Blown Clutch and Trans, Many Pics inside
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=415
Printed Date: 22 November 2024 at 9:15pm
Topic: Blown Clutch and Trans, Many Pics inside
Subject: Blown Clutch and Trans, Many Pics inside
Date Posted: 30 December 2007 at 2:23pm
Well I don't think I will ever by buying another Centerforce Clutch EVER again.
Last spring my 4.9 with the Isuzu 5spd blew something up.  Was not sure exactly but it sounded like a hand grenade going off in the bell housing.   I parked it and today I finally had the time to tear it down.
I don't think I will ever buy another Centerforce clutch again.   Thankfully my flywheel looks like it will be fine with a surfacing.  The only area that got scored was near the center where there is no contact with a clutch.
Note this clutch has only about 6000 miles on it.  It never saw slicks or heck I never really took it to the track.  Just played on the street.  At the time of failure I was only running 225/50/16's on it.
Well here are the pics and there are lots of them, so I hope you have broadband.
I was baffled when I pulled the trans off to find this mess.  I could not see where the metal had came from.  The clutch LOOKED fine.
To start off here are the bell housing / input shaft pics.
Here is the Pressure Plate both on and off the car.
Then we get to the really broken stuff.
The Clutch Disc.
Then a few group shots of the parts.  Notice the springs are in pieces.
Well the next clutch will be one of 3 things.   A cheap one to get the car on the road.  Or a Spec or a Bully Clutch from Alberta.  With the current USD / CDN$ rate the way it is, I might just splurge on a Spec stage 4.
Posted By: ZeroC
Date Posted: 30 December 2007 at 6:42pm
Dave Is To Transmissions ...As Death Is To Humans
They Should Put This In The SAT Test ;)lol You Could Be Famous Dave :)
Posted By: Chicken Chaser
Date Posted: 31 December 2007 at 7:11pm
Wow, that's not very good. Hope you get your fiero back on the road soon.
Date Posted: 07 January 2008 at 3:58pm
That's gros, David.
I think of all the clutches my car has one through, I only actually wore out one.   The other 4, including the one that came out of the factory, had the clutch throwout bearing break.  But you have to replace the entire clutch anyways.
Date Posted: 08 January 2008 at 10:55am
Well I am going to take my time with it and fix a few other things before it hits the road again.
