ECM Files for 86 v6 4 speed
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=861
Printed Date: 23 November 2024 at 3:37pm
Topic: ECM Files for 86 v6 4 speed
Subject: ECM Files for 86 v6 4 speed
Date Posted: 10 September 2008 at 11:13am
Anyone be willing to share the stock bin and/or xdf(Tunerpro) and or ecm files for an 86 se v6 4sp?
I'm going to start datalogging the 3.4 blms in order to check the tune, then move to a '7730, but it would be nice to see what the current tune is and how it's running. After I tune the stock code I can then insert the table data into the $8f code (Turbo grand prix) and add the turbo and tune later. Also I can take advantage of the well documented advantages of the '7730. Hopefully the experience of tuning the 3.4 n/a will help when the turbo setup is built.
Any help is appreciated.
Date Posted: 10 September 2008 at 11:17am
PM Sent
Date Posted: 10 September 2008 at 5:53pm
I've got the .bin files for every year/model fiero, plus I've got all the TGP ones.
Date Posted: 11 September 2008 at 3:06pm
Would you mind shooting them off to me at mailto:aimeechay@shaw.ca - aimeechay@shaw.ca ?
Which tuning program do you use? Tcat, Tpro, Winbin, etc.
Do you use .ecm(s) for bin mapping or other?
Dave sent me some bins already...I believe he said you were the source.
Thanks for any info.
Date Posted: 11 September 2008 at 6:42pm
Files sent...
I usually use Tunercat, but have also used a few others in a pinch.
Date Posted: 12 September 2008 at 8:50am
Right on. I'm trying to use tunerpro...I'll see how it goes. So no ecm or xdf files for the fiero. I'll have to look around but I'm sure it's not a common application. The bins are a good start though.
You sent me three bins, as I understand it there are different setups (Calibrations) for the $8F code which correspond to different configurations (tranny, componenets etc)and therfore broadcast (prom) codes. I haven't found a list of broadcast codes vs. configuration. I read somewhere you can sort of read the name, like the A stands for alluminum heads etc. Any idea where I can find a complete comprehensive list? I've seen lists which include the popular tuning stuff like camaro setups for tpi 305 and 350 and 4.3 extreme and all that, just no reference to the TGP.
I guess it's not that important seeing as I will be modifying it away from whatever stock code I start with, essentially creating a new broadcast code (I'll call it FOSS I think), but it would be nice to be able to tell the original config a bin was setup for at a glance.
I would have thought with all the tuners out there this would be available someplace?
Date Posted: 12 September 2008 at 5:59pm
Check this page:
http://www.cruzers.com/%7Eludis/c3xref.html - http://www.cruzers.com/~ludis/c3xref.html
Lots of good info you might not have.
Date Posted: 19 September 2008 at 7:09pm
So Chay, how is the ECM tweaking going?
