check engine light
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=922
Printed Date: 23 April 2025 at 8:02am
Topic: check engine light
Posted By: hangmans8
Subject: check engine light
Date Posted: 11 October 2008 at 9:28am
Question: where is the computer plug in?
the car was on the dyno at aircare and the check engine light came on!
i have i good scaner but no idea where to plug it in!
ps i car failed on idle!
1987 gt 5spd
Date Posted: 11 October 2008 at 9:44am
The panel where your cig lighter is...remove those two screws and plate, and there she be:)
Date Posted: 11 October 2008 at 9:48am
1987 gt 5spd
Posted By: kawana
Date Posted: 11 October 2008 at 10:11am
what scanner do you have? Ive been meaning to get one
Date Posted: 11 October 2008 at 12:50pm
i have a MAC taskMaster!
1987 gt 5spd
Date Posted: 11 October 2008 at 2:46pm
o2 and egr codes!
1987 gt 5spd
Date Posted: 11 October 2008 at 9:45pm
Fracking Hell, I had a whole paragraph reply written when I hit submit the page failed to load and lost all the reply.
So here is the short version.
O2 sensor code is normally due to the ground on the firewall side head on the drivers side has came off or gotten corroded. Check the ground wire on the side of the head, if it is good, then replace the O2 sensor.
EGR Sensor is usually due to the EGR solenoid going bad. So replace it.
Posted By: 88FieroGT
Date Posted: 11 October 2008 at 11:38pm
Where is the ground located? Is it on the engine or the firewall. My O2
sensor has been spitting codes at me to, but I couldn't get the old one off to
replace with the new one I have, so I gave up for a while. Thanks.
Date Posted: 12 October 2008 at 8:19am
the ground on my car is rotted off, there only half of it there!
1987 gt 5spd
Date Posted: 12 October 2008 at 10:22am
Its on the side of the head. (Engine)
