Velocity Channel North Star into a Fiero Monday |
Jim85GT ![]() Senior Member ![]() Joined: 04 October 2010 Location: Canada Status: Offline Points: 105 |
![]() ![]() ![]() ![]() Posted: 29 January 2017 at 5:22am |
To anyone interested, The Velocity Channel has a program set for 4 pm called Car Fix.
They are working on installing a North Star engine into a Fiero.. Please note, my cable service is from Eastlink in Delta so check your own system for times and or go online to see the program, if your interested.
That is totally Awesome Jim, thanks for the heads up. Do you know if the episode is a NEW episode or a repeat? As my PVR is set to record all NEW episodes of Car Fix.
Would like to see that,Discover Chanel on Mon.is it on line any where.
Cheers |
Hi Dave and Artic 1.
Yes it is a new episode on channel 788 the Velocity Channel for (Delta Cable) Eastlink. I haven't tried to find Car Fix online yet but if you have an Amazon stick or box, you should be able to pick it up about an hour prior to the broadcast. Note: the Velocity Channel is FREE for the month of January in Delta at least. Hope to see a new method of installing the engine although, we've already done it a few times.
beken ![]() Admin Group ![]() ![]() Joined: 12 February 2007 Location: Canada Status: Offline Points: 1438 |
I did not know that was on. Thanks for the heads up.
![]() ![]() Keep watching, they said there will be another episode about the Fiero later??? Sorry people. If I see anything coming up, in the near future, I will send another note.
