18" rims on fiero?
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=694
Printed Date: 22 April 2025 at 6:15pm
Topic: 18" rims on fiero?
Posted By: gtexotic
Subject: 18" rims on fiero?
Date Posted: 11 June 2008 at 3:07am
Will 18" rims with an offset of +45 and the width of 7.5 fit on my 86 fiero gt that is lowered 2 inches?
Date Posted: 11 June 2008 at 8:12am
  I don't know about the offset, however Chris aka RedDragon in the members gallery section.  Has 18x8's with 245/40/18's on his car, which is dropped 2" all the way around.
Posted By: Matt
Date Posted: 12 June 2008 at 6:04pm
pictures plz (once it's done)
I wanna go fast.
Posted By: Austin
Date Posted: 18 June 2008 at 12:17am
I found this thread/diagram very helpful when I was looking for wheels.
(from this thread)
http://www.fiero.nl/forum/Forum1/HTML/058236.html - http://www.fiero.nl/forum/Forum1/HTML/058236.html
Date Posted: 19 June 2008 at 9:13am
What are you running now Austin?
Posted By: Austin
Date Posted: 19 June 2008 at 9:33pm
17 x 7.5, 42mm offset
They are pretty 'tucked in' so at full lock my front tires rub a tiny bit.  Problem would be solved with a brake upgrade though
Date Posted: 19 June 2008 at 11:42pm
I a looking at these in 225/50/16's
http://www.falkentire.com/#/Tires/Motorsports/RT-615 - http://www.falkentire.com/#/Tires/Motorsports/RT-615
But had great replies off the Fiero Racing list on Yahoo:
Honestly? My advice aint what you want to hear. Leave it alone.
Learn how to drive for a while. Participate in at least six events
before you even ponder what the car needs. Until then, you need way
more improvement than the car does. If you buy expensive tires that
stick really good, they will mask your bad habits that ALL newbies
have. The tires will wear out way too fast. But the worst part is
that you will have developed bad habits that will be very hard to
break later. Learn how to get the most out of what you have now. By
learning on tires with less grip, you will learn how to be smooth
and not upset the car by overdriving it. Then when you get the
stickies, you will be SOOOOOOO much faster.
Sorry...
You're on the internet... If you ask for opinions, we're allowed to
give ours. I'm sure others will have a different opinion than mine.
And when you do buy the tires, Kumho & Hoosier have good DOT legal
slicks. You can find the specs for those on Tirerack. You can get
used "true" slicks that are not DOT legal for almost free. If you
want a true "street tire" that has excelent grip, the Falken Azenis
RT-615's are hard to beat. Consult your club's rule book for maximum
wheel width an diameter as well as tire compound and width. You
don't want to buy equipment that will boost you up with faster cars
where you won't be competitive.
My $0.07. (nickel fuel surcharge)
Makes sence, I would like to salvage my rims for the stock look and feel, so let's see how much it works out to...lol
Posted By: Austin
Date Posted: 20 June 2008 at 6:33pm
Those definately look to be good track tires but that treadwear of 200 lol... Wouldn't drive on those everyday :)
Date Posted: 20 June 2008 at 8:08pm
I will be meeting my buddy on Monday at OK Tire...considering KUMHO tires, I'll update ya when I know more...considering a brake upgrade for the fronts also, just need the time for all this...lol
Posted By: Austin
Date Posted: 22 June 2008 at 2:42pm
Sorry can't say for sure but the diagram says it should just clear the strut/springs.. I think the fronts will rub the control arms at full lock though.  If you do pick up a set of wheels, make sure to test full suspension travel/steering lock to lock before driving so you know it clears or not.  Unless you're pretty decided on a set of wheels, I think youre better off finding wheels that fit than to use spacers.
Cool.. Im very very nervous about the stock Fiero brakes at Mission.   I had mine smoking when I was oiut there last year and I think I may have to do the Grand Am fronts before then.
Austin
Date Posted: 22 June 2008 at 4:05pm
I pretty much have decided to go with this package:
In Bronze: http://www.enkei.com/Performance%20specs/rsv.html - http://www.enkei.com/Performance%20specs/rsv.html
215/40/17 Falken Azenis RT-615: http://www.falkentire.com/#/Tires/Tuner/ - http://www.falkentire.com/#/Tires/Tuner/
As for brakes, I just checked mine at David's, I will be looking at doing the GA upgrade before I think also, but I don't plan on going really hard anyways.
Good to know that you have already raced Mission:)
Date Posted: 23 June 2008 at 3:48pm
Ok, I gave in today...lol
http://i170.photobucket.com/albums/u243/Bassman68/Detail%20at%20Blairs/June1508001.jpg - http://i170.photobucket.com/albums/u243/Bassman68/Detail%20a t%20Blairs/June1508001.jpg
http://i170.photobucket.com/albums/u243/Bassman68/Detail%20at%20Blairs/June1508004.jpg - http://i170.photobucket.com/albums/u243/Bassman68/Detail%20a t%20Blairs/June1508004.jpg
http://i170.photobucket.com/albums/u243/Bassman68/Detail%20at%20Blairs/June1508006.jpg - http://i170.photobucket.com/albums/u243/Bassman68/Detail%20a t%20Blairs/June1508006.jpg
Posted By: Matt
Date Posted: 23 June 2008 at 8:08pm
Ooooo pretty
I wanna go fast.
Posted By: Austin
Date Posted: 23 June 2008 at 10:28pm
Those look awesome!!  17x7?  Offset?
Date Posted: 23 June 2008 at 10:38pm
yes and 42 offset, went with 215/45/17's, 40's were too low.
