Engine stall???
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3119
Printed Date: 22 November 2024 at 12:01pm
Topic: Engine stall???
Posted By: ryanwmitchell
Subject: Engine stall???
Date Posted: 28 January 2013 at 6:44pm
basicall what is happening is when i am going slow or start from a stop and
give my engine gas it drops almost all the way out and i have had it shut off
completely in traffic, sometimes just when sitting there it stalls. Any idea
what i should try to fix or what is happening its not the O2 sensor i changed
that and i have also tried unplugging my map sensor that didnt change
anything any help would be much appreciated???
Ryan, 86 Fiero GT fastback V6 orange and black
Posted By: ZeroC
Date Posted: 28 January 2013 at 8:57pm
auto or standard
Posted By: bcampbell
Date Posted: 28 January 2013 at 9:09pm
Warm, cold, or both?
'89 Firebird 3500T, T56
Date Posted: 28 January 2013 at 10:10pm
it is an automatic and it does it warm and cold
Posted By: ZeroC
Date Posted: 28 January 2013 at 10:18pm
tcc lock up solenoid
had similar issues unplug it and see it if helps
4 wire plug next to the kickdown cable on the tranny
Date Posted: 28 January 2013 at 10:34pm
   Advance your ignition timing, if you have worn ignition parts, it can make your ignition act like it is retarded and cause an automatic Fiero to stall.
     If the timing helps, then go out and buy a new MSD Cap and Rotor and New Wires and New Plugs, then return your timing to 12 degree's.
     Other issue can be the IAC but you said it does not have the problem all the time, so I would tend to lean towards the car needing a tune up with "GOOD" parts.
Date Posted: 28 January 2013 at 10:35pm
sweet thanks ill give it a try lol can you describe where the kickdown cable
is lol im kinda new to calling parts by there name ive stripped my fiero
down before but dont know the proper names for parts lol i should probs
get on learning them
Date Posted: 28 January 2013 at 10:38pm
Thanks capt i will get the timing adjusted and see if that helps and ive
already replaced 3 of the plugs and wires just working at getting to those
hard to reach back three haha. and i will take a look at my IAC thanks for all
the help!!!!!!!
Posted By: ZeroC
Date Posted: 28 January 2013 at 10:42pm
http://fierodomain.com/articles/repair-articles/44-how-to-re place-the-tcc-trans-lock-up-solenoid
really easy to see if its the problem ...unplug it and go for a drive ...if it still does it then dave may be on to something ( but he is never right )...lol :)
Date Posted: 28 January 2013 at 10:50pm
k ill give it a try once i get my new throttle cable in lol my snapped while
driving so waiting on that from the fiero store but i guess in a couple weeks
ill post back on here and tell how it goes thanks again for all the help!!!!
much appreciated
Date Posted: 29 January 2013 at 8:57pm
Ive got 2 Autos an had the same Problm!
The link ZeroC posted is a good one,pics
a bit crappy but.Dont make the same mistake
i made,an had to pull it apart again ? there are
TWO components in line.  First the lockup solenoid
 then a pressure switch. change them both.a little
tricky getting the pan off-Tight fit- it comes out the
top an there 2 brackits to come off , its about 4Hrs
with your 3/8 craftmans ratchet set,12mm is the
size of the pan bolts i think.Good luck
Date Posted: 30 January 2013 at 10:51am
Thanks for all the the help i am going to check that out in the next few days
prbably i cleaned my iac it had a little bit of carbon on it or dirt and that
seemed to help with the idle to and i pulled and reset codes it says i need a
new map but im going to double check that
Date Posted: 31 January 2013 at 12:35pm
Hey there everyone so i figure either the some sensors are working and
then not working or its my transmission that is brokencause sometimes
when i shift into gear it makes the car move and i get a kick out of it other
times i do not and today when going 30 the engine almost cut out and
stalled so not really sure about my transmission on this thing!
