fuel pump relay
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=910
Printed Date: 10 May 2025 at 11:45am
Topic: fuel pump relay
Posted By: hangmans8
Subject: fuel pump relay
Date Posted: 05 October 2008 at 6:49pm
where is the fuel pump relay in 87 gt?
i found a relay under the passenger side dash and one in the front trunk.
my fuel pump doesn't turn on some times.
thanks
1987 gt 5spd
Date Posted: 05 October 2008 at 7:00pm
Its in the engine bay, behind the Air Cleaner Box. If you have AC there will be 2 relays, if you do not have AC there will only be one.
Date Posted: 06 October 2008 at 7:30pm
thanks alot
the relay was sit in a little puddle of water!!
mounted it back on the fire wall with a new relay.
so far so good!
1987 gt 5spd
Date Posted: 06 October 2008 at 8:15pm
Ya if they come loose, the way they hang on the wires they will fill with water, really kinda sucks. However new relays are cheap, and if you really find water a problem you can wrap it in Saran Wrap.
