the 4 speed manual doesn't use one.
I also found out that a Canadian Tire pickle fork makes a
perfect clutch alignment tool:
Some pics of the old flywheel vs new and the friction
surfaces:
Thickness of the clutch:
I found out the 2.8 spark plug wires work fine where I
mounted the coils. They're a little on the short side for
one side but they're not being stretched so I think
they'll be fine (NGK). To mount the coils I drilled
holes in the 3.5 mounting bracket and used nuts to secure
the bolts. The original mounting bolts are still in-tact
in case I want to go back to the 3.5 coils in the future.
I did want to ask if anyone knows what this port in the
rear side valve cover is for:
I'm assuming it's for PCV, but the other side valve cover
already goes to just behind the throttle body so I'm
wondering if anyone knows where the other port goes.
Could I just put a breather on it or does it require
vacuum?
Edit: Found out it just needs filtered air. I'll
probably put a breather on it.
Date Posted: 26 February 2012 at 1:48am
Some fairly minor updates. Got 3 of 4 rubber cradle
bushings out so far, hopefully the last one will be out
by Monday and hopefully the engine will be going back
into the car Monday as well. I'm debating whether or not
I should do the polyurethane bushings on my rear control
arms now as well but I assume that means getting a rear
alignment. If they hadn't come with the engine I
probably never would have bought them. Anybody have
personal experiences they could share as to what
differences aluminium cradle bushings and/or polyurethane
control arm bushings make?
Here's a pic of the engine about to be mounted to the
cradle finally:
In the next pic you'll see the motor mount nut is almost
touching the new oil pan. I carefully threaded it as I
lowered the engine onto the mount because I did not feel
comfortable 'clearancing' the oil pan.
Another pic of the complete cradle assembly:
Next question I have is about the ignition coils. Are
they in the right order? (This is the way they were when
I got them). Edit: These are indeed in the correct
order.
And finally I got an alternator and found a belt to fit
(IIRC the size was 640). Originally I wasn't going to
use the idler pulley right by the alternator, but since
the belt was too short otherwise and I didn't want to go
back to Lordco for a fourth time, I added it and the belt
fit great. It's just as well as it gives the alternator
a bit more grip. And for the record I ended up buying an
alternator for a '99 Cavalier 2.4L as it came close to
bolting up to the 3500 alt bracket and was only $55
(we'll see how long it lasts though). The two bolt holes
on the side line up and the through bolt is a bit off but
I think it will be fine for now. On my LT1 in my other
car my A/C delete pulley is only held on by 2/3 bolts as
well and it's held up fine. I did have to switch the
pulley to one from an '01 Malibu though because the 2.4
Cavalier pulley was for a 5-rib belt. I still need to
get a pigtail for the alternator. Anyways that's the end
of my rant.
CFoss: If I'm gonna be borrowing your tuning equipment we
should probably meet up some time. What part of Duncan
do you live in?
Date Posted: 26 February 2012 at 10:47pm
Looking really good.
Date Posted: 27 February 2012 at 9:33am
When you're ready, I'm near Queen of Angels school, towards Maple Bay on Tzouhalem road.
When do you think you'll need it?
Do you want me to see if I have a prom that'll work after you're done tuning? I think I have some EEproms (fast rewritable) around here somewhere.
I'm jealous of your serpentine belt. I hate the slippage on the old v belts!
Date Posted: 27 February 2012 at 6:55pm
A few more things done. Pretty much all the wiring is
finished except for wiring in the new alternator but I'm
gonna wait till tomorrow because it's really cold
outside. I also threw some paint on the parts of the
cradle starting to rust. My G1 adapter also came in the
mail today and I got a knock sensor for $11 from
Maxwell's and an alternator pigtail for free from
Blacky's.
school, towards Maple Bay on Tzouhalem road.When do you
think you'll need it?Do you want me to see if I have a
somewhere. I'm jealous of your serpentine belt. I hate
the slippage on the old v belts!Chay
I hate V-belts just as much as you do :P
I ordered a couple of chips with the G1 so I think that's
covered. The car is parked in Cowichan Bay near the
building called the 'Old Firehall' so if you want to come
see the car let me know.
Date Posted: 27 February 2012 at 8:02pm
I was also thinking since I don't know yet how my exhaust
is going to be routed and (correct me if I'm wrong) the
7730 ECM only supports 1 O2 sensor, I would use the
existing O2 bungs and tune 1 bank at a time. To simplify
switching between O2 sensors I would build an extension
harness to reach around to the O2 sensor on the opposite
side. I just don't know yet how the Y-pipe will be
routed/if I will have a Y-pipe.
Date Posted: 27 February 2012 at 9:48pm
Oh and I'll be ready to start the engine probably in a
little under two weeks. I'd be ready to start earlier but
at the moment I'm low on funds so can't spend anything on
exhaust manifold gaskets or fuel injection line or other
misc. items. For the coolant hoses I'm going to see if any
of my L98 hoses fit at all since I have no use for them
since I swapped the engine in my Firebird (they're brand
new blue Goodyear hoses). I am hoping to get the engine in
the car tomorrow.
Date Posted: 28 February 2012 at 8:42am
Right on!
My parents live off of Payne Rd. (About 2 minutes from the old firehall) so I do know what you're talking about!
The 7730 does only support 1 02. I suspect that both banks will perform about the same, so there will be no need to switch back and forth. You may want to do it just to check everything is similar. You are using batch fire anyway, so you can't tune the sides independently.
" I just don't know yet how the Y-pipe will be
Does this mean you're considering a dual exhaust?
Date Posted: 29 February 2012 at 6:02pm
CFoss wrote:
Right on!
" I just don't know yet how the Y-pipe will be routed/if I will have a Y-pipe. "
Yes I am considering a dual exhaust. Is it just me being crazy or does it simplify things? I'm thinking a pipe coming down from each manifold, turning towards opposite sides of the car and just glasspack mufflers straight out to the rear. (Which might sound like crap I guess but I can deal with annoying exhaust until I can afford something better)
Throttle body adapter plate arrived today, so I bolted that up. It seems like no-one makes gaskets for the 3.5 throttle body (stock is an o-ring), so I just used black gasket maker to seal it up and I'm thinking that will be fine for a while. I guess I could get some of that generic gasket paper and cut it out myself but I don't really think it's necessary for now. I guess I'll find out soon anyway though.
I think the wiring is to the point where I can't really go any further until the engine is in the car. It's pretty much all routed where I want it and ready to be loomed, I just have to figure out the alternator wiring and add the 7730 ECM grounds (which I'll probably do once the engine is in the car.
I was planning on getting the engine in on my days off (Monday and Tuesday), but it's been super cold out so I decided to hold off. In any case I got 3/4 aluminium cradle bushings installed. Those front ones seem super tight compared to the rears but they're doable. I threw some anti-sieze on them so that there's a possibility of removing them in the future.
I'll upload some more pics soon.
Date Posted: 01 March 2012 at 8:44am
I don't think you are crazy, but I don't think there is any performance enhancement. The wye pipe can be kinda hard to build if you don't have the tools to do it.
I did some 'inside work' on my car the last few days. Kinda cold and still dark by 6 or so.
I'm going to use a single 2.5 or 3" glasspack on my car. I don't really care how it sounds though, just how it goes! I'll have the turbo in the way consuming some noise too.
The gasket maker will make a mess if you have to remove the throttle body. I've used the generic in the past with lots of success.
I actually have some hanging around if you need it.
Date Posted: 01 March 2012 at 9:56pm
So today I believe I've finished up the wiring except for
the two remaining ECM grounds. I'm hoping the way I
wired the alternator is correct but I'll find out soon
enough. I wired the "Alternator field duty cycle signal"
wire to the brown wire on the Fiero harness, which as far
as I can tell goes to the warning light in the dash, and
the "Alternator output - Regulator reference voltage"
wire to the red wire on the Fiero harness that connects
to the large wire going to the charging post. I left the
"Fuse output - battery" wire alone because the other 99
Cavalier wiring diagram I used didn't even mention that
wire.
This is the method I used to get my front solid cradle
bushings installed:
I stripped two or three bolts using this method but I
eventually got them both in.
This is a comparison of the 2.8 manifolds and the 3.5
manifolds:
And some other random pics:
G1 adapter:
Throttle body adapter:
O2 sensor that came with the motor. Looks in much better
shape than the O2 sensor I pulled out of the 2.8's
exhaust:
Wiring finished:
And everything draped over the engine ready to be
installed:
Edit to add my todo list to complete the project:
- Install cradle in car and finally get the car back on
the ground!
- Fuel lines. I need something to attach the quick-
disconnect side of the vette fuel filter to either fuel
injection hose or one of the stock hard lines. The 'in'
side and return line can just be attached with rubber
fuel injection hose I think.
- Fill engine with oil... any recommendations?
- Fill engine with coolant... any suggestions on getting
all the air out? I was thinking just raising the front
of the car high enough that it's the highest point in the
system.
- Get an exhaust gasket and install rear exhaust
manifold
- Hook up my fuel pressure gauge so I can monitor the
fuel pressure when trying to start the engine
- Wire in two more ECM grounds
- Start the engine and troubleshoot when it doesn't
start!
- Tune
- Missing anything?
I'm thinking of buying a base tune from Superdave on the
60degreev6 forum. It will cost $50 but should get me to
the point where I'll only really need to dial in the tune
to my specific needs. Otherwise I'll be starting out
with a 3.1 tune. My friend said I could borrow his AEM
wideband so that should work out. Since I have an O2
bung in each manifold I can run the ECM off one and have
the wideband in the other.
Date Posted: 02 March 2012 at 9:38am
If there is a starting tune it's always nice to have, that's for sure. It'll save you a bunch of time.
I like the zif socket on the G1. Mine's an old press socket, the zifs are much nicer for repeated connections.
1 thing I did do was sharpie the code revision and type ($whatever) on the ecm so I woudn't forget what I have in there. I just checked that out so I was glad it was there. Amazing what you forget over a year!
Oil...there's a way to start a flame war! I always ask if anyone has ever worn an engine out. I haven't yet and I've really tried (I went broke trying to finish off my old Ford 351...just wouldn't die, had to sell it).
I was looking at some braided fuel line you can attach tips to so you can custom it up (Summit racing).
Something like this:
http://www.summitracing.com/search/Part-Type/Fuel-System-Plu mbing-Kits/?keyword=braided+fuel+line
I haven't quite got there though.
Date Posted: 02 March 2012 at 9:40am
Check this out too:
http://www.jegs.com/c/Fittings-Hose/181705/10002/-1?gclid=CJ Kn44nhyK4CFQV_hwodSRdsBg
Date Posted: 02 March 2012 at 10:58pm
time.I like the zif socket on the G1. Mine's an old press
connections.1 thing I did do was sharpie the code
year!Oil...there's a way to start a flame war! I always
my old Ford 351...just wouldn't die, had to sell it).I
to so you can custom it up (Summit racing).Something like
this: http://www.summitracing.com/search/Part-Type/Fuel-
System-Plu mbing-Kits/?keyword=braided+fuel+line I
haven't quite got there though. Chay
Thanks for the tips on the fuel lines. I might see if I
can find something at a junkyard too that will fit. It
looks like the G6 calls for a 5w-30 oil. Not sure if
I'll go synthetic or not.
I test-fitted some radiator hoses today and I think I can
make the ones I already have work. Here are the hoses:
They're for an 87-92 IIRC F-body and they're Goodyear
Super Hi-Miler hoses. They came with my Firebird I
bought last year and have no use for them in that car but
it looks like they just might fit a 3.5L in a Fiero.
I'm thinking this one will work if I snip it where my
hand is (passenger's side):
And this one might work without trimming on the driver's
side:
I do have questions about the heater core lines though.
I see there are two on the fiero. This one on the trunk
side below the dog-bone:
which actually seems to just come out to beside this one
on the firewall side:
Which one is supply and which one is return?
I should probably replace the battery tray soon...
And my driver's side hinge is damaged:
You can see where the metal cable has come out of it's
clamp and there's nothing to prevent the hinge from
lifting futher. Does the hinge need to be replaced? If
so I'm thinking I might just remove it and install a
strut on that side instead.
Date Posted: 06 March 2012 at 12:02am
Engine was installed today. Good news is that the rad
hoses I have will work with the new engine. I did find
that there is hardly any room for the shifter cables but
they fit, and I found that the clutch is now very soft.
So I guess the slave needs to be bled. Also got some
things to try out with the fuel system and hooked up my
fuel pressure gauge. I'll need a vacuum line for the
brake booster to come around to the front of the engine
from the rear. The alternator was hitting the stock
dogbone mount so I had to grind off some of it to get the
engine in. I think I'll be cutting it off completely in
the end since I didn't really trim enough of it off and
it will probably knock when the engine rocks.
Pics to come soon
Date Posted: 06 March 2012 at 10:49am
The heater core doesn't really have an in and out I don't think.
Date Posted: 06 March 2012 at 8:34pm
So I started attaching a few more things today. Got most
of the coolant hoses hooked up, hooked up a brake booster
line, put my air cleaner assembly back in place, etc...
Here are the pics:
At this point the cradle was nearly lined up. Btw
instead of spending time building a rolling dolly for the
cradle, I just had the cradle on the lift legs and
dropped the car onto the cradle. Lining it up was
difficult at first but mostly because the alternator was
hitting the factory dogbone mount. After removing the
alternator it practically lined itself up.
And a couple pics of the engine finally installed in the
car:
Put the brakes back on today:
This is a pic of where I had to clearance the dogbone
mount. I'll most likely end up taking the rest off as
when the engine rocks I can see it making a horrible
knocking sound...
For the brake booster line I used some rubber hose that
used to be attached to the charcoal canister in my
Firebird and hooked that up to the 2.8's booster hard
line, which ended up going to the rubber line on the
firewall side. A red circle shows where the hard line
attaches. Looks decently clean to me:
Some pics of the rad hoses:
A couple of inches had to be trimmed off this one,
otherwise it's a perfect fit:
The flared end needed to be trimmed off this one:
And the last one was a perfect fit with no trimming:
For the other heater core line I plan on putting in a
place to fill the coolant from the engine bay (red circle
in closeup of engine in car).
I found an EVAP solenoid that came on my LT1. Anyone
know if it will work with a 7730 ECM?
And for the intake I grabbed a 6" piece of 3" pipe from
Canadian Tire and I'm thinking if I get a 45* coupler it
will work out:
Date Posted: 12 March 2012 at 12:58am
So a few updates for tonight. First off, I finished
installing everything and was able to get the engine
cranking but it's not firing. I believe it's not getting
fuel. More on that later.
For the fuel system, I got 4 (3 x 3/8, 1 x 5/16) Dorman
quick disconnect adapters and 4 ft. of fuel injection
hose and clamped everything down. Fuel pressure builds
and holds at about 55 psi and there have been no leaks.
I also added a ground wire for the fuel filter since it's
zip-tied in place and it has a ground strap on it that's
designed to ground static developed by fuel flowing
through the filter.
Pic of the G1 adapter installed in the ECM:
Is it just me or is there more room in front of the
engine with this motor?
Pic of the firewall side of the engine from underneath:
Finished my EGR block-off plate today. Used a piece of
scrap metal that used to do something to hold on the
inner bumper on my Firebird. It's not a work of art but
it gets the job done. For the EVAP solenoid block-off I
was able to use an LT1 manifold EGR block-off plate.
For the intake I was able to get a 45* coupler from Super
Street Imports in Victoria for $20. It fits pretty
nicely although I had to heat it up to slip it over the
air cleaner (3"):
In the next pic you can see my engine-side coolant
filler. $6.50 at Canadian Tire (supposed to be used to
flush cooling system with a garden hose). Filling was a
slow process but I do believe it works:
And finally a pic of the engine just about ready to be
started:
For grounds I used the factory ground strap and added
another 4 gauge ground strap. I'm using the stock
battery cables.
Now on to the starting problems. First thing I did when
it didn't fire was a compression test/test for spark
plugs firing. I did a compression test on the rear 3
cylinders and they read 200, 190, and 200; good
compression in my opinion. At the same time I found that
all 6 cylinders are getting spark (since each coil sparks
a plug on each bank, it should only be necessary to check
3 cylinders to verify spark on all 6). Since I'm not
even getting the odd fire happening at all, I'm convinced
the issue is fuel related.
My friend had the idea that since the regulator is near
the tank there could be a lot of air in the system. We
then bled all the air out of the system by opening the
schrader valve and re-priming. I did find that after
'bleeding' the fuel rail, my gauge indicated that it was
priming much faster than before (not having to compress
air I guess). However that didn't change anything.
As for wiring, I did a basic test to see if the injector
harness was getting a signal to fire. I was reading
about 12V at the injector power wire and during cranking
I saw fluctuating readings at the ECM ground(?) wires.
Someone please correct me if I'm wrong but to me this
indicates the injectors are getting a signal to fire.
Another possibility I suppose is that the tune I'm trying
to use (91 3.1L J-body) isn't giving it sufficient fuel
to start the engine. There seems to be no fuel exiting
the exhaust manifolds.
One thing that seemed strange to me is that I can't get
any data to come through the ALDL port (using my ALDL
cable). Is it possible to get data to come through while
using the emulator? In tunerpro RT it just says "DA:
Connecting" when I'm trying to get a datastream. I've
already verified that this cable works on my friend's 93
Sonoma. Oh and I also tried to jumper the A and B pins
on the connector but that didn't cause the check engine
light to flash. However, the check engine light DOES
light up with key on, engine off as it should. That
indicates that the ECM is at least partially working, I
think. I'm just thinking if I could get a datastream
that it will help determine if the sensors are getting
proper readings and it could also help to indicate any
wiring issues.
Anyways that's where I've left it for tonight, hopefully
tomorrow with a fresh perspective I can make some more
progress.
Date Posted: 12 March 2012 at 9:00am
Can you hear the injectors clicking? IF you have an automotive stethescope and can get to the injectors, use it and the injector clicking should be easily audible.
When you say the injector power wire, you mean the one going from the injector to the ecm right (Not the solid +12 one)? If so, you are correct, the wire should go to ground to fire the injector so what you saw is a good thing. I have a handheld scope we can hook up to further analyze this if you want. That way you can actually see the duty cycle, and period of the injector shot.
I don't remember the '7730 needing a-b. It does require a 2 transistor type cable though, where some of the older ecm only require the 1 transistor type. This could be your issue. I can build you one if you want. The one I have is in use on my boat at the moment. I have found Tunerpro to be more finiky than winaldl, but for the '7730 winaldl won't work (too fast).
Search on 3rd gen for some alternative programs that are stand alone. I know I saw some, but I got the tunerpro working.
How did you make out with finding an wideband o2 sensor? I just ordered one which does logging (Zeitronix ZT-2) after I got my last one wet (It died a sad sad death). I'd highly recommed something like it, especially for power enrich settings. I found that I didn't really tune with the ecm, I used the wideband mainly.
It is still good to nail down the blm's with a good tune though, so you need it, but it's a little less important.
Date Posted: 12 March 2012 at 12:21pm
easily audible. |
I haven't listened for the injectors and don't have an
shot. |
I've tested both wires (to make sure it's getting
constant power as well)
tunerpro working. |
The cable I'm using has been known to work with a 7730.
It's from aldlcable.com I've also tried using Freescan
to get data as that's what I use with my other car. Did
I also mention that the fan always turns on with the key
in the on position?
mainly.
important.
Chay |
I can borrow a wideband from a friend but haven't done so
yet.
Date Posted: 12 March 2012 at 6:52pm
Did some more testing today and it looks like all but one
of my injectors are stuck. They don't look dirty but I
guess after sitting for a few years they've just gotten
stuck. I can get the #5 injector to fire by manually
jumping it with a 9V battery but the rest of the
injectors aren't opening at all.
Another issue is that with the fuel rail out and the
engine cranking, it doesn't look like it's firing #5
anyway. It may be computer related because I still can't
get a datastream after trying a couple different code
masks. I also double checked the pinouts on the ECM
connectors and they all appear fine. It doesn't seem
normal that the fan always runs with the key in the on
position either.
Tomorrow I'll take the injectors up to Action Fuel
Injection in Nanaimo and hopefully they can get them
cleaned for a reasonable price.
Date Posted: 16 March 2012 at 12:05am
Ok so did a little research and it looks like I need to set
my codemask to $AA to disable the checksum checking during
emulation. It seems that by not disabling the checksum, it
could be putting the ECM into limp home mode which is why
the fan turns on with the key in the on position (always
happens AFTER the fuel pump primes too). Apparently this
can also prevent data from coming through the ALDL port.
Also, my fuel injectors are supposed to be ready to pick up
tomorrow, so I'll be grabbing them as well. Hopefully all
goes well.
Date Posted: 19 March 2012 at 10:23pm
Got the engine running today and took the car for a couple
spins around the block. Pics and vid to come soon!
Date Posted: 20 March 2012 at 12:06am
So injectors were the main problem, also my chip adapter
wasn't pushed in all the way... . Anyways, after the
cleaned injectors were installed and I loaded a 3.1L tune
into the emulator, it started up first try! After that we
took the car off jack stands and took it for a spin around
the block a few times. Feels so good to finally drive it!
And here's the video:
http://youtu.be/x-Sg8IZc5p0 - LX9 Start-up
Date Posted: 20 March 2012 at 3:55pm
Congrats!
Sounds good with no exhaust!
Nice vid, especially like the 'he's got no liscence on that thing' at the end. Classic.
Date Posted: 31 March 2012 at 5:13pm
Exhuast will be done on Monday or Tuesday and I'm gonna put
plates on it soon after and really begin to dial in the
tune. I decided to get a y-pipe made at Mill Bay Muffler
to keep things fairly inexpensive (using the stock muffler
and tips) and they're gonna weld up my cradle nut and
battery tray as well. If I want a better exhaust later I
can always upgrade to a better stock-style muffler.
How much longer till your turbo build is done Chay?
Date Posted: 01 April 2012 at 11:15am
It'll be a while yet. I'm working on the exhaust right now...lots of tricky fab work because the 2.5" mian exhuast and 2' wastegate tubing has to come together at some strange angle. You have at least a couple of weeks, probably more like a month...no rush!
Date Posted: 05 April 2012 at 7:57am
Put plates on the car yesterday after getting the exhaust done and having a battery tray made. The car is much quiter now but still sounds really good IMO. The tune is fairly close now at least with part throttle driving; just running a little on the rich side now. So far no problems with knock retard so I might play a little with timing advance as well. I'll probably get a video of the final exhaust sound later.
Date Posted: 05 April 2012 at 10:44pm
That thing is going to kiss ass!
Date Posted: 06 April 2012 at 8:08am
Thanks! Gas mileage doesn't seem to be too terrible right now so that's a good sign. I was worried at first about how bad the 4 speed manual would be. I think it probably helps that the torque peak of this engine is relatively high compared to the 2.8 (4800 rpm IIRC), so it should in theory be more efficient at mid-high rpms. Once I enable lean highway cruising in the tune it should get even better.
Only issue right now is that it's been stalling once warmed up but I think I figured that out so I'll find out later today. I think it tries to go into single fire mode when idling and that's causing the stalling. Disabling single fire mode will hopefully solve the problem.
Oh and since I still don't have an upper dog-bone mount I'm driving pretty conservatively right now. Hopefully I'll be addressing that on Monday.
Date Posted: 06 April 2012 at 6:03pm
Disabling single-fire in the tune made the idle problem go
away. VE maps are also just about done. Not too much
left!
Date Posted: 07 April 2012 at 6:09pm
Tuning is just about done. I'll probably set up a nAst1
tune and a regular A1 tune just because the nAst1 has a few
glitches here and there. It's great for tuning with
though.
This engine is just begging for a 5 speed swap! Maybe I'll
get around to that by late summertime.
------------- '86 2m6 F23 5-speed, LSD, 3.5L LX9
'89 Firebird 3500T, T56
Date Posted: 21 April 2012 at 12:59pm
So tuning is pretty much finished. Also had to replace and require my
alternator recently. And I now have a dog bone mount. I'm planning on
going to the 1/8 mile drags at western speedway tomorrow so we'll see
how that works out.
Date Posted: 22 April 2012 at 9:38pm
Had some good fun at the SISLA event today. Best time
ended up being a 6.489 @ 62.27 MPH. Didn't break any
transmission mounts and did some light burnouts. Wow
it's really easy to get a good launch with these cars.
With some better tires I could probably shave another
1/10 of a second away. I thought it was pretty awesome
beating most of the V8s in street class and also having
one of the most quiet cars there. It's a 384-foot track.
On the other hand a brand new Shelby GT500 crashed on its
first run...
And I snapped a pic of my dog-bone mount and the car with
the stock wheels now painted satin black:
Date Posted: 22 April 2012 at 10:36pm
Your times seem really odd to me. I went back and checked some of my old time slips from when I was running a strung out V6 (2.8 with mods) My best 1/8 mile with 9.4 at 75mph. (3 seconds slower but 10mph faster) which does not make any sense to me? I was racing against a Turbo Miata at the time in my now deceased 85GT with a 4spd trans. I was car 3641 with a 14.6 quarter mile.
Scan of my slip is here, http://www.captfiero.com/missiontime.JPG - http://www.captfiero.com/missiontime.JPG
Date Posted: 22 April 2012 at 10:38pm
Yes it's not an 1/8 mile track it's a 384 foot track.
Sorry for the confusion.
Date Posted: 22 April 2012 at 10:40pm
14.6 quarter mile.
To compare, my best 330-foot time was 5.711
Date Posted: 22 April 2012 at 11:12pm
To get a 5.7 330 you were cooking along really well. I am impressed.
Date Posted: 08 May 2012 at 11:09pm
Just added some more videos today:
http://www.youtube.com/watch?v=t2en4b4MX-s - LX9
Autocross Run
http://www.youtube.com/watch?v=qURrkcbCryE - Fiero vs.
4.6L Mustang
http://www.youtube.com/watch?v=xtN4YeRAxW4 - Fiero vs.
Dodge Magnum
Date Posted: 09 May 2012 at 9:42am
Very cool. Lotsa fun! Engine sounds good!
Posted By: 88 Addict
Date Posted: 11 May 2012 at 3:09pm
Looks like good work on a budget. Don't think I could get results like that for what you have spent. Let me know when you are ready to do your 5 speed swap. I have a 282 from a cavalier that I spit the case on to replace the speedomiter drive gear and left sitting in the garage till I moved back to the Island. It is sitting in the basement looking for someone finish putting it back together. Would be interested in getting your 4 speed shifter for my current project which is an f40 6 speed swap. PM me the next time you plan to come through Mill Bay and have the time for coffee.
------------- So many Fiero's, So little time.
Date Posted: 11 May 2012 at 9:41pm
I LOVE the sound of this engine. It's funny my friend
was the one driving it mostly at the track on Sunday and
he wouldn't stop revving the engine every chance he got.
Too funny.
The heater core blew Sunday morning but we just did a
quick bypass so it could still go to the track. I drove
my Firebird at autocross and the Fiero beat me by about
1/10 of a second. The hairpin turns really killed me; it
just doesn't have as much steering angle and I couldn't
make up for it with just the stiff suspension. I decided
not to drag my Firebird because my oil pressure was
dropping when coming to a stop (probably oil pump pick-up
fell off oil pump and needs to be welded on).
Date Posted: 19 May 2012 at 7:21pm
Just finished painting most of the trim satin black.
It's finally starting to not look like a piece of garbage
on the outside haha.
I'm also posting a few pictures of what it looked like
when I bought it:
And now:
Date Posted: 19 May 2012 at 11:15pm
The car looks great. However my personal taste I would have prefered the red/black look. Don't get me wrong you did amazing work and paint quality looks great. Just not a fan of Green/Black as a colour scheme on a Fiero. Although I have never seen your engine swap in person, it looks to also be top notch and the performance numbers you have posted speak for themselfs.
Date Posted: 31 July 2012 at 6:36pm
Going to Thunder in the Valley 2012. Can't wait to see
some 1/4 mile times and probably going to use a 75 shot of
N2O.
Date Posted: 12 August 2012 at 6:49pm
Fiero really surprised me (and everyone else) by running a
13.686 @ 102.68 MPH!!! My friend was driving it for me (I
was driving Firebird) and got a GoPro video of it racing an
LS1 WS6 Trans Am which I will hopefully post soon. That
time really surprised me as I was hoping for a best of
13.9.
We ran the 75 shot of nitrous in 2nd, 3rd, and 4th.
Date Posted: 29 December 2012 at 10:28pm
Wow I completely forgot to post the vid!
http://www.youtube.com/watch?v=W4bYR0-qSpQ - Here it
is
Car is still running great 25,000 kms later but needs a
new
muffler. My turbo Firebird project is nearing completion
and the Fiero will get attention after that is driveable.
:D
Date Posted: 08 July 2013 at 6:34pm
Getting this ready for the Port Alberni drags again; just
pulled the engine out the other day for a max-effort N/A
cam, 8 lb aluminum flywheel, 6-puck ACT clutch, and F23 5-
speed w/LSD. I'm also redoing the fuel system with a
returnless rail and 28# trailblazer injectors, and tidying
things up a bit more. Probably gonna set up the N2O on a
WOT switch this year as well.
Date Posted: 11 July 2013 at 3:52am
Got the cam in and installed the new flywheel/clutch.
Also started porting the manifolds. Transmission should
be re-assembled by the weekend.
Despite the 35,000 kms of driving since the swap, the
motor still looks brand new inside :).
Anyone need a 4-speed? I also have a reinforced stock
rear trans mount if anyone wants it. It originally broke
into 3 pieces so we welded it back together with some
1/4" steel pieces to reinforce it. It held really well.
Date Posted: 12 July 2013 at 7:28pm
4spd trans?...
Good work by the way, looking good
------------- Brian (Bassman)
Date Posted: 13 July 2013 at 1:57am
I actually forgot to post this, but in January the stock
3500 dynoed at 205 whp and 250 ft-lbs wtq. I was really
impressed with those numbers. That's stock manifolds,
stock Fiero air cleaner, untouched engine.
Ya, since I'm installing an LSD'd F23 I should no longer
need the 4-speed manual anymore.
I actually got the cam/valvespring/pushrods for a steal
at $180 shipped because it's the same seller I bought the
3500 turbo manifolds off of for my Firebird.
And after I finish this last round of upgrades I'm
seriously considering selling the car. Kinda wanna
replace it with an Audi A4. This cam won't be as good on
gas as stock but should be plenty fun at the same time.
Supposed to be good for power to/past 7000 rpm and on an
otherwise stock 3400 was expected to make 245 whp. On a
3500 it should make a bit more.
Specs:
Intake 230 .578" lift
Exhaust 236 .573" lift
LCL 110
LSA 112
Oh and rear control arms are getting poly bushings now.
I'll probably do the fronts later as they really should
be done.
Date Posted: 05 August 2013 at 1:42am
Finished up the minor porting to the intakes
Put the trans back together now with a rebuilt OBX. My
first time shimming a trans so hopefully this works out
ok.
Did some major wiring cleanup; changed the routing of a
lot of wires and grouped everything together a lot better
than last time. Integrated the nitrous system wiring as
well. Also swapped to a 3400 returnless fuel rail with
28# trailblazer injectors and drilled/tapped the rear
valve cover so I could properly install a breather on it.
Mounted the transmission with Fieroflyer from fiero.nl's
mounts. The mounts are nice and beefy and they work, but
quality could be better. For example some of the
bolt holes needed to be spaced away with washers to make
the other bolt holes line up. Rear side mount had to be
pried a little to get all the bolts started. The nice
thing at least is that after the mounts were installed,
they lined up perfectly with my poly trans mounts.
Had to do a minor notch to the cradle here to clear the
transmission since the mounts were designed for an 88
cradle. Pic also shows poly control arm bushings now
intalled.
Ready to go in the car
Once in the car, I relocated the coolant filler to the
other heater core line to make for a cleaner look. Also,
the heater core line that comes from the front side of
the engine, and routes all the way to the rear, was cut
at the front side right after a weld bead (so that a hose
clamp cannot slip off) so that the line has a much
shorter route.
For the F23 clutch line, I had Island Hose silver solder
a -4 male AN fitting onto the F23 bleeder, and then I cut
the end off the stock braided steel line and installed a
-4 Russell Powerflex hose end. The olive in the hose end
needed to be slightly drilled out due to the Fiero line
being slightly larger than -4 (I'm assuming it's a metric
size). Clutch bled very easily compared to stock and
clutch is disengaging properly. Pedal has a much lighter
feel to it now despite the same pressure plate being
used.
Posted By: bcampbell
Date Posted: 05 November 2013 at 12:51am
So it's probably time to update the build... Drag racing
didn't go as planned :). Had issues with the shifter all
weekend and the shift cable ended up breaking on one of
the runs. It was actually the best run of the weekend
and ran a 15.x with only 1st and 2nd gear :). Which I
think is pretty decent considering that was NO nitrous
this time and it didn't get a chance to wind out 3rd and
4th gear. Shifting was around 6300 rpm or so as I have
the rev limiter set very conservatively right now.
Powerband of this cam goes past 7000 but I'm nervous to
go that high as the last motor this cam was in left valve
marks on the pistons . That may or may not be
because the timing chain was old and stretched though.
Anyways, after TITV the car mostly sat waiting for parts
for a couple months. Ordered a set of new cables from
California Push-Pull, front poly a-arm bushings, front
poly sway bar end links, front ball joints, and installed
rear coilovers as well. I'm also doing a GT conversion
to it with the next week and painting it again. This time
midnight blue.
Front suspension rebuild has been a HUGE pain. 3 Of the
6 control arm bolts were seized to the bushing sleeves
and the lower ball joints took hours of pressing,
torching, beating, etc... to remove. Oh and two of the
steering rack bolts broke when I went to remove them.
Fun.
After the front suspension rebuild is over with and the
body panels go back on, I still have a couple more things
to do before I put the car up for sale. Rear struts will
be changed out for KYBs, another motor mount will be
added (possibly two if that's not enough), a second
muffler will be added (current exhaust is LOUD... one of
the loudest street cars I've heard... my friend's cammed
LM7-swapped S13 isn't even as loud when straight piped
with NO muffler), and the starter needs to be replaced
since it's pretty much done for.
Pic of how it's sitting now
And of course a vid of the glorious cammed V6 noises
http://youtu.be/kpztfwp6rNE - Cammed 3500 Fiero
It's idling at 1300 right now but with more tuning it
should hold 1000 ok. This cam is much more aggressive
than the one I have in my Firebird right now. I think
I'm going to try to get this back on the dyno before it
sells. It should make at least 250 whp if not more based
on simple math and the dyno with the stock cam; stock cam
made 250 ft-lbs of torque and if this cam torque peaks at
over 5252 rpm then it will make 250 hp and likely more.
Date Posted: 15 December 2013 at 1:23am
So car is finally ready to go back on the road... almost.
Just needs an alignment really.
Poly bushed the front end... BTW, I discovered that Moog
poly end links actually appear to be MUCH higher quality
than anything offered by energy suspension. And I got
them for $6/side on rockauto. I would highly recommend
them to anyone going to poly end links. I also replaced
both lower front ball joints since it was time they be
done.
Installed all newly painted body panels
Exhaust has now been re-done and is much nicer than
before. I was surprised how quiet it is vs. before but I
do effectively have two mufflers now. I bought a
Dynomax/Walker turbo muffler from Lordco for $26 and re-
used the glasspack as a tip. Had to do a pie-cut to make
the connection from y-pipe to muffler as space sure is
tight back there. The whole system is effectively one
piece but can be removed by removing the sway bar and un-
hooking the right side e-brake cable.
Discovered a broken transmission mount while changing the
starter (upgraded to one from an 00+ Sunfire 2.2L engine
which is smaller/lighter/faster). That's now the 4th
mount I've broken on this car :). Dog-bone twice, rear
trans mount bracket once (stock 4-speed metal bracket
into 3 pieces), and now this one.
Fortunately Rodney's poly mounts use readily available
poly bushings that only cost $20 to replace from Lordco.
It was changed relatively painlessly.
Other things that were changed include coilovers in the
rear using KYBs and 325# 12" springs, new shift cable
from California push-pull, Grant steering wheel, and a
new cold-air-intake using a K&N filter in front of the
wheel well.
Tuning has been improving as well. It now idles nicely
at 900-950 rpm and has a really nice lope. Here's a
video showing the new exhaust.
http://youtu.be/kzOW1AEG6qw - Cammed 3500 Fiero
Took it out for a quick spin after the video and although
the alignment is way off, it seems to handle much nicer
than before. Dampening is a bit soft for my liking but
is still firm enough for good performance.
I think before it goes back on the road it will be
getting some solid motor mounts. I'm just not satisfied
with the engine movement yet.
Date Posted: 18 December 2013 at 1:33pm
Alright did up a couple solid mounts last night.
This one is on the front side of the engine, and uses
pieces of that shock-type mount that is used with the
stock 2.8. It bolts to two holes on the engine block and
one on the oil pan.
The other one I don't have a picture of but I just went
from the alternator bracket to what's left of the stock
dog-bone mount location on the trunk side. It's a little
tricky to install and less beefy but should compliment
the one on the front side and the dog-bone (which is
solid).
Date Posted: 17 January 2014 at 12:24am
Well after getting everything else sorted out, I guess it
was time to focus again on the engine. I had this
problem where every time I would run the engine (after
filling the coolant), air would get in the cooling system
and it would overheat. I thought for sure it was a head
gasket problem after doing a compression test and finding
one cylinder low, but this is what I found.
Head gaskets were both fine but the exhaust valves had
all been hitting the pistons. Cam is just too big for
the stock pistons I guess :). According to the machine
shop down the road the coolant issue is most likely being
caused by a cracked head.
Well, my pistons were already all dented so I decided to
go ahead and attempt cutting my own valve reliefs. I
finished one side of the block today and it was actually
pretty easy. Just put sandpaper on the bottom of the
valve, popped it in the head, bolted the head down with
two bolts, put the valve in a drill chuck, feeler gauge
between the valve seal and chuck to accurately notch the
pistons evenly, and drilled until the drill hit the seal.
Plan is to finish the other side of the block, put on a
new set of heads and see what happens :). If it goes
horribly wrong I'll most likely replace the engine and
put in a milder cam.
Date Posted: 21 January 2014 at 8:30pm
BTW here is a pic of the decklid notch to clear the FWD
alternator. Very minor.
Date Posted: 01 February 2014 at 10:57pm
Got the motor back together and it's running well. Turns
out that the overheating problem was most likely a
blockage or air lock, since after getting the motor back
together it was still wanting to overheat. Flushing the
system with a garden hose solved the problem.
Pulled the heads off of my Firebird (which blew the head
gaskets in October) to use on the Fiero and cleaned them
up:
And re-assembled the top end
Also installed a surge tank from a G6 to make filling the
coolant easier and put a 20 psi cap on the rad
And finally I test fit some STI RA seats
http://www.youtube.com/watch?v=8clDxSawSpE - Startup
video
Date Posted: 02 February 2014 at 9:13pm
That's a nice wicked sound
------------- Johnny-B-Good
Date Posted: 02 February 2014 at 9:37pm
bcampbell wrote:
Well, my pistons were already all dented so I decided to go ahead and attempt cutting my own valve reliefs. I finished one side of the block today and it was actually pretty easy. Just put sandpaper on the bottom of the valve, popped it in the head, bolted the head down with two bolts, put the valve in a drill chuck, feeler gauge between the valve seal and chuck to accurately notch the pistons evenly, and drilled until the drill hit the seal. |
I appreciate your ingenuity, but I still would've been afraid that different amounts of metal would've been removed from the top of the six pistons... putting the engine out of balance somewhat.
I guess the test will be to see how well the engine runs... and for how long.
Sounds good in your latest video clip.
Date Posted: 03 February 2014 at 8:00am
Well it was either notch the pistons myself, downgrade the cam, or get
a machine shop to do the work. Machine shop would have cost too
much so I chose option #1. Really I didn't take much material off, as the
pistons were aleady dented in those locations, and I would be surprised
if the balance is sufficiently off to cause issues, although it's a
possibility I had considered.
Before doing this I read about guys doing it on LS1s and Ford V8s so
after that I wasn't as nervous.
Worst case scenario I can get another engine for $300 and start over.
