Fuel Pump |
![]() ![]() ![]() ![]() Posted: 02 May 2010 at 9:22pm |
Got to change the fuel pump in my GT,i pulled the filter off to pump out the
old gas in the tank,an the line is pluged!, can't get any flow throught the line that goes to the tank allso i don't here the fuel pump spinning up! fuse is good an relay is good,so iam assuming its the pump. the tank has to come off,any tips on changing the fule pump from somone that has done this. thanks |
#1 tip, buy the fuel pump for the 88 V6 GT/Formula its a much better pump. Better flow, less noisy and I think even costs a few bucks less than the early Fiero one as GM used it everything from the Corvette to the Big Block 454 (I think 7.4L V8) trucks. Jack the rear of the car up,and get under there its a fairly easy job, Lisa did her's with my help in less than an hour. You'll need a 13mm shallow socket a deep 13mm and a deep 15mm, plus assorted screw drivers to remove the hoses. |
Thanks dave,i took your advise in the beginning an got myself a doner car to
pull parts from,so i wounder if i can just pull the other tank outa the other car an put it in,witch two wires power up the pump?color?or just buy a new pump @ lordco an put it in this tank, how much$ for an 88 pump. thanks |
Fire451 ![]() Senior Member ![]() ![]() Joined: 14 February 2007 Location: Canada Status: Offline Points: 318 |
i would personaly just buy the new one at lordco beacuse even though it is not that big a job, it is not one that you want to do twice close togeather, you never know the condition of the pump in the donor car.. and for the piece of mind.. it is worth it to just get a new one.. which is about $150 for a ac delco and put a new sock/strainer ($15) on it too while you are in there
And to make the job MUCH easier, pull out the 4 tiny screws that hold the heat shield down and remove it.
When I had a bad batch of pumps, I had it down to about 20 min's total to swap the pump. :) |
Thanks for the tips guys,it all worked out just like Dave said,it was a big
help just knowing what tools to have on hand,it wasn't the first tank ive changed a tank,won't be the last,this car has bin sitting for a while an has skunk gas in it,just woundering about the fule rails/injectors an how to wash them out or just what to look at? lots of good advise here.Thanks |
Personally unless the gas is 10 years old, I would just let it run through. Many a person has let a Fiero sit for several years and ran the old gas until they could get some fresh stuff in it. Hell the gas in my V8 Fiero has not been filled for at least 4 years.
If you really want to purge it, aside from removing the entire fuel rail, your only option is to remove the schrader valve in the fuel rail. (under the plastic cap near the the coolant cap, in the fuel rail) Then unscrew the schrader same thing as a tire valve schrader. Put a hose on it, feed that hose into a jar or bottle then cycle the key on and off a few times. At the least that will dilute the old gas in the rail and purge the lines. |
Hay just s thought! what outer car crosses over for the fule pump in the
2.8 Fiero.don't have $130 for a new one.so pick a part for $19.99 looks vary good.in a regular car the fule tank is on a cupple of straps that can be cut with snips quick,i can pull a tank in about 2 min,snip the fule lines an test the pump with a boster Batt that i bring.so i might have to pull a few tanks to find a good pump?what outher cars have the same pump?is this list rite? THANKS FUEL PUMP 85-87 2.8L Fiero Buick & nbsp; & nbsp; '85 3.8L front wheel drive Buick & nbsp; & nbsp; '86 3.0L Buick & nbsp; & nbsp; '86 3.8L Buick & nbsp; & nbsp; '88 3.8L "HEL & HEM" on pump harness Buick Century   ; '87 2.8L except Station Wagon Buick Century   ; '87 3.8L except Station Wagon Buick Century   ; '84-86 3.8L Buick Reatta '88 Buick Skyhawk   ; '87 2.0L turbocharged Buick Skyhawk   ; '84-86 1.8L turbocharged Buick Skylark   ; '85 2.8L EFI Buick Skylark   ; '86-87 3.0L Buick Somerset &nbs p; '85-87 3.0L Cadillac Allante   ; '87 Cadillac Cimarron &nbs p; '87 Cadillac Cimarron &nbs p; '85-86 2.8L Cadillac Eldorado &nbs p; '87 & nbsp; & nbsp; "EP 176" on pump harness Cadillac Seville   ; '87 "EP 176" on pump harness Camaro '85-89 2.8L Camaro '90-92 3.1L Cavalier &nbs p; &nbs p; '85-87 2.8L Chevrolet Beretta   ; '87 2.8L Chevrolet Beretta   ; '88 2.8L VIN 200,001-500,000 Chevy Celebrity &nb sp; '87 2.8L except Station Wagon Chevy Celebrity &nb sp; '85-86 2.8L EFI Chevy Citation &nbs p; '85 2.8L EFI Chevy Corsica   ; '87 2.8L Chevy Corsica   ; '88 2.8L VIN 2000,000-500,000 Firebird &nbs p; &nbs p; '85-89 2.8L Firebird &nbs p; &nbs p; '90-92 3.1L Olds &n bsp; &n bsp; '85 3.8L FWD, mechanical speedometer Olds &n bsp; &n bsp; '86 3.0L Olds &n bsp; &n bsp; '86 3.8L Olds &n bsp; &n bsp; '88 3.8L "HEL & HEM" on pump harness Olds Calais '85-86 3.0L Olds Ciera & nbsp; & nbsp; '86 2.8L EFI Olds Ciera & nbsp; & nbsp; '86 3.8L Olds Ciera & nbsp; & nbsp; '87 2.8L &n bsp;except Station Wagon Olds Ciera & nbsp; & nbsp; '87 3.8L &n bsp;except Station Wagon Olds Ciera & nbsp; '84-85 3.8L Olds Cutlass   ;   ;'88 2.8L "WEC 07" on pump harness Olds Firenza   ; '85-87 2.8L Olds Regal & nbsp; & nbsp; '88 2.8L "WEC 07" on pump harness Olds Riviera   ; '86-88 Olds Toronado &nbs p; '86-87 Pontiac   ;   ; '87 3.8L Pontiac   ;   ; '88 3.8L "HEL" on pump harness Pontiac 2000 &n bsp; '8 4 1.8L turbocharger Pontiac 6000 &n bsp; '8 7 2.8L except Station Wagon Pontiac 6000 &n bsp; '85-86 2.8L EFI Pontiac Grand Am &nbs p; '87 2.0L Pontiac Grand Am &nbs p; '87 3.0L Pontiac Grand Am &nbs p; '85-86 3.0L Pontiac Grand Prix &n bsp; '88 2.8L "WEC 07" on pump harness Pontiac Sunbird   ; '87 2.0L turbocharged Pontiac Sunbird   ; '85-86 1.8L turbocharged Pontiac Tempest   ; '87 2.8L Pontiac Tempest   ; '88 2.8L VIN 200,001-500,000 |
Don't bother with the early pumps, go with the 88 pump, it is WAY more common, and a better pump, I am sure I have the interchange around here someplace. |
Buyers Guide Report A Catalog Issue
Enter a part number for which you would like to see vehicles. New Buyers Guide Search Part#: P74037 Manufacturer: Select ManufacturerCARQUEST/AIRTEXCARTER Part Type: Select Part TypeAll Part Type(s)ELECTRIC FUEL PUMPMECHANICAL FUEL PUMP Total Number of Applications: 274 BUICK (47) 1988-1996 CENTURY (7) 1988-1992 1992 V6-204ci 3.3L F/I Vin N 1991 V6-204ci 3.3L F/I Vin N 1990 V6-204ci 3.3L F/I Vin N 1989 V6-204ci 3.3L F/I Vin N 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W 1988 V6-231ci 3.8L F/I Vin 3 ELECTRA (1) 1990-1990 1990 V6-231ci 3.8L F/I Vin C LESABRE (3) 1989-1991 1991 V6-231ci 3.8L F/I Vin C 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C PARK AVENUE (1) 1990-1990 1990 V6-231ci 3.8L F/I Vin C REATTA (3) 1989-1991 1991 V6-231ci 3.8L F/I Vin L 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C REGAL (17) 1988-1996 1996 V6-189ci 3.1L F/I Vin M 1996 V6-231ci 3.8L F/I Vin K 1995 V6-189ci 3.1L F/I Vin M 1995 V6-231ci 3.8L F/I Vin L 1994 V6-189ci 3.1L F/I Vin M 1994 V6-231ci 3.8L F/I Vin L 1993 V6-189ci 3.1L F/I Vin T 1993 V6-231ci 3.8L F/I Vin L 1992 V6-189ci 3.1L F/I Vin T 1992 V6-231ci 3.8L F/I Vin L 1991 V6-189ci 3.1L F/I Vin T 1991 V6-231ci 3.8L F/I Vin L 1990 V6-189ci 3.1L F/I Vin T 1990 V6-231ci 3.8L F/I Vin L 1989 V6-173ci 2.8L F/I Vin W 1989 V6-189ci 3.1L F/I Vin T 1988 V6-173ci 2.8L F/I Vin W RIVIERA (5) 1989-1993 1993 V6-231ci 3.8L F/I Vin L 1992 V6-231ci 3.8L F/I Vin L 1991 V6-231ci 3.8L F/I Vin L 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C ROADMASTER (2) 1994-1995 1995 V8-350ci 5.7L F/I Vin P 1994 V8-350ci 5.7L F/I Vin P ROADMASTER ESTATE WAGON (2) 1994-1995 1995 V8-350ci 5.7L F/I Vin P 1994 V8-350ci 5.7L F/I Vin P SKYLARK (6) 1988-1991 1991 L4-138ci 2.3L F/I Vin D 1990 L4-138ci 2.3L F/I Vin D 1989 L4-138ci 2.3L F/I Vin D 1989 V6-204ci 3.3L F/I Vin N 1988 L4-138ci 2.3L F/I Vin D 1988 V6-181ci 3.0L F/I Vin L CADILLAC (16) 1988-1992 ALLANTE (5) 1988-1992 1992 V8-276ci 4.5L F/I Vin 8 1991 V8-276ci 4.5L F/I Vin 8 1990 V8-276ci 4.5L F/I Vin 8 1989 V8-276ci 4.5L F/I Vin 8 1988 V8-252ci 4.1L F/I Vin 7 CIMARRON (1) 1988-1988 1988 V6-173ci 2.8L F/I Vin W ELDORADO (3) 1990-1992 1992 V8-300ci 4.9L F/I Vin B 1991 V8-300ci 4.9L F/I Vin B 1990 V8-276ci 4.5L F/I Vin 3 ELDORADO TOURING COUPE (2) 1991-1992 1992 V8-300ci 4.9L F/I Vin B 1991 V8-300ci 4.9L F/I Vin B SEVILLE (3) 1990-1992 1992 V8-300ci 4.9L F/I Vin B 1991 V8-300ci 4.9L F/I Vin B 1990 V8-276ci 4.5L F/I Vin 3 SEVILLE STS (2) 1990-1991 1991 V8-300ci 4.9L F/I Vin B 1990 V8-276ci 4.5L F/I Vin 3 CHEVROLET (89) 1988-1996 BERETTA (9) 1988-1992 1992 L4-133ci 2.2L F/I Vin 4 1992 L4-138ci 2.3L F/I Vin A 1992 V6-189ci 3.1L F/I Vin T 1991 L4-138ci 2.3L F/I Vin A 1991 V6-189ci 3.1L F/I Vin T 1990 L4-138ci 2.3L F/I Vin A 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W CAPRICE (1) 1995-1995 1995 V8-350ci 5.7L F/I Vin P CAPRICE WAGON (2) 1994-1995 1995 V8-350ci 5.7L F/I Vin P 1994 V8-350ci 5.7L F/I Vin P CAVALIER (4) 1988-1991 1991 V6-189ci 3.1L F/I Vin T 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W CAVALIER Z24 (4) 1988-1991 1991 V6-189ci 3.1L F/I Vin T 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W CELEBRITY (3) 1988-1990 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W CORSICA (6) 1988-1992 1992 L4-133ci 2.2L F/I Vin 4 1992 V6-189ci 3.1L F/I Vin T 1991 V6-189ci 3.1L F/I Vin T 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W CORVETTE (4) 1988-1991 1991 V8-350ci 5.7L F/I Vin 8 1990 V8-350ci 5.7L F/I Vin 8 1989 V8-350ci 5.7L F/I Vin 8 1988 V8-350ci 5.7L F/I Vin 8 IMPALA SS (1) 1995-1995 1995 V8-350ci 5.7L F/I Vin P LUMINA (12) 1990-1996 1996 V6-189ci 3.1L F/I Vin M 1996 V6-207ci 3.4L F/I Vin X 1995 V6-189ci 3.1L F/I Vin M 1995 V6-207ci 3.4L F/I Vin X 1994 V6-189ci 3.1L F/I Vin T 1993 V6-189ci 3.1L F/I Vin T 1993 V6-189ci 3.1L FLEX/FI Vin W 1992 V6-189ci 3.1L F/I Vin T 1991 L4-151ci 2.5L F/I Vin R 1991 V6-189ci 3.1L F/I Vin T 1990 L4-151ci 2.5L F/I Vin R 1990 V6-189ci 3.1L F/I Vin T LUMINA APV (5) 1992-1996 1996 V6-207ci 3.4L F/I Vin E 1995 V6-231ci 3.8L F/I Vin L 1994 V6-231ci 3.8L F/I Vin L 1993 V6-231ci 3.8L F/I Vin L 1992 V6-231ci 3.8L F/I Vin L LUMINA COUPE (8) 1991-1994 1994 V6-189ci 3.1L F/I Vin T 1994 V6-207ci 3.4L F/I Vin X 1993 V6-189ci 3.1L F/I Vin T 1993 V6-207ci 3.4L F/I Vin X 1992 V6-189ci 3.1L F/I Vin T 1991 L4-151ci 2.5L F/I Vin R 1991 V6-189ci 3.1L F/I Vin T 1991 V6-207ci 3.4L F/I Vin X LUMINA EURO COUPE (6) 1992-1994 1994 V6-189ci 3.1L F/I Vin T 1994 V6-207ci 3.4L F/I Vin X 1993 V6-189ci 3.1L F/I Vin T 1993 V6-207ci 3.4L F/I Vin X 1992 V6-189ci 3.1L F/I Vin T 1992 V6-207ci 3.4L F/I Vin X LUMINA EURO SEDAN (6) 1992-1994 1994 V6-189ci 3.1L F/I Vin T 1994 V6-207ci 3.4L F/I Vin X 1993 V6-189ci 3.1L F/I Vin T 1993 V6-207ci 3.4L F/I Vin X 1992 V6-189ci 3.1L F/I Vin T 1992 V6-207ci 3.4L F/I Vin X LUMINA Z34 COUPE (3) 1992-1994 1994 V6-207ci 3.4L F/I Vin X 1993 V6-207ci 3.4L F/I Vin X 1992 V6-207ci 3.4L F/I Vin X MONTE CARLO (2) 1995-1996 1996 V6-189ci 3.1L F/I Vin M 1995 V6-189ci 3.1L F/I Vin M MONTE CARLO Z34 (2) 1995-1996 1996 V6-207ci 3.4L F/I Vin X 1995 V6-207ci 3.4L F/I Vin X PICKUP C2500 3/4 TON 4x2 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP C3500 1 TON 4x2 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP K2500 3/4 TON 4x4 (2) 1994-1995 1995 V8-454ci 7.4L 4 BBL Vin N 1994 V8-454ci 7.4L 4 BBL Vin N PICKUP K3500 1 TON 4x4 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP S10 4x2 (2) 1994-1995 1995 L4-133ci 2.2L F/I Vin 4 1994 L4-133ci 2.2L F/I Vin 4 PICKUP T10 4x4 (S10) (1) 1994-1994 1994 L4-133ci 2.2L F/I Vin 4 GMC (10) 1994-1995 PICKUP C2500 3/4 TON 4x2 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP C3500 1 TON 4x2 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP K2500 3/4 TON 4x4 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP K3500 1 TON 4x4 (2) 1994-1995 1995 V8-454ci 7.4L F/I Vin N 1994 V8-454ci 7.4L F/I Vin N PICKUP SONOMA (S15/T15) (2) 1994-1995 1995 L4-133ci 2.2L F/I Vin 4 1994 L4-133ci 2.2L F/I Vin 4 OLDSMOBILE (61) 1987-1997 CALAIS 442 (1) 1991-1991 1991 L4-138ci 2.3L F/I Vin D CUTLASS CALAIS (7) 1988-1991 1991 L4-138ci 2.3L F/I Vin D 1991 V6-204ci 3.3L F/I Vin N 1990 L4-138ci 2.3L F/I Vin D 1990 V6-204ci 3.3L F/I Vin N 1989 L4-138ci 2.3L F/I Vin D 1989 V6-204ci 3.3L F/I Vin N 1988 L4-138ci 2.3L F/I Vin D CUTLASS CALAIS - INTL (3) 1989-1991 1991 L4-138ci 2.3L F/I Vin D 1990 L4-138ci 2.3L F/I Vin A 1989 L4-138ci 2.3L F/I Vin A CUTLASS CIERA (9) 1987-1992 1992 V6-204ci 3.3L F/I Vin N 1991 V6-204ci 3.3L F/I Vin N 1990 V6-204ci 3.3L F/I Vin N 1989 V6-173ci 2.8L F/I Vin W 1989 V6-204ci 3.3L F/I Vin N 1988 V6-173ci 2.8L F/I Vin W 1988 V6-231ci 3.8L F/I Vin 3 1987 V6-173ci 2.8L F/I Vin W 1987 V6-231ci 3.8L F/I Vin 3 CUTLASS CIERA CRUISER (3) 1987-1992 1992 V6-204ci 3.3L F/I Vin N 1987 V6-173ci 2.8L F/I Vin W 1987 V6-231ci 3.8L F/I Vin 3 CUTLASS CRUISER (3) 1988-1991 1991 V6-204ci 3.3L F/I Vin N 1988 V6-173ci 2.8L F/I Vin W 1988 V6-231ci 3.8L F/I Vin 3 CUTLASS SUPREME (19) 1988-1997 1997 V6-189ci 3.1L F/I Vin M 1996 V6-189ci 3.1L F/I Vin M 1996 V6-207ci 3.4L F/I Vin X 1995 V6-189ci 3.1L F/I Vin M 1995 V6-207ci 3.4L F/I Vin X 1994 V6-189ci 3.1L F/I Vin M 1994 V6-207ci 3.4L F/I Vin X 1993 V6-189ci 3.1L F/I Vin T 1993 V6-207ci 3.4L F/I Vin X 1993 V6-189ci 3.1L F/I Vin M 1992 V6-189ci 3.1L F/I Vin T 1992 V6-207ci 3.4L F/I Vin X 1991 L4-138ci 2.3L F/I Vin D 1991 V6-189ci 3.1L F/I Vin T 1991 V6-207ci 3.4L F/I Vin X 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1989 V6-189ci 3.1L F/I Vin T 1988 V6-173ci 2.8L F/I Vin W CUTLASS SUPREME INT'L (2) 1992-1993 1993 V6-207ci 3.4L F/I Vin X 1992 V6-207ci 3.4L F/I Vin X DELTA 88 (1) 1989-1989 1989 V6-231ci 3.8L F/I Vin C SILHOUETTE (OLDS) (5) 1992-1996 1996 V6-207ci 3.4L F/I Vin E 1995 V6-231ci 3.8L F/I Vin L 1994 V6-231ci 3.8L F/I Vin L 1993 V6-231ci 3.8L F/I Vin L 1992 V6-231ci 3.8L F/I Vin L TORONADO (4) 1989-1992 1992 V6-231ci 3.8L F/I Vin L 1991 V6-231ci 3.8L F/I Vin L 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C TORONADO TROFEO (4) 1989-1992 1992 V6-231ci 3.8L F/I Vin L 1991 V6-231ci 3.8L F/I Vin L 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C PONTIAC (51) 1988-1996 6000 (5) 1988-1991 1991 V6-189ci 3.1L F/I Vin T 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1988 V6-173ci 2.8L F/I Vin W 1988 V6-189ci 3.1L F/I Vin T 6000 SE AWD (1) 1990-1990 1990 V6-189ci 3.1L F/I Vin T 6000 STE (2) 1988-1989 1989 V6-189ci 3.1L F/I Vin T 1988 V6-173ci 2.8L F/I Vin W BONNEVILLE (3) 1989-1991 1991 V6-231ci 3.8L F/I Vin C 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C BONNEVILLE SSE (3) 1989-1991 1991 V6-231ci 3.8L F/I Vin C 1990 V6-231ci 3.8L F/I Vin C 1989 V6-231ci 3.8L F/I Vin C FIERO (1) 1988-1988 1988 V6-173ci 2.8L F/I Vin 9 GRAND AM (6) 1988-1991 1991 L4-138ci 2.3L F/I Vin D 1990 L4-138ci 2.3L F/I Vin D 1989 L4-122ci 2.0L F/I Turbo Vin M 1989 L4-138ci 2.3L F/I Vin D 1988 L4-122ci 2.0L F/I Turbo Vin M 1988 L4-138ci 2.3L F/I Vin D GRAND PRIX (18) 1988-1996 1996 V6-189ci 3.1L F/I Vin M 1996 V6-207ci 3.4L F/I Vin X 1995 V6-189ci 3.1L F/I Vin M 1995 V6-207ci 3.4L F/I Vin X 1994 V6-189ci 3.1L F/I Vin M 1994 V6-207ci 3.4L F/I Vin X 1993 V6-189ci 3.1L F/I Vin T 1993 V6-207ci 3.4L F/I Vin X 1992 V6-189ci 3.1L F/I Vin T 1992 V6-207ci 3.4L F/I Vin X 1991 V6-189ci 3.1L F/I Vin T 1991 V6-207ci 3.4L F/I Vin X 1991 L4-138ci 2.3L F/I Vin D 1990 L4-138ci 2.3L F/I Vin D 1990 V6-189ci 3.1L F/I Vin T 1989 V6-173ci 2.8L F/I Vin W 1989 V6-189ci 3.1L F/I Vin T 1988 V6-173ci 2.8L F/I Vin W GRAND PRIX GTP (3) 1991-1993 1993 V6-207ci 3.4L F/I Vin X 1992 V6-207ci 3.4L F/I Vin X 1991 V6-207ci 3.4L F/I Vin X SUNBIRD (4) 1988-1991 1991 V6-189ci 3.1L F/I Vin T 1990 L4-122ci 2.0L F/I Turbo Vin M 1989 L4-122ci 2.0L F/I Turbo Vin M 1988 L4-122ci 2.0L F/I Turbo Vin M TRANS SPORT (5) 1992-1996 1996 V6-207ci 3.4L F/I Vin E 1995 V6-231ci 3.8L F/I Vin L 1994 V6-231ci 3.8L F/I Vin L 1993 V6-231ci 3.8L F/I Vin L 1992 V6-231ci 3.8L F/I Vin L New Buyers Guide Search |
HI All,well i got the pump in an purged the fuel rails with fresh fuel,so far
so good,this car was sitting for a few years-87 White GT/Auto-2.8 stock.when i bought it he said it had a bad valve,OK i can fix that.so when i got it fired up,yea its got a bad lifter,rocker? somthing in the top end is knocking,for sure valve train,so i pulled the plugs an found the CYL that is the problm-#No 1 .ive got to pull the intake off an thats where i need some pointers,the doos an don'ts of this job would be a great help.it does run vary smooth even with a sloppy lifter,i was surprised,i did try the snake oil thing with a little diesel fuel mixed in,an it did quiet down quite a bit,but didn't compltey go away,not sure,it could be a rod or piston, gotta come apart! any help would be great,thanks |
Update-well i got it apart!-UGLY! a bad rod, the engine is junk! so i guess
iam dropping the cradle.i found a 3.1 block that will work.i looked at a 90 LUMNIA today with a 3.1 in it ,but the top end was a lot differnt,ALUM heads an 6 pack coils SYS, an intake was differnt allso,so i would have to strip the 3.1 down to a short block an then bolt all my 2.8 Fiero top end back on it?is that how that works,an droping the cradle,how hi do you have to get the back of the car off the ground to clear everything,any advise would be grate!<"19_224303_PDR_0014.JPG"> |
