  New Posts New Posts RSS Feed - FS; 1986 Fiero V8 CADILLAC 4.9PFI Seattle
diesel_ View Drop Down
Post Options Post Options   Quote diesel_ Quote  Post ReplyReply Direct Link To This Post Topic: FS; 1986 Fiero V8 CADILLAC 4.9PFI Seattle
    Posted: 15 September 2013 at 10:45am
Hello everybody,
I got this 1986 Fiero SE 2M8 with 92 Cadillac 4.9 V8 PFI
and 4sp Muncie for sale! It started out as a project for
a friend and after he quit on it(after year and halve and
spending $10k US)it became mine! I need to sell it so,
any reasonable offer will be considered!
144k miles on the car and about 100k on a Cadillac motor
that has been rebuild >6k miles ago!
Cadillac V8 rebuild, with;
Rod and Main bearings, Tri Metal
Timing gears and Chain
Complete engine Gasket set
Machine shop heads rebuild(Jay's Automotive Machine Shop
in Everett)
Delta camshaft stage 1 street,
Mustang 19# Injectors, 4 hole,
Distributor, Hydraulic Lifters and new Head bolts
Also less than 6k miles ago:
Suspension Techniques 1.7" Lowering springs
KONI RACING Shocks, Rear Adjustable - 4 different
settings,
Add-on Rear Sway bar,
Polyurethane mounting hardware,
Big Brake Kit,
Stage 3 clutch 9-11/16" Bronze Ceramic Disk with steel
Flywheel and Pressure Plate,
Engine and Tranny Mounts and Brackets,
Aluminium Cradle Mount Bushings, set of 6,
A-arm Bushings, Delrin, rear, serviceable,
Lower front Control arm Bushings,
Injection Technolugy Wireing harnes,
Additional Electric Water Pump in front - Davis Craig
EWP80L,
Racing 4 Core Radiator,
High Flow fuel pump,
20HP ECU chip,
Custom Exhaust,
Engine oil Cooler,
Rodney Dickman Short Trow Kit , Shift Cables and Custom
Shifter
Toyota MR2 slave cylinder,
CV axles, wheel bearings, ball joints, tie rods, interior
carpet,
most engine switches and sensors...
Pioneer CD Deck,
Fresh oils and fluids all around,
Front tires 215/45/17, >3k on them,
Brand new Pirelli 225/45/17 rear tires and alignment >500
miles.
AC blows cold!
Thanks Adam
2M8 Cadillac 4.9 V8 PFI 4sp Muncie
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2013 at 11:13am
Adam, I had considered buying that Fiero from Larry two years ago.
If I hadn't just brought an '88 Formula up from Washington State a month ago, I might've considered making an offer on this Fiero... but that ain't happening now.
Edited by Patrick
