Fiero 1986 V6 GT with T-Top
Category: Buy / Sell
Forum Name: Complete Cars
Forum Description: A Place to sell or buy your Fiero. Please use FS: (for sale) WTD: (wanted) in the title of each post
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2967
Printed Date: 05 April 2025 at 12:55pm Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: Fiero 1986 V6 GT with T-Top
Posted By: fierokit
Subject: Fiero 1986 V6 GT with T-Top
Date Posted: 27 June 2012 at 2:12pm
Fiero 1986 GT Automatic
Have had the car since 2002. Body Kit was installed in
the mid 90's from previous owner.
Selling car as is. You can use it as a parts-car, or if
you're a mechanic can get
the car running again.
The BAD:
- Last time car went on the road was 3yrs ago. Has been
sitting idle parked since then. Because of this the car
probably will need a engine rebuild or engine swap.
- The trunk door lock is broken, as the key was snapped
in half and stuck. Therefore I haven't been able to
access the battery to recharge it and turn it on. May
need to put a 9volt battery to the trunk switch on the
Driver side to pop open the trunk. Will need a locksmith
or method of putting a 9volt battery at the front to pop
open trunk, to this day i cant open it.
- The original issue (when the battery/trunk was
accessable) was that the car would not shift to second or
third gear because the throttle would get stuck, I tried
adding WD-40 but only partially helped. Never fixed the
problem so car stayed on first gear.
- Car will need new paint job. Body kit will need
touching up if you're familiar with fiberglass as parts
have taken their toll.
- Fuel gage will tell you its 50% empty, when in reality
its full, So you have to rely on speedometer to tell you
when it reaches 360Miles to refuel ( i think its 360miles
for the tank last i drove). Otherwise swap the sensor in
the fuel tank and it will fix the problem.
- Quarter glass on driver needs new fiberglass or
replacement on driver side. Been like that since 2002.
- Great as a part-car, or if you have a spare engine to
swap it with or are familiar with engine rebuilds then
the car will run great and only needs new paintjob and
interior cleaning. It may not need an engine rebuild, its
just that I can't figure out why it wont shift to the
next gear, before parking it in 2008 car ran great, then
I didn't insure it for a couple of years and when i tried
running the car again the throttle would get stuck in
HIGH RPMS because it wouldn't jump to the next gear.
The good:
- Airconditioning works
- Originally came with its built-in subwoofer. But i
removed it because the speaker kept blowing. But the
wiring is still there.
- Wheels are good
- Still catches peoples eyes when it ran in late 2000's.
Sale:
Looking to get it off my parking lot make me an offer.
Cheap sale, more importantly I
need it off my parking lot as soon as possible as its
using up space.
Since I can't access the battery to put the car in
reverse, we need to call two-truck to transport it to
final destination.
604-781-4980 or TXT or email
OLD Images (more images):
http://www.fiero.nl/forum/Forum4/HTML/062443.html#p0
- old images
Posted By: fierokit
Date Posted: 30 August 2012 at 1:18am
Got the trunk open, will need a new key lock for trunk
though. Here's a pic of engine. Engine starts, but wont
goto second gear and quickly accelerates to 6000rpm.
Posted By: fierokit
Date Posted: 03 September 2012 at 12:21pm
car still for sale, taking offers need sell it.
604-781-4980
