Torx For Caliper Removal
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=588
Printed Date: 22 April 2025 at 6:14pm
Topic: Torx For Caliper Removal
Subject: Torx For Caliper Removal
Date Posted: 30 April 2008 at 7:55pm
Hey there. Anyone know the size of the torx bit required to remove the rear calipers?
Thanks,
Date Posted: 01 May 2008 at 8:33pm
I think 45 or 50
Posted By: ZeroC
Date Posted: 02 May 2008 at 12:14am
pretty sure its a 50 ..
Date Posted: 02 May 2008 at 10:41pm
Its a T45 is the plug is dirty and you can't tap in a T50. If the Bolt is clean and rust free, take a T50 line it up with the hole and use the side of the ratchet to tap it in. A T50 is your best bet.
Just to make sure, try and poke your head around the back and make sure it is even a torx. Over the lives of Fiero's some people have changed the Torx bolts to large Allen bolts, especially if the Grand Am Calipers added.
Hey Chay, can I send you the club scan tool, and have you take a look at it. Can I just use the address on the envelop of cables you sent. Thanks for the cables by the way, they got here I just have not found an old laptop to test them with. All of our current lappys have USB and no standard com ports.
Date Posted: 12 May 2008 at 7:30am
Thanks for the info guys. I bought a decent set and should be ok...they were pricey though.
Dave, you can definately send the scan tool to the address on the envelope. I'll see what I can do.
