Clutch fluid lines
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=965
Printed Date: 23 November 2024 at 2:57am
Topic: Clutch fluid lines
Posted By: kawana
Subject: Clutch fluid lines
Date Posted: 02 November 2008 at 8:09pm
Does anyone have a diagram of where the clutch fluid lines run?  I have a small leak somewhere, and i have to add a few ounces every month or 2 when the pedal gets soft, but id like to get it fixed once and for all. I just dont know where the lines lead.   I have a feeling the problem is related to when i had my master and slave cyl replaced like 9 months ago,  it started not long after that.
Date Posted: 02 November 2008 at 8:14pm
The lines don't usually leak, peel back the boot on the slave and look for signs of dampness, and get your head under the dash and reach up to the master rod and check for signs of dampness. If everything is dry on both places, start checking for fittings at the slave and master.
