Universal throttle cable
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3009
Printed Date: 11 March 2025 at 12:40pm
Topic: Universal throttle cable
Posted By: tweeder
Subject: Universal throttle cable
Date Posted: 05 August 2012 at 9:51am
Anyone know of a universal or other throttle cable that I can replace my
stocker with? My engine is a 90 buick electra 3800. The problem I am
having is that the heat in the engine compartment is melting the inner
plastic liner. I was thinking of running it around the engine compartment
and away from the header heat. The headers are wrapped and the
throttle cable insulated and wrapped also, but it still melts. If no way of
going around I could possibly go over the top, but would have to
fabricate something up.
86 GT Convertable 3800
Date Posted: 05 August 2012 at 4:50pm
So I have never heard of any universal kits, but I would suspect you could buy bulk bicycle cable and housing then wrap it, would be a ton of work to solder and fabricate ends but would be the cheapest solution.
