  New Posts New Posts RSS Feed - Transmission leak
Transmission leak
HarleeQuinn86 View Drop Down
Post Options Post Options   Quote HarleeQuinn86 Quote  Post ReplyReply Direct Link To This Post Topic: Transmission leak
    Posted: 29 August 2013 at 5:57pm
So I finally realized my leak was transmission. It looks like its coming
out of a hose near my back drivers side tire. How hard is it to fix/replace
that?
Nikki's Beaut:
Red 1986 Fiero GT
2.8L V6
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2013 at 7:13am
Going to assume you mean it's coming from one of the rubber lines that
goes from the tranny, heading left? Not from one of the hardlines itself (rust
etc).
Super easy.
Pop by Lordco and pick up about 3ft of transmission cooler line (not fuel
line, not vacuum line, not... well you get the idea). Get 6 new hose clamps
as well. I want to say it's 3/8" hose, but double check - it might be 5/16".
Stick a tray under that area to catch the small bit of ATF that will dump.
Slice the lines in the middle. Undo the hose clamps all the way. Now you've
got a free end you can grab and twist to pull the old lines off.
Note which one went to which spot (or just do them one at a time!).
Measure twice, cut once the new hoses. Longer is better.
Use extended tang clamps, and don't overtighten.
Run, cycle through gears, check for leaks.
Done!
