Wheel offsets and spacer plates |
Post Reply | Page <1 234 |
Author | ||
Colby
Admin Group Joined: 30 March 2009 Location: Abbotsford/Sask Status: Offline Points: 665 |
Post Options Quote Reply Posted: 28 July 2011 at 4:31pm | |
Yes, but I wasn't sure if I had already made that clear in this topic. |
Zac88GT
Newbie Joined: 31 July 2008 Location: Canada Status: Offline Points: 20 |
Post Options Quote Reply Posted: 28 July 2011 at 7:44pm | |
Yes the position of the spokes will have an influence on the center of gravity (CG) of the wheel and thus influence some of the dynamic loading that the bearing supports. However, it is insignificant in the grand scheme of things because of the minimal change in CG, and the wheel only weighs ~15lbs compared to the 750lb corner weight. If you want to take the spoke position into account then you'll need to know what brand of wheels they are, their center of gravity, their mass moments of inertia, tire weights, tire stiffness and moments of inertia, and a thousand other parameters to model the multi-degree of freedom dynamic system. Formula 1 engineers "might" consider it but I doubt it. Your intuition is correct but you need to look at what the greatest forces involved are. The force from the 15lb wheel will act through the center of gravity, where the 750lb force of supporting the car in that corner will act through the center of the contact patch (the center of the wheel) and not the center of gravity. Hope that helps. |
Colby
Post Options Quote Reply Posted: 28 July 2011 at 11:42pm | |
Thanks for clearing that up.
Patrick
Post Options Quote Reply Posted: 09 September 2011 at 9:13pm | |
I finally picked up these 1" spacers from the fella who's address I use in Blaine for any/all of my US eBay orders. Ended up costing $73(Cdn) total for each pair. One pair for me, and one pair for another club member who I'll try and get to show and tell at the meeting. I like 'em! Nicely made, don't look cheap. Pushes the rear wheels out so that the tires just barely stick out beyond the fender lip. Very manly, good for 3/10's off my next autocross run. Yeah yeah, I should've taken before and after pictures... but I didn't. So you'll all have to line up in person tomorrow at the club meeting to gawk in amazement.
Colby
Post Options Quote Reply Posted: 09 September 2011 at 9:47pm | |
Actually, if anything, expect to hit a couple more cones with your rear wheels now. |
Patrick
Post Options Quote Reply Posted: 09 September 2011 at 10:03pm | |
You'll be having the same issue when you put the wheel on your car with the proper offset.
Patrick
Post Options Quote Reply Posted: 11 September 2011 at 3:54pm | |
I had a chance to test the wheel spacers last night going and coming back from the club meeting. I'm happy to report that the hub-centric part of them works very well. I didn't go crazy, but I had the duke up to 120 km (for short spurts between congestion on the freeway) and there was no added vibration at all. I'm pleased.
Car-2-Lo
Senior Post God Joined: 14 February 2007 Location: Canada Status: Offline Points: 1266 |
Post Options Quote Reply Posted: 12 September 2011 at 7:33pm | |
Thanks Patrick Yesterday I installed the wheel spacers on RBS in front to have the wide track look, Fred and I pushed RBS inside the garage and there no vibration and really smooth, RBS is happy |
Patrick
Post Options Quote Reply Posted: 12 September 2011 at 8:11pm | |
Oh no, what did Fred hit this time?!!! (Inside joke) |
