I wanna build
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3178
Printed Date: 22 November 2024 at 4:36pm
Topic: I wanna build
Posted By: doug6644
Subject: I wanna build
Date Posted: 07 April 2013 at 8:37pm
I own a 2000 Regal with a great running motor, but a junk trans. I have finally decided I can't find a trans for the Regal. Now I have found an 85 Fiero GT, can I do an easy swap with my 3.8 SC into an 85 GT, or will it require a different trans and a bunch of upgrades? Thanks in advance for any info given, I just need to get out from under this darn Regal.
Just need something to wrench on.
Posted By: doug6644
Date Posted: 08 April 2013 at 8:17pm
Did I post in the wrong section? Can anyone point me in the right direction?
Posted By: DannyCanuck
Date Posted: 08 April 2013 at 10:21pm
I think it should just bolt up, it has the same bell
housing pattern.
88 duke, bog standard
Date Posted: 08 April 2013 at 10:45pm
The 3800 will bolt right up to the Fiero trans. You would need to make
or buy a mount for the engine, redo all coolant hoses and fuel lines,
and rewire the engine and either trick the ECM into thinking it is still in
the regal, or have it reprogrammed. You will also need a flywheel from
a camaro 3800.
Not quite a bolt in, but very doable for the mechanically inclined.
Lots more good info on pennocks: www.fiero.com
Date Posted: 08 April 2013 at 10:46pm
Originally posted by doug6644 doug6644 wrote:
...can I do an easy swap with my 3.8 SC into an 85 GT, or will it require a different trans and a bunch of upgrades?
There is a TON of info at http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi?action=intro - Pennock's Fiero Forum  about this type of swap.
Posted By: doug6644
Date Posted: 09 April 2013 at 7:26pm
Sweet....thanks for the info guys.
