Also new to the Forum.
Forum Name: Fiero Spotting
Forum Description: Seen a Fiero around town, wanted to know who's it was, this is the place
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3391
Printed Date: 26 November 2024 at 10:54am
Topic: Also new to the Forum.
Posted By: RegCharie
Subject: Also new to the Forum.
Date Posted: 07 January 2014 at 3:46pm
Hi all,
I have just purchased an 86 Fiero which has had a LOT of work done to it.
This is the info I received with it.
Work done:
New plugs and sensors
Resonator
Flow master muffler
Magnaflow tips
Tranny oil pan
new rings
rear main
large injectors
accel coil
MSG ignition
comp cam
K&N cold air intake
engine mounts
new battery
new rotors and brakes
calipers rebuilt
adjustable coil-overs (2" lower)
power
windows
power mirrors
Aftermarket deck
It runs well and has the performance, idle and sound of a nicely modified engine, lopey idle, crisp exhaust note, and noticeable "cammed engine" performance.
It's a 'bit' extreme in regards to suspension changes as it has been lowered and getting in and out is a treat..
It's lucky I live in Courtenay where we do not get much snow, (and slush), but contorting this 72 yr old 6 foot 1 inch frame getting in and out is a trip.
Would anyone here know the guy that did the upgrades?
From the Vehicle history it has been in:
MAPLE RIDGE (11/13/2000), ABBOTSFORD (07/05/2008),and DUNCAN 11/10/2012, before being sold to the young guy in Nanimo in July 2013.  I got it in Dec.
I am really enjoying it, it is a HOOT to drive.
Hope to talk with you all soon.
Reg Charie
New Fiero Owner
Date Posted: 07 January 2014 at 6:13pm
Welcome
There will be somone here that will no the history
of your Fiero,but not me.Your Fiero looks real nice.
They sure are a fun little car to drive,an stick to the
road like glue.Me being over 50, an getting in an out
not as easy as when i was in my 20s, I open the door
an put the palm of my L/H on the rocker/door jam an
kinda push an roll my self out like a barrel -LOL Have
fun with your new found Fiero Reg Charie
Joe
Date Posted: 07 January 2014 at 7:38pm
Welcome to the forum, lots of knowledgeable people here.
Someone will probably know the history of that Fiero.
Posted By: Jordandsd
Date Posted: 07 January 2014 at 9:05pm
Hey, Im the other new guy on here lol
I saw that fiero for sale on the island.. i planned on
checkin it out but didnt make it out there in time ahah
So since then i just bought one. There is a meet coming up
over here i might throw a permit on mine and show up. My
fiero has had some work done to it as well but it also
needs some work... planning on a paint job etc and new
clutch. I would want to do a 3800 swap but sounds like
allot of work?!
Date Posted: 08 January 2014 at 8:46am
Thanks for the welcome guys.
I hope someone does. Knowing more about the mods sure would help.
@Artic-1
Yes it is in quite good condition and seems to be well cared for.
It does need some work but it seems minor.
Need to get a proper oil cap, oil pressure shows max, temp sensor sets off "Service Engine" light if I run with a thermostat, temps look ok on guage and 'feel' about right.
Oh ya, there is no spare, jack or lug wrench.
It has an annoying click coming from the passenger door when I hit a bump, (Which I understand can be fixed by using a Ford lock post), the rear deck lock is broken, small stuff.
Reg Charie
New Fiero Owner
Date Posted: 08 January 2014 at 8:28pm
Wecome.
Hope to see you at a meeting.
Date Posted: 08 January 2014 at 11:46pm
Ya i heard its common for the oil pressure guage to read
max.. Mine does too and my service engine light comes on
once in awhile not sure why yet but this spring and summer
ill be going through the car and figuring it all out. Also
since your new with the Fiero always make sure if you take
it somewhere to be worked on make sure to watch where they
are putting the lifts under the car.. your radiator lines
run under the car on either side where lift points are
close to.
Posted By: bcampbell
Date Posted: 10 January 2014 at 12:22am
Rear deck lock is super easy to fix; you can order
replacements on-line. If you want all the locks to match
though, the door locks are quite a bit more annoying to
change.
'89 Firebird 3500T, T56
Date Posted: 10 January 2014 at 8:32am
Originally posted by RegCharie RegCharie wrote:
Work done:
K&N cold air intake
I'm curious, where is the http://www.fiero.nl/forum/Forum2/HTML/121680.html - MAT sensor now located with the addition of a K&N cold air intake? (It's worthwhile noting that the way K&N filters are normally installed, they actually supply warm air from inside the engine bay as opposed to the stock system which is a true "cold air" intake.)
...temp sensor sets off "Service Engine" light if I run with a thermostat, temps look ok on guage and 'feel' about right.
I hope you're not running without a thermostat... especially this time of year. Your engine will never warm up properly, leading to excessive wear and terrible gas mileage.
You need to determine what your http://www.fiero.nl/cgi-bin/main.cgi?ECMCodes - trouble codes are and deal with them.
