85 gt with 5 speed from 86
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3274
Printed Date: 22 November 2024 at 10:33am
Topic: 85 gt with 5 speed from 86
Posted By: dbuck8420
Subject: 85 gt with 5 speed from 86
Date Posted: 15 July 2013 at 3:06pm
i have an 85 gt came with a 4 speed muncie. i put a 5 speed
getrag from an 86 gt, and i am having an issue setting up
the new cables. i did get new cables for the 5 speed, a 5
speed shifter and the brackets for the cables. i am hoping
someone can help me figure out what i am not seeing or
doing right.
Date Posted: 15 July 2013 at 3:19pm
This may be an obvious question, but the shifter cables you got were for a 5-spd getrag tranny, right?
Cables for a 5-spd Isuzu won't work and neither I suspect would cables for a 4-spd getrag.
Date Posted: 15 July 2013 at 3:49pm
Not as obvious as you would think, I started off with Isuzu cables and brackets before I did research and realized what I had and that they wouldn't work. I started off with a pile of parts, including the Isuzu cables and brackets. I did order the getrag cables from the Fiero store. And got the brackets from the Fiero factory.
Date Posted: 15 July 2013 at 4:07pm
I swapped a 5-spd Isuzu into my '84, but I have no experience with 5-spd getrags.
Someone else may be able to better advise you, but you're going to have to at least describe what the issue is that you're having a problem with.
Date Posted: 15 July 2013 at 4:21pm
I can't figure out how the select cable bracket mounts to the transmission
Posted By: Erwin
Date Posted: 15 July 2013 at 5:04pm
I can take a picture of my 87 GT if you want - will that
help?
Date Posted: 15 July 2013 at 5:14pm
Yeah that would be great.
Date Posted: 29 July 2013 at 10:48am
just realized Saturday night that I had been lied to
about the transmission i had put into my fiero. it is a 5
speed, but it is not the Getrag i was made to believe it
was. it is actually the Isuzu 5 speed. i really wish i
had seen this forum a long time ago,
http://www.fiero.nl/forum/Forum2/HTML/063783.html
there are pictures of all 3 transmissions put in the
fieros. so if anyone out there is looking for an Isuzu
trans. let me know, i have 1 laying around that i dont
want. i went and found a getrag 2 hours away, so i
wouldn't have to start over with getting all the brackets
and cables for the isuzu trans.
