My fuse 5 got detached! |
InfernoFiero ![]() Senior Member ![]() Joined: 25 June 2011 Location: Canada Status: Offline Points: 133 |
![]() ![]() ![]() ![]() Posted: 27 August 2011 at 1:47pm |
As I was cleaning the inside of my car I noticed a fuse by the brake pedal. It was fuse 5. Looking up on the electrical diagram and info for a 1984 Pontiac Fiero I discovered the fuse powers the left and right signal turns on the back of the car. My car, however, without the fuse 5 is able to do right and left turn signals though. Anyone have an idea why this might be happening? |
DannyCanuck ![]() Senior Member ![]() Joined: 04 July 2011 Location: Canada Status: Offline Points: 106 |
The number on the actual fuse is for the amp rating of the
fuse, not the number of the fuse. I'm not sure which fuse it is but hang on to it for when the next 5-amp fuse blows. |
88 duke, bog standard
Gotcha, since its the only 5 amp fuse it turned out to be
fuse 11 which is in charge of the panel lamps and headlamp warning. Thanks. |
