Clutch wont engage
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=674
Printed Date: 23 November 2024 at 5:30am
Topic: Clutch wont engage
Posted By: Roadfury
Subject: Clutch wont engage
Date Posted: 06 June 2008 at 4:31pm
No matter how may times we bleed the system it won't engage the clutch.....
Put in a new slave cylinder today but still nothing!!!!!!
Is there a common problem with these?
PS its a 4spd 85GT
Date Posted: 06 June 2008 at 9:04pm
Use a power bleeder if you have access to one.
They ARE a PITA to bleed.  Took me many many times to get a technique down.  If you pull the rod out of the slave - the pedal should be rock hard (DONT push with your FOOT though!!!!!!!!!!!!!!!!!!!!!!!!!! No more pressure than you can get with ONE finger) if you've got all the air out.
