Won’t go into gear
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=3467
Printed Date: 18 April 2025 at 12:29pm
Topic: Won’t go into gear
Posted By: reidzap
Subject: Won’t go into gear
Date Posted: 05 May 2014 at 4:17pm
Give you a run down on what happened first. Running fine, went to stop
at a stop sign then the car wouldn't go into gear, any if them it would
only grind. I then tried slamming it into gear And the car quit and
wouldn't start again after. I trailered it home and replaced the slave
cylinder thinking that was the issue because I just replaced the clutch
2000 kms ago. Still won't go into gear and the only way I can start it is
by jumping the starter or jumping the connections underneath the
clutch pedal. So my issue is still the not going into gear while running.
And won't start unless I jump the connections or the starter. So my
question for you guys is what the heck is wrong?
Posted By: reidzap
Date Posted: 05 May 2014 at 4:18pm
Oh and I re bled the system as it says to do on the fieros
Posted By: Fieroman88
Date Posted: 06 May 2014 at 10:41pm
How does the clutch field when you depress the pedal. Can
you put it into gear car into neutral with the car off?
Fieroman88
