88 Cradle swap rear brake line
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=855
Printed Date: 23 April 2025 at 1:00am
Topic: 88 Cradle swap rear brake line
Subject: 88 Cradle swap rear brake line
Date Posted: 08 September 2008 at 11:26am
Anyone who has done the swap...any part numbers or suggestions on where to source the longer brake lines needed? Are they Lordco specials or do you have to custom order them from someplace?
Thanks,
Date Posted: 08 September 2008 at 9:37pm
I used -4 lines, and an inverted flare to -4, and a banjo to -4 adaptor.
THEN...  I found out it was WAY cheaper and easier....  to simply bend the flex line to the rear of the axle, and use the stock flex hose!   :)
Date Posted: 09 September 2008 at 1:24am
It's just so crazy it might work.
I'll try it.
Thanks,
