Man that is one wicked system.
Even SATA Optical Drive.
That CPU heat sink is Massive too.
Drools over 4gb of ram and an 8800GTS video card. You are not going to NEED to upgrade for a long time. However looks like you have room to upgrade anything as soon as you want too. I am betting that MB supports running 8-16gb of ram not that anyone in the near future should need that. But that is frigging cool.
I see it has a top vent. That is a nice mod that I have done to several of my server class rigs. If you decide you want to add some more coolness to the system. (and this just seems to make every PC cooler) Well not cooler in the temp so to speak, but cool in the WOW factory.
Hit up Home Depot and pick up 4 swivel casters with flat mounting pads. Then go home, dismantle the entire rig so you won't get ANY metal anywhere on any of the awesome parts. Drill holes in the bottom of the case for the caster mounts and install.
It does 2 things. Gives the case some more breather room under it and allows you to move the case around easier for tweaking things. (and there is nothing cooler than being able to roll your computer around.
I have 2 servers on wheels. My main rig, I cheated, I picked up a Nice looking piece of 1" thick 12" wide I think its Oak and mounted the casters to it. Then the tower rests on the wood, with it slide forward enough that the front bottom intake is just forward of the lip in the wood and can get plenty of fresh air.
Ok back to your Sweet Tower.
That is totally awesome. I can't believe you put that rig together for that price, (aside from the new video card which is probably $500 alone)
Just out of curiosity what mouse are you using. I know you being a Gamer and all need awesome response time from your mouse. I know the Razor is the best, however I kinda prefer the Logitech Revolution. It has 2 scroll wheels and 5 configurable buttons. Each scroll wheel also has a button function when you push it down. So tech it has 7 buttons and 2 scroll wheels. Uses Li-Ion batts, True Laser Sensor yadda yadda yadda.
Dang I keep getting off topic here.
Ok you need to go out and run some benchies on the new rig and post back the results. Be sure to post the ver of the bench software you run. Just for laughs sake I would love to run my antique rig against it just to see how huge the difference is.
(for the record for people that don't know me)
This WAS top of the line when I put it together.
CPU P4 2.8C Overclocked to 3.5ghz
Ram 1gig DDR400 running OCed 500mhz
Video Ati Radeon 9800XT
Hard Drives. 2 many to list. Total 2.2 terabytes. (2250 gig usable HD space)
Lots of other stuff, but nothing worth noting.
Again if I have not said it enough, I am so jealous of your new rig. I was thinking about building something similar, however budget dictated I had to make a choice, Build a Super Rig or Buy Super Quality parts to get my 85GT V8 Fiero back on the road and I am choosing Fiero. I got an email back from Spec and I am going with a race clutch this time. Solid Hub design. All new mounts, and getting some other custom work done to make it a bit more reliable.
I guess my antique computer will have to get me by for another 6 months of so. The good news is by then all the computer parts should have gone through another update cycle and be a bit cheaper.
