  New Posts New Posts RSS Feed - Nose idea for the Bomber
 Post Reply Post Reply Page  <123
Nexus View Drop Down
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2011 at 2:18pm
Idea 2 Version 1:
Version 2: Needs a bit more work but the idea is there
Charlie
84 SE
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2011 at 2:50pm
I like it better now that the lines flow better down below.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2011 at 4:58pm
What would that nose look like with the centre opening reduced in height to only the size of the silver "aero" part? In other words, don't have the opening intrude into the red "coupe" nose part, have the centre opening the same height as the lower brake vents.
It's all very subjective, but right now the "mouth" looks way too big IMO.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2011 at 5:41pm
It's got a Maserati vibe right now. Maybe a little Aston Martin.
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2011 at 8:45pm
I'll se what i can conjure up with the opening!!!
Charlie
84 SE
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2011 at 8:51pm
Retain the front belt line!
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2011 at 8:26pm
Ok it took me longer for some reason to make this look right but here it is
Idea 2, Version 3
Charlie
84 SE
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2011 at 8:27pm
some more tweaks coming with brake vents or running lights
edit:
Version 4:
Charlie
84 SE
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2011 at 12:57am
Hmm... Not sure if I'm as big a fan of these ones. From an aesthetic standpoint, I personally don't find them as attractive as your earlier work, and from an aerdynamic standpoint, I see less flow volume but the same amount od drag.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2011 at 1:12am
Originally posted by Nexus Nexus wrote:
Ok it took me longer for some reason to make this look right but here it is...
So why did you stick a license plate on these two latest variations when it wasn't on the earlier ones? Let's get that sucker off of there!
As I had stated earlier though, I'd also like to see the center opening the same height as the larger custom brake vents. Yes, the same larger custom brake vents which have now disappeared!  Jeez, it's difficult to get good help these days!
Don't worry about Tristan's concerns about "less flow volume". If this was a real Fiero, I suspect enough air would hit the rad coming up off the lower air dam.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2011 at 11:52pm
My point is that there's already going to be turbulence there from the fact there's airflow; Making it a small orifice where air will struggle to get through will increase turbulence, and thus drag, while simultaneously minimizing the amount of total volume of air flowed. If you're going to have an inlet, and thus a turbulent area - take advantage of it!
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2011 at 12:07am
Tristan, what speeds need to be reached for all this "turbulence" to be causing us an issue?
In other words, are we designing a race car or are we discussing mods for the typical grocery-getter Fiero that most of us putt around town in?
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2011 at 3:45am
The licence plate is there because I was having a hell of a time getting that section to look right, so I cheated...I'm sorry
I will see what I can do to make it more like you were saying Patrick
OK Romeo, I'll make another and see what we come up with...maybe the next idea is more to your liking!!
Charlie
84 SE
kharmata View Drop Down
Post Options Post Options   Quote kharmata Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2011 at 8:36am
Great theoretical analysis Tristan.
Kevin
08GSXR1000
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2011 at 6:33pm
ok so I grew bored of those designs and decided to fit the early 90's toyota supra front clip onto the car
I really like this design so here it is
idea 3 version 1: round holes for fog lights and brake vents included!!
Charlie
84 SE
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2011 at 7:07pm
Nexus, I gotta ask... Are you the reincarnation of 85SEnochie?
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2011 at 11:55pm
HELL YES, FIRST GEN SUPRA!
As for your question Patty, turbulence doesn't necessitate any speed - it's effect will happen any time there's airflow. It will scale up and become more and more noticable as speed goes up, and while you might not notice the reduced top speed, what one would notice is the reduced gas mileage (Especially on the highway) as a result of it. There's one thing I really tried to specialize in at school, it was aerodynamics. lol
Post Options Post Options   Quote Nexus Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2011 at 11:13am
I am not 85SEnochie...the GT I have is the first Fiero I have ever owned
I got the name Nexus from playing Half Life in 99 or 2000...needed a screen name and i heard my teacher talking about a "Nexus" and thought it was pretty cool so voila...11 years later it had followed me around internet life!!
Charlie
84 SE
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 1:42pm
Another good game which has a Nexus is Starcraft, and it's sequel.
So, are you an excellent fibre-glasser like our own Johnny Boy and Clynt? Any plans to bring the photoshops to fruition?
Post Options Post Options   Quote kharmata Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 3:03pm
Sorry its off topic but Nexus is also a new samsung android cell
phone.
Kevin
08GSXR1000
