2.5 engine
Forum Name: Build Threads
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3372
Printed Date: 03 July 2025 at 3:35pm
Topic: 2.5 engine
Posted By: mechanicair03
Subject: 2.5 engine
Date Posted: 06 December 2013 at 5:36pm
I have a 1986 Fiero SE just had the head checked and it has a crack. I know that the Iron Duke was produced for several Pontiacs and some American Motors cars. What years of the 2.5 will interchange with my SE?
Posted By: DannyCanuck
Date Posted: 06 December 2013 at 6:33pm
87 and up are different i think, and the Vin U engines are
completely differant
88 duke, bog standard
Date Posted: 06 December 2013 at 8:49pm
Copied from the Fiero Interchange Parts page. I hope this comes through with the correct formatting.
As might be expected, the cylinder heads in a Fiero are common to many GM engines. There were many variations so care must be exercised in getting the correct heads.
'84-86 2.5L XJS: The designation "XJS" is stamped on the front face or right rear of the block. The intake valve has 0.3137" diameter stem. The exhaust valve has 0.3132" diameter stem. The push rod length is 8.3".
Pontiac 6000         &n bsp;     '84-86 2.5L Identification XJS on block
Chevy Celebrity        &nb sp;   '84-86 2.5L Identification XJS on block
Buick Century          ;     '84-86 2.5L Identification XJS on block
Olds Ciera         & nbsp;       '84-86 2.5L Identification XJS on block
Chevy Citation        &nbs p;    '84-85 2.5L Identification XJS on block
Olds Omega         & nbsp;         & nbsp;'84 2.5L Identification XJS on block
Pontiac Phoenix          ;      '84 2.5L Identification XJS on block
Buick Skylark          ;     '84-85 2.5L Identification XJS on block
'84-86 2.5L XJS: The designation "XJS" is stamped on the front face or right rear of the block. The following non-XJS heads will interchange if the coolant outlet and positions are switched and the push rods are included. The heads below must have identification number 10020699 or 1552.
Pontiac 6000         &n bsp;     '82-83 2.5L
Chevy Celebrity        &nb sp;   '82-83 2.5L
Buick Century          ;     '82-83 2.5L
Olds Ciera         & nbsp;       '82-83 2.5L
Chevy Citation        &nbs p;    '82-83 2.5L
Olds Omega         & nbsp;       '82-83 2.5L
Pontiac Phoenix          ;   '82-83 2.5L
Buick Skylark          ;     '82-83 2.5L
'84-86 2.5L XJS: The designation "XJS" is stamped on the front face or right rear of the block. The following heads will interchange if the coolant outlet and positions are switched and the push rods are included. The intake valves have 0.3422" diameter stems. The exhaust valves have 0.3419" diameter stems. The push rod length is 8.4". The heads below must have identification number 10022373, 10027767, 10030838, 10030839, 12360333, 1373 or 1767.
Pontiac 6000         &n bsp;        '84 2.5L w/o XJS designation on block
Camaro                          '84 2.5L
Chevy Celebrity        &nb sp;      '84 2.5L w/o XJS designation on block
Buick Century          ;        '84 2.5L w/o XJS designation on block
Olds Ciera         & nbsp;         & nbsp;'84 2.5L w/o XJS designation on block
Chevy Citation        &nbs p;      '84 2.5L w/o XJS designation on block
Firebird        &nbs p;         &nbs p;   '84 2.5L
Olds Omega         & nbsp;         & nbsp;'84 2.5L w/o XJS designation on block
Pontiac Phoenix          ;      '84 2.5L w/o XJS designation on block
Buick Skylark          ;        '84 2.5L w/o XJS designation on block
'84-86 2.5L XJS: The designation "XJS" is stamped on the front face or right rear of the block. The following non-XJS heads will interchange if the coolant outlet and positions are switched and the push rods are included. The intake valves have 0.3422" diameter stems. The exhaust valves have 0.3419" diameter stems. The push rod length is 8.4". The heads below must have identification number 10037282, 10038231 or 12360335.
Pontiac 6000         &n bsp;     '85-86 2.5L w/o XJS designation on block
Chevy Celebrity        &nb sp;   '85-86 2.5L w/o XJS designation on block
Buick Century          ;     '85-86 2.5L w/o XJS designation on block
Olds Ciera         & nbsp;       '85-86 2.5L w/o XJS designation on block
Chevy Citation        &nbs p;      '85 2.5L w/o XJS designation on block
Buick Skylark          ;        '85 2.5L w/o XJS designation on block
'84-86 2.5L w/o XJS: When present, the designation "XJS" is stamped on the front face or right rear of the block. The following heads will interchange if the coolant outlet and positions are switched and the push rods are included. The intake valves have 0.3422" diameter stems. The exhaust valves have 0.3419" diameter stems. The push rod length is 8.4". The heads below must have identification number 10022373, 10027767, 10030838, 10030839, 12360333, 1373 or 1767.
Camaro                          '84 2.5L
'85-86 2.5L w/o XJS: When present, the designation "XJS" is stamped on the front face or right rear of the block. The following non-XJS heads will interchange if the coolant outlet and positions are switched and the push rods are included. The intake valves have 0.3422" diameter stems. The exhaust valves have 0.3419" diameter stems. The push rod length is 8.4". The heads below must have identification number 10037282, 10038231 or 12360335.
'87-88 2.5L: The heads below will interchange only if they have identification number 10049100, 10117769, or 12360340.
Pontiac 6000         &n bsp;     '87-88 2.5L
Chevy Celebrity        &nb sp;   '87-88 2.5L
Buick Century          ;     '87-88 2.5L
Olds Ciera         & nbsp;       '87-88 2.5L
The following information was posted to Pennock's Fiero Forum by "Ray", Houston, TX:
Better flowing heads for an '87-88 Fiero 2.5L are found on the '90-93 S-10, S-15 and Blazer. Using these heads requires transferring the intake manifold with the heads, but all other parts from the Fiero will bolt on directly. Changing the heads/intake provides a bit more horsepower and better mileage. The exhaust ports on the newer heads are smaller than those on the Fiero but are more efficient. The combustion chambers are different and provide better fuel/air mixing and better cooling.
'87-88 2.5L: The heads below will interchange if the coolant outlet and positions are switched. Heads must have identification number 10054501, 1006630, 10117770 or 12360340.
Pontiac Astro         & nbsp;    '87-88 2.5L
Blazer S10/GM Jimmy S15    '87-88 2.5L
S10/S15/GM Sonoma           '87-88 2.5L
Pontiac Safari (GMC)       '87-88 2.5L
Date Posted: 06 December 2013 at 8:51pm
http://www.fierosails.com/CylinderHead.html - http://www.fierosails.com/CylinderHead.html
