  New Posts New Posts RSS Feed - next step
next step
mxracer208 View Drop Down
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Topic: next step
    Posted: 18 July 2010 at 9:55pm
I have an 86 GT with the 4 speed manual and im planning
some upgrades. Im going to be buying some KYB shocks and
struts soon and a rear sway bar at some point to fix the
handling. However, the motor is fairly strong for its size
but im looking for a little more. I would like to be around
a 15 second quarter mile( i have done 16.1 at 84) so i was
wondering what options are available for reasonable amounts
of money and if what im doing to the suspension is good.
any comments are appreciated.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2010 at 10:39pm
Well, what direction are you headed with the car? Daily driver? Street-strip hybrid? Race spec? Show-strip hybrid? Right off the bat, basic mechanical maintenance is both cheap and one of the best areas to start (New oil, oil filter, air filter, spark plugs). Below I listed as much as I can think of that's cheap.
Daily Driver: Port the exhaust, polish up the intake as best you can, get MSD ignition components.
Street-Strip: Same as above, plus remove the spare tire and jack, get a spark amplifier.
Race Spec: Same as above, plus remove the sound system, get a comp cams k-code set (Valvetrain package), consider running a small nitrous system.
Show-Strip: Remove spare tire and jack, port the exhaust, polish the intake as best you can, get MSD components, rims and tires, spring cut.
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2010 at 10:43pm
Thanks for the info, it will mainly be a daily driver that
i will eventually take road racing and drag racing once in
awhile. I was looking at the MSD coil and wondering how
good it is. anybody using it? also the KYB suspension, does
anybody know how good it is?
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2010 at 10:51pm
Many members are using the coil, cap and rotor. I have them all, they hold up wonderfully at high rpm, which is apparently where the stock system falls short, but I can't honestly recall the difference, I'm just too used to it now. As for the KYB's, I personally have no experience with them, but our autocross guys here should be able to enlighten you with regards to them.
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2010 at 10:53pm
Alright, the MSD coil isnt very expensive so i will
definatly look into that and i just replaced my cap and
rotor with an oem replacement so i will leave that.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2010 at 9:39am
Ok start off, this is your cheapest place for MSD stuff and other good stuff.
http://captfiero.com/ppc/
Now to performance, Fire451 and I have both built Fiero's that ran as fast as 14.6 with a V6 4spd combo.  My personal best V6 run on motor alone was 15.01 and he edged me out with a 14.99 later that night with cooler air.
  There is a huge and I mean HUGE difference between 15.9 and 14.9 when it comes to performance, however neither of us had any fancy intake or exhaust.  Stock intake, stock Throttle body, only mod was ported exhaust manifolds and no cat converters.
We did have full MSD Ignition, 19# injectors, big cams, custom chips and roller tip rockers.  I ran 1.52 rockers and he had 1.6 rockers.  If you want performance without pulling the engine your first mods are...
MSD Ignition, complete, wires, coil, ignition box and cap and rotor.  Your OEM Cap and Rotor won't handle the 6al box.  Heck if your OEM coil does not have brass contacts it barely works with a good stock coil.
Next mod is adjustable fuel pressure regulator, and fuel pressure gauge.
Next remove the stock exhaust manifolds and get them fixed.  All of them from the factory are CRAP, you can get 5-7hp just by cleaning up the ports.
Then you start to get a bit more work, but with the biggest gain, 1.6 ration roller tip rockers combined with the exhaust porting is worth 5hp, however the big gain is the increased rpm and power range.
Oh almost forgot to mention the power pulley set.  You can get it from ASP or I think the Fiero store.  Its worth a documented 1-2 tents in the quarter, thats a good 2 car lengths faster in a street race.  I run the single pulley during the winter and both during the summer.
There are a ton of other little mods like EGR delete, Valve cover breather delete, and remove the mesh under the deck lid vents, all little things that will help the car run better.  Over inflating the front tires to reduce rolling resistance, they can all ad up to an extra tenth.
On a P.S. note, if you are going to race a 2.8 start looking now for a spare motor.  Even with fully rebuilt, balanced and using really good parts, our motors only lasted a year maybe 2.
If you want to get into more of a full rebuild I can recommend what parts made the biggest difference, however unless you are doing all the labor yourself and your time does not matter, it will cost you more than just doing an engine swap to a 4.9 or 3800S/C.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2010 at 10:10am
I guess it depends what you consider cheap....:)  Dave said it well I think,"Mods that don't involve pulling the engine".
I think the big bore intakes help you take better advantage of all the other little improvements that have been done.  Intake, valve train and exhaust should be opened up to let the engine breath.  It's all available locally and is relatively cheap.
The stock V6 Fiero ignition is definitely a weak point.  Anything you can do to improve it will make you happy.
There are several of us that have higher output V6's that run reliably as daily drivers.  It is very doable and didn't cost a ton of money.
Fire451 View Drop Down
Post Options Post Options   Quote Fire451 Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2010 at 4:00pm
i honestly will NEVER build up a 60 deg v6 for a fiero again, cost me just as much if not more than it would have cost me to do a engine swap and the gain is very minimal and like dave said i only got a couple of years out of each motor.  if you want to know how to get your car into the 14's the list was like this:
Forged TRW Pistons 9.01:1, Molly rings, Clevite bearings,
ARP Head studs & rod bolts, performance 0.039" head gaskets,
Comp 1.52:1 roller tip rockers, Comp 130 lb valve springs,
custom grind cam .484 ex and .468 int. with 110 seperation
if I remember correctly, Comp Magnum lifters, I cleaned up
the heads, intake and exhaust manifolds, gasket matched everything,
new timing set,MSD Digital 6 ignition box, MSD Blaster
coil, MSD 8.5mm super conductor wires, Heads decked .027" and block head
surface resurfaced (maybe 0.003' off), shaved and realigned lower
intake plenum to match, block was bored 0.040' over, crank was
machined and oil galleries champfered (block as well),corvette fuel pump and mustang 19 lb injectors
also in a stock 87 gt with a msd ignition I was able to get a fastest run of 15.9.
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2010 at 4:11pm
ya, im not planning on keeping the 2.8 for serious racing,
it will cost way to much. how is the pushrod 3.4 for power?
that seems like a fairly easy swap that i was planning for
sometime later.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2010 at 7:06pm
Talk to Austin on the forum about the 3.4 Camaro motor or even to Brian who has a 3.2 the extra torque from the longer stroke is suppose to be the big difference not so much the horsepower.  Also check out Pennocks there is a thread their with a list of 1/4 miles times with at least 100 different engine and trans combo's so you can get a good idea of what mods work the best.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2010 at 10:44pm
Hehe, or you could do a really convuluted aluminum head swap...
