Audio problems.. XM radio
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=982
Printed Date: 23 April 2025 at 1:30pm
Topic: Audio problems.. XM radio
Posted By: kawana
Subject: Audio problems.. XM radio
Date Posted: 08 November 2008 at 6:52pm
I need help here, im getting frusterated.  You can read everything over here at pennocks, but ill sum it up.
http://www.fiero.nl/forum/Forum1/HTML/073291.htm
Basically, im installing an XM radio, im trying to hide the wires. Ive run the antenna wires. For the power it plugs into the cigarette lighter spot, but i dont like that. So what i did was buy a 3 plug adapter that is under the dash. Im trying to power it off of the radio's power, i THOUGHT i found the power and ground for the radio, i used my multimeter and when i touched both of them, it read 12.4V, but im now thinking those were for the speakers (which, as i write this, doesn't make sense.. it shouldn't read 12V if they go to the speakers..).  So anywho, i wired the 3plug adapter into the red+black wires on the back of the radio (both power and ground) (2 wires below the antenna input). The radio is really staticy, and i hear a click sound every time the cassette turns inside (cassette is the audio input from the XM radio.  I took off the wires i spliced in, but its still staticy, and i still hear the clicking sound. It wasn't like this before, and i didn't mess with any other wires besides those 2.  Another issue im having is that i cant eject the cassette, is there another way i can get it out?
Date Posted: 08 November 2008 at 9:44pm
Well the only input I can offer is regarding the power for the system. If you really need to get power for the 3 prong outlet the best place to grab the power from is the power window harness in the center console. Its much heaver gauge wire and it backed up by a circuit breaker. I have the 3 outlet power adapter under my dash and just ran the wires to the power window switch's. Its nice as it turns on with the car and off with the car. I have my radar detector plugged into it as well as the inverter and my bluetooth GPS charger.
Posted By: kawana
Date Posted: 08 November 2008 at 11:03pm
Ok, thanks, i might do that.  Anyone know what might be wrong with the radio?
