  New Posts New Posts RSS Feed - Putting the door back on
Roadfury View Drop Down
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Topic: Putting the door back on
    Posted: 03 November 2009 at 8:41am
I swapped doors out a while ago and there was only one bolt per hinge while the furthest spots were bolt less, im wanting to put those bolts back in but am haveing major problems putting the bottom one in... is there any tips to doing this???? thanks!
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2009 at 9:32am
Are you having trouble putting the hinge bolts back into the door or into the frame?
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2009 at 9:47am
Lower one on the frame/body side?  IIRC the nut is loose inside the pillar.  Been a while, but I seem to recall you need to pull back the carpet, and gently yank the 'tar paper' that covers the hole up.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2009 at 9:53am
Actually, it's a bolt that goes into the hinge from the inside of the pillar (opposite of the others), but it's difficult to tell if this is the problem that Mark is referring to.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2009 at 10:05am
Ah yes - that's it.  Knew there was 'something' hidden in there...  just been too long....
That aside - the whole hinge bolting on/off thing is the reason I simply pull the pins and lift off the door if I know it's going to go back on!!!!
(the pins probably needed replacing anyhow)
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2009 at 10:26am
The only reason I knew was because something jammed inside the driver's door of my parts car a couple of months ago and the only way I could ultimately get the door open was to remove the damn hinges!
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2009 at 10:29pm
So it is the bolts bolting hinge to body NOT hinge to door
And the bolts marked green are bolted from hinge to body (threads on body) and bolt marked red is bolted from the inside
but from your thoughts it looks like im going to just tap out the pins and bolt them in cause i have to replace bushings anyway door wont line up
