  New Posts New Posts RSS Feed - Slave Cylinder has oil around bleeder
littleV8fiero View Drop Down
Post Options Post Options   Quote littleV8fiero Quote  Post ReplyReply Direct Link To This Post Topic: Slave Cylinder has oil around bleeder
    Posted: 09 July 2007 at 7:04pm
My new slave cylinder has oil all around the bleeder valve. It's not thick, just looks like it's sweating. It's about 2 inches across. It' won't go away. However the master cylinder is not leaking or showing any signs that it's losing fluid. Just wondering if this is normal? I'm having troubles getting the rod to move the 1.15 inches. Do you guys have any ideas? I've heard of putting a longer rod in, would this help.
Thanks Andrew
Post Options Post Options   Quote littleV8fiero Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2007 at 7:09pm
Oh BTW the clutch isn't releasing. It's only traveling about 3/4 of an inch. Would this mean I have air in my lines and or a bad slave cylinder?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2007 at 10:28pm
Well depending on what you have replaced, I would install a new slave first, then a new master and use a stock rod for the slave.  I ran an Isuze 5spd on my 4.9 Caddy V8 in my Fiero for years without issue and the Isuzu requires the most travel in order to shift correcly.
If you have not used a power bleeder on it, I would think about renting one or borrowing one.
Post Options Post Options   Quote littleV8fiero Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2007 at 11:36am
Awesome, thanks for your ideas!! I'll keep ya posted!
