  New Posts New Posts RSS Feed - Muncie Exploded View
CFoss View Drop Down
Post Options Post Options   Quote CFoss Quote  Post ReplyReply Direct Link To This Post Topic: Muncie Exploded View
    Posted: 21 July 2008 at 11:00am
Anyone have an exploded view of the 4 speed Muncie?
I'm considering doing a phantom grip install and I want to scope it out ahead of time.
Thanks,
ZeroC View Drop Down
Post Options Post Options   Quote ZeroC Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2008 at 11:43am
lol i dont know why this thread title just reminds me of dave ;) loll
Edited by ZeroC
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2008 at 11:55am
Ya Ya, I know.   However I think its only been 3 Muncies that I blew up. 2 of which were 4spd cases, so I can't really be faulted for that, and 1 was due to a shift pin inside the transaxle popped.    However Chay, I will see what I can find for a Muncie rebuild sheet.  I have never had to rebuild one as frankly it usually costs 4x more to rebuild one than to replace one.
Post Options Post Options   Quote ZeroC Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2008 at 12:13pm
just teasin ;)
Austin View Drop Down
Post Options Post Options   Quote Austin Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2008 at 12:26pm
Originally posted by ZeroC ZeroC wrote:
lol i dont why this thread title just reminds me of dave ;) loll
Hahah I thought it was another destroyed tranny thread too
:P
Post Options Post Options   Quote ZeroC Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2008 at 1:13pm
search on pennocks about the phantom grip lsd ...i have seen some bad threads about it
Roadfury View Drop Down
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2008 at 4:39pm
http://www.fiero.nl/forum/Forum2/HTML/082235.html
What kind of driving are you planning on doing?
If this is the LSD im thinking about....
Do you like great handling around the corners?
OR
Do you like going straight?
if you like the turns dont go for the LSD
if you want to go straight then go ahead and get a lsd
(I only know this because I also offroad in my B2 and debated getting a rear locker.... i decided against it because it isnt a soley offroad vehicle.)
Post Options Post Options   Quote CFoss Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2008 at 10:23am
Well, given your comments I think you may not be aware of the difference between the two. Please correct me if I'm wrong 'cause I don't want to come off as arrogant.
A LSD is just that...limited slip. It will slip around a corner so long as you don't spin both wheels. It's actually an advantage in cornering as torque will transfer from the slipping wheel to the rolling wheel.
A locker depends on loose ground as one wheel has to slide in order for a turn to be made. Definately offroad use only, and then probably only in the sand/mud/snow, not on twisiting hill climb etc.
Post Options Post Options   Quote CFoss Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2008 at 10:28am
Thanks for the tip on Pennock's.
After reviewing the info I'm goign to go with one from EP Performance:
http://www.engineered.net/eplsd.htm
It'll have to wait till next year though, funds are a bit tight after all the stuff I've done.
