Vancouvers Next Top Novice #2 |
Page 123> |
![]() ![]() ![]() ![]() Posted: 19 June 2008 at 8:35am |
http://www.ubcscc.com/index.shtml#events Hi All...next Novice races with UBC club is on June 29th. We need to become a member and register, same as last weekend which was a VCMC event. Between both clubs they hold all the races and share Pitt Meadows. I'll be registering today...and hope to have new tread by then if I can make up my mind...lol |
Well if I get the suspension rebuild and lowering of my 88GT done and then sent in for alignment, I may join you. I have the entire front end torn to bits right now. Trying to work on it little by little in between work and home duties.
Austin ![]() Senior Member ![]() ![]() Joined: 17 June 2008 Location: Canada Status: Offline Points: 195 |
Nice.. haven't seen the sign-up thread yet on their site but Im keeping an eye out. What kinda rubber you getting? Do you have another set of wheels? If you're buying wheels keep size & weight in mind, I can definately feel a difference when changing from 14's/15's to the 17's. |
![]() 1986 Fiero GT 3.4L V6 DIS, 5 spd, Full Polyurethane Suspension, Rear Coil-overs |
![]() Welcome to the second of the 4 part Vancouver's Next Top Novice series. Competition is sure to be fierce as our 100+ novices that battled through the UBCSCC Slush Series continue for chances at prizes from Driver's Edge, cash, free events, and the most important - bragging rights. Vancouver's Next Top Novice #2 Date: Sunday, June 29th, 2008 Membership Required Location: BC Driving Centre Cost: $20 pre-registration via Karelo or $25 on-site There is absolutely ZERO TOLERANCE for any burnouts, reckless driving, or loud stereos on Ford Road at any time. Anyone caught breaking this rule will be immediately, and permanently, banned from all 3 local autocross clubs without warning. Please note: Tech closes at 8:30am sharp. If you are changing tires, this must be complete before you go through the tech inspection. Registration closes at 8:40am sharp. Please read over this event's Supplemental Regulations prior to signing up at: Supplemental Regulations Leads for this event: Event Chair: Mark Uhlmann Event Steward: Jared Powell-Williams Head of Course Design: TBD Head of Technical Inspection: Felix Chan Head of Registration: TBD Head of Workers: TBD Head of Timing & Scoring: Jessica Walker Head of Parking: TBD If you would like to volunteer for a position listed above, please post along with your registration info in this thread. If you are attending, but NOT SIGNING UP ON KARELO, please post as follows: Name: Car: Class: Novice: (Y/N) Hope to have you all out! Good luck from all of us in your UBCSCC Executive Team. |
Fiero Zen ![]() Senior Member ![]() ![]() Joined: 12 February 2007 Location: Canada Status: Offline Points: 276 |
Looks good to me
Yesterday is History
Tomorrow is a Mystery But Today is a Gift That is why it is called the Present |
Just signed up. Are you going to be able to make this one Nigel? |
As a spectator - hopefully |
Spectator...come on buddy:). Austin, man I am happy your in, make sure you post on the UBC site forum with your details, the bar code you will get on the event day with your membership, it's a decal that you scans you before each run, I just stuck it on my new helmet, picked it up this week. Cheers...hope others from the club can make it out |
Nice.. where'd you pick up the helmet? specs/$$??? Austin |
I picked it up from Don at PDM: http://www.pdm-racing.com/safety/bell.html There is also Drivers Edge that my buddy Larry suggested, for a helpmet the Pyrotect is good: http://www.driversedgeautosport.com/ It's a SA2005 rated helmet, tax in $168 for the open face which is better as I wear glasses. |
I drove by Drivers Edge on my way home from work but they are closed Mondays. I'll try again tomorrow. I checked out PDM as well. It was kinda after hours but I still was able to test fit the Pyrotech Open face & closed face helmets. I actually prefer the closed one for $248 but I'll check out a few more first.
The open face is good for me with glasses...the closed would be warmer on the hot days if we ever see any...lol
I picked up a helmet today a HJC closed face. Frank from Drivers Edge, great guy to talk to and very helpful with going over fit and the different models available. Gearing up for this Sunday WOooo!!! :) Austin |
Did you pick up the AR10?...nice helmet man:). I tried to find this shop on Monday, I will try tomorrow as I took the day off and have my suspension in AGAIN at Dales to tighten the front end up...and potentially new brake pads. We will need a lot of water and sun screen...real warm day ahead...which means really sticky tires I hope:). Good stuff bud |
Austin...make sure you post your details for Sunday...will be nice to see two Fiero's registered:) |
Yep that's the one. It was a bit more than I was hoping to spend, but it seemed to be the right one for me. I'll be checking my suspension as well in the next couple of days to make sure everythings tight. Heard it'll hit 30's this weekend, it's gonne be a scorcher! I registered online via Karelo but haven't gotten around to signing up to the forums yet. Been too busy and lazy lol Austin |
Do both of yourselves a massive favor and get a bottle of water wetter from either Lordco or Mopac. If the weather is going to be near as hot as expected and you are going to drive near as hard as expected, you are really going to want that stuff in your cooling system. Austin, Brian had his car over here last weekend to do some checks and we found that several of his ball joints needed to be greased. The shop that had worked on it I guess skipped over a few things. So that is one thing to give a good look over. Also I would not even bother checking, I would simply do it, pull both front wheels, and repack the front wheel bearings with a good synthetic grease. Even go as far as putting in new outer bearings. They are cheap, I think 10 bucks each. Edited by Capt Fiero |
Well...I have a new battery holder thanks to Blair...this baby won't move now:). If adding Water Wetter now means draining the cooling system doesn't it, don't put it in with old?. I am off tomorrow and will be at Dales at 8:30am:)...maybe call me Dave and suggest what I should do as I agree, I have wanted to add this to the system for some time. I checked all my pads and I am over 80%...I hope to go GA before July 16th...anyone have Edgars phone number as I have hubs.
To get the most from Water Wetter, you would drain your system, and replace with one bottle of water wetter and remainder being store bought distilled water only. However you WILL still see a benefit just adding it into your cooling system as is. When I use to run at Mission on a semi regular basis. In the spring I would drain my entire system and just run distilled water and water wetter. I don't know about the circuit you will be racing, however at Mission Raceway Park on the strip you were not allowed to have any antifreeze in your car. I would run straight water all sumer and to be honest, I even removed the rad fan for several months as the car never got hot enough to even boil over. I don't remember the specs off hand, but with a standard rad cap to keep pressure in the system, water won't boil until 230F or 240F. |
Mission race track is fine with anitifreeze, I may do a system flush tomorrow or just add this to my current. I checked out Redline and the big difference is seen with water only, not much with 50/50 mix. Edited by Bassman |
Page 123> |
