what engines will fit? |
rumonk ![]() Newbie ![]() Joined: 26 October 2009 Location: Canada Status: Offline Points: 41 |
![]() ![]() ![]() ![]() Posted: 29 October 2009 at 9:23pm |
i've got an 85 4cyl auto, with a blown motor, i'm hoping to just replace it 4cyl that will last me a year or two 'till i do an upgrade. i'm curious what other year/model engines will drop in easily? how much work would it be to go to a 2.8? thanks any info is great.
Find a V6 auto car that's wrecked - it's a fairly easy swap then.
what's the easiest and cheapest swap? what can i look forward too as far as cmputer, exhaust etc? thanks
Easiest? 4cyl out, 4cyl in.
Next easiest? 85/86 V6 AUTO. Don't look into a 4spd swap, or your 'easy' button just got stepped on. You take the WHOLE thing out of the V6 car, and simply swap it over. One tiny wiring change to add the line for the other injector bank. Steal the dash out of it, and your gauges are done. |
theres X2-4cyl Fieros @ pick a part-$125 compl ENG
this may seem like a stupid question, but a '84 4cyl will drop straight in? there's nothing i need to change from the '85? thanks
'84 was the wimpiest of the whole flock - but AFAIK there's no external changes to the 84 vs. 85.
If it's an auto -> auto, it'd be a simple in/out. |
i found a complete '84 w/auto it's only got 50K on professional rebuild engine. it was in a front end wreck but it still drives. everything else including interior is in great shape. 300$ for the whole thing. thanks for all the help and advice given.
