3.5L LX9 Swap into ’86 2M6 4 speed |
Page <12345> |
Author | ||||
bcampbell ![]() Senior Member ![]() ![]() Joined: 14 November 2011 Location: Canada Status: Offline Points: 160 |
Some fairly minor updates. Got 3 of 4 rubber cradle
bushings out so far, hopefully the last one will be out by Monday and hopefully the engine will be going back into the car Monday as well. I'm debating whether or not I should do the polyurethane bushings on my rear control arms now as well but I assume that means getting a rear alignment. If they hadn't come with the engine I probably never would have bought them. Anybody have personal experiences they could share as to what differences aluminium cradle bushings and/or polyurethane control arm bushings make? Here's a pic of the engine about to be mounted to the cradle finally: ![]() In the next pic you'll see the motor mount nut is almost touching the new oil pan. I carefully threaded it as I lowered the engine onto the mount because I did not feel comfortable 'clearancing' the oil pan. ![]() Another pic of the complete cradle assembly: ![]() Next question I have is about the ignition coils. Are they in the right order? (This is the way they were when I got them). Edit: These are indeed in the correct order. ![]() And finally I got an alternator and found a belt to fit (IIRC the size was 640). Originally I wasn't going to use the idler pulley right by the alternator, but since the belt was too short otherwise and I didn't want to go back to Lordco for a fourth time, I added it and the belt fit great. It's just as well as it gives the alternator a bit more grip. And for the record I ended up buying an alternator for a '99 Cavalier 2.4L as it came close to bolting up to the 3500 alt bracket and was only $55 (we'll see how long it lasts though). The two bolt holes on the side line up and the through bolt is a bit off but I think it will be fine for now. On my LT1 in my other car my A/C delete pulley is only held on by 2/3 bolts as well and it's held up fine. I did have to switch the pulley to one from an '01 Malibu though because the 2.4 Cavalier pulley was for a 5-rib belt. I still need to get a pigtail for the alternator. Anyways that's the end of my rant. ![]() CFoss: If I'm gonna be borrowing your tuning equipment we should probably meet up some time. What part of Duncan do you live in? |
Looking really good.
When you're ready, I'm near Queen of Angels school, towards Maple Bay on Tzouhalem road.
When do you think you'll need it? Do you want me to see if I have a prom that'll work after you're done tuning? I think I have some EEproms (fast rewritable) around here somewhere. I'm jealous of your serpentine belt. I hate the slippage on the old v belts! Chay |
A few more things done. Pretty much all the wiring is
finished except for wiring in the new alternator but I'm gonna wait till tomorrow because it's really cold outside. I also threw some paint on the parts of the cradle starting to rust. My G1 adapter also came in the mail today and I got a knock sensor for $11 from Maxwell's and an alternator pigtail for free from Blacky's.
I hate V-belts just as much as you do :P I ordered a couple of chips with the G1 so I think that's covered. The car is parked in Cowichan Bay near the building called the 'Old Firehall' so if you want to come see the car let me know. |
I was also thinking since I don't know yet how my exhaust
is going to be routed and (correct me if I'm wrong) the 7730 ECM only supports 1 O2 sensor, I would use the existing O2 bungs and tune 1 bank at a time. To simplify switching between O2 sensors I would build an extension harness to reach around to the O2 sensor on the opposite side. I just don't know yet how the Y-pipe will be routed/if I will have a Y-pipe. |
Oh and I'll be ready to start the engine probably in a
little under two weeks. I'd be ready to start earlier but at the moment I'm low on funds so can't spend anything on exhaust manifold gaskets or fuel injection line or other misc. items. For the coolant hoses I'm going to see if any of my L98 hoses fit at all since I have no use for them since I swapped the engine in my Firebird (they're brand new blue Goodyear hoses). I am hoping to get the engine in the car tomorrow. |
Right on!
My parents live off of Payne Rd. (About 2 minutes from the old firehall) so I do know what you're talking about! The 7730 does only support 1 02. I suspect that both banks will perform about the same, so there will be no need to switch back and forth. You may want to do it just to check everything is similar. You are using batch fire anyway, so you can't tune the sides independently. " I just don't know yet how the Y-pipe will be routed/if I will have a Y-pipe. " Does this mean you're considering a dual exhaust? Chay |
Yes I am considering a dual exhaust. Is it just me being crazy or does it simplify things? I'm thinking a pipe coming down from each manifold, turning towards opposite sides of the car and just glasspack mufflers straight out to the rear. (Which might sound like crap I guess but I can deal with annoying exhaust until I can afford something better) Throttle body adapter plate arrived today, so I bolted that up. It seems like no-one makes gaskets for the 3.5 throttle body (stock is an o-ring), so I just used black gasket maker to seal it up and I'm thinking that will be fine for a while. I guess I could get some of that generic gasket paper and cut it out myself but I don't really think it's necessary for now. I guess I'll find out soon anyway though. I think the wiring is to the point where I can't really go any further until the engine is in the car. It's pretty much all routed where I want it and ready to be loomed, I just have to figure out the alternator wiring and add the 7730 ECM grounds (which I'll probably do once the engine is in the car. I was planning on getting the engine in on my days off (Monday and Tuesday), but it's been super cold out so I decided to hold off. In any case I got 3/4 aluminium cradle bushings installed. Those front ones seem super tight compared to the rears but they're doable. I threw some anti-sieze on them so that there's a possibility of removing them in the future. I'll upload some more pics soon. |
I don't think you are crazy, but I don't think there is any performance enhancement. The wye pipe can be kinda hard to build if you don't have the tools to do it.
I did some 'inside work' on my car the last few days. Kinda cold and still dark by 6 or so. I'm going to use a single 2.5 or 3" glasspack on my car. I don't really care how it sounds though, just how it goes! I'll have the turbo in the way consuming some noise too. The gasket maker will make a mess if you have to remove the throttle body. I've used the generic in the past with lots of success. I actually have some hanging around if you need it. Chay |
So today I believe I've finished up the wiring except for
the two remaining ECM grounds. I'm hoping the way I wired the alternator is correct but I'll find out soon enough. I wired the "Alternator field duty cycle signal" wire to the brown wire on the Fiero harness, which as far as I can tell goes to the warning light in the dash, and the "Alternator output - Regulator reference voltage" wire to the red wire on the Fiero harness that connects to the large wire going to the charging post. I left the "Fuse output - battery" wire alone because the other 99 Cavalier wiring diagram I used didn't even mention that wire. This is the method I used to get my front solid cradle bushings installed: ![]() I stripped two or three bolts using this method but I eventually got them both in. This is a comparison of the 2.8 manifolds and the 3.5 manifolds: ![]() And some other random pics: G1 adapter: ![]() Throttle body adapter: ![]() O2 sensor that came with the motor. Looks in much better shape than the O2 sensor I pulled out of the 2.8's exhaust: ![]() Wiring finished: ![]() And everything draped over the engine ready to be installed: ![]() Edit to add my todo list to complete the project: - Install cradle in car and finally get the car back on the ground! - Fuel lines. I need something to attach the quick- disconnect side of the vette fuel filter to either fuel injection hose or one of the stock hard lines. The 'in' side and return line can just be attached with rubber fuel injection hose I think. - Fill engine with oil... any recommendations? - Fill engine with coolant... any suggestions on getting all the air out? I was thinking just raising the front of the car high enough that it's the highest point in the system. - Get an exhaust gasket and install rear exhaust manifold - Hook up my fuel pressure gauge so I can monitor the fuel pressure when trying to start the engine - Wire in two more ECM grounds - Start the engine and troubleshoot when it doesn't start! - Tune - Missing anything? I'm thinking of buying a base tune from Superdave on the 60degreev6 forum. It will cost $50 but should get me to the point where I'll only really need to dial in the tune to my specific needs. Otherwise I'll be starting out with a 3.1 tune. My friend said I could borrow his AEM wideband so that should work out. Since I have an O2 bung in each manifold I can run the ECM off one and have the wideband in the other. |
If there is a starting tune it's always nice to have, that's for sure. It'll save you a bunch of time.
I like the zif socket on the G1. Mine's an old press socket, the zifs are much nicer for repeated connections. 1 thing I did do was sharpie the code revision and type ($whatever) on the ecm so I woudn't forget what I have in there. I just checked that out so I was glad it was there. Amazing what you forget over a year! Oil...there's a way to start a flame war! I always ask if anyone has ever worn an engine out. I haven't yet and I've really tried (I went broke trying to finish off my old Ford 351...just wouldn't die, had to sell it). I was looking at some braided fuel line you can attach tips to so you can custom it up (Summit racing). Something like this: http://www.summitracing.com/search/Part-Type/Fuel-System-Plu mbing-Kits/?keyword=braided+fuel+line I haven't quite got there though. Chay |
Check this out too:
http://www.jegs.com/c/Fittings-Hose/181705/10002/-1?gclid=CJ Kn44nhyK4CFQV_hwodSRdsBg Chay |
Thanks for the tips on the fuel lines. I might see if I can find something at a junkyard too that will fit. It looks like the G6 calls for a 5w-30 oil. Not sure if I'll go synthetic or not. I test-fitted some radiator hoses today and I think I can make the ones I already have work. Here are the hoses: ![]() They're for an 87-92 IIRC F-body and they're Goodyear Super Hi-Miler hoses. They came with my Firebird I bought last year and have no use for them in that car but it looks like they just might fit a 3.5L in a Fiero. I'm thinking this one will work if I snip it where my hand is (passenger's side): ![]() And this one might work without trimming on the driver's side: ![]() I do have questions about the heater core lines though. I see there are two on the fiero. This one on the trunk side below the dog-bone: ![]() which actually seems to just come out to beside this one on the firewall side: ![]() Which one is supply and which one is return? I should probably replace the battery tray soon... ![]() And my driver's side hinge is damaged: ![]() You can see where the metal cable has come out of it's clamp and there's nothing to prevent the hinge from lifting futher. Does the hinge need to be replaced? If so I'm thinking I might just remove it and install a strut on that side instead. |
Engine was installed today. Good news is that the rad
hoses I have will work with the new engine. I did find that there is hardly any room for the shifter cables but they fit, and I found that the clutch is now very soft. So I guess the slave needs to be bled. Also got some things to try out with the fuel system and hooked up my fuel pressure gauge. I'll need a vacuum line for the brake booster to come around to the front of the engine from the rear. The alternator was hitting the stock dogbone mount so I had to grind off some of it to get the engine in. I think I'll be cutting it off completely in the end since I didn't really trim enough of it off and it will probably knock when the engine rocks. Pics to come soon |
The heater core doesn't really have an in and out I don't think.
Dawg |
So I started attaching a few more things today. Got most
of the coolant hoses hooked up, hooked up a brake booster line, put my air cleaner assembly back in place, etc... Here are the pics: At this point the cradle was nearly lined up. Btw instead of spending time building a rolling dolly for the cradle, I just had the cradle on the lift legs and dropped the car onto the cradle. Lining it up was difficult at first but mostly because the alternator was hitting the factory dogbone mount. After removing the alternator it practically lined itself up. ![]() And a couple pics of the engine finally installed in the car: ![]() ![]() Put the brakes back on today: ![]() This is a pic of where I had to clearance the dogbone mount. I'll most likely end up taking the rest off as when the engine rocks I can see it making a horrible knocking sound... ![]() For the brake booster line I used some rubber hose that used to be attached to the charcoal canister in my Firebird and hooked that up to the 2.8's booster hard line, which ended up going to the rubber line on the firewall side. A red circle shows where the hard line attaches. Looks decently clean to me: ![]() Some pics of the rad hoses: A couple of inches had to be trimmed off this one, otherwise it's a perfect fit: ![]() The flared end needed to be trimmed off this one: ![]() And the last one was a perfect fit with no trimming: ![]() For the other heater core line I plan on putting in a place to fill the coolant from the engine bay (red circle in closeup of engine in car). I found an EVAP solenoid that came on my LT1. Anyone know if it will work with a 7730 ECM? ![]() And for the intake I grabbed a 6" piece of 3" pipe from Canadian Tire and I'm thinking if I get a 45* coupler it will work out: ![]() |
So a few updates for tonight. First off, I finished
installing everything and was able to get the engine cranking but it's not firing. I believe it's not getting fuel. More on that later. For the fuel system, I got 4 (3 x 3/8, 1 x 5/16) Dorman quick disconnect adapters and 4 ft. of fuel injection hose and clamped everything down. Fuel pressure builds and holds at about 55 psi and there have been no leaks. I also added a ground wire for the fuel filter since it's zip-tied in place and it has a ground strap on it that's designed to ground static developed by fuel flowing through the filter. ![]() ![]() ![]() Pic of the G1 adapter installed in the ECM: ![]() Is it just me or is there more room in front of the engine with this motor? ![]() Pic of the firewall side of the engine from underneath: ![]() Finished my EGR block-off plate today. Used a piece of scrap metal that used to do something to hold on the inner bumper on my Firebird. It's not a work of art but it gets the job done. For the EVAP solenoid block-off I was able to use an LT1 manifold EGR block-off plate. ![]() ![]() For the intake I was able to get a 45* coupler from Super Street Imports in Victoria for $20. It fits pretty nicely although I had to heat it up to slip it over the air cleaner (3"): ![]() In the next pic you can see my engine-side coolant filler. $6.50 at Canadian Tire (supposed to be used to flush cooling system with a garden hose). Filling was a slow process but I do believe it works: ![]() And finally a pic of the engine just about ready to be started: ![]() For grounds I used the factory ground strap and added another 4 gauge ground strap. I'm using the stock battery cables. Now on to the starting problems. First thing I did when it didn't fire was a compression test/test for spark plugs firing. I did a compression test on the rear 3 cylinders and they read 200, 190, and 200; good compression in my opinion. At the same time I found that all 6 cylinders are getting spark (since each coil sparks a plug on each bank, it should only be necessary to check 3 cylinders to verify spark on all 6). Since I'm not even getting the odd fire happening at all, I'm convinced the issue is fuel related. My friend had the idea that since the regulator is near the tank there could be a lot of air in the system. We then bled all the air out of the system by opening the schrader valve and re-priming. I did find that after 'bleeding' the fuel rail, my gauge indicated that it was priming much faster than before (not having to compress air I guess). However that didn't change anything. As for wiring, I did a basic test to see if the injector harness was getting a signal to fire. I was reading about 12V at the injector power wire and during cranking I saw fluctuating readings at the ECM ground(?) wires. Someone please correct me if I'm wrong but to me this indicates the injectors are getting a signal to fire. Another possibility I suppose is that the tune I'm trying to use (91 3.1L J-body) isn't giving it sufficient fuel to start the engine. There seems to be no fuel exiting the exhaust manifolds. One thing that seemed strange to me is that I can't get any data to come through the ALDL port (using my ALDL cable). Is it possible to get data to come through while using the emulator? In tunerpro RT it just says "DA: Connecting" when I'm trying to get a datastream. I've already verified that this cable works on my friend's 93 Sonoma. Oh and I also tried to jumper the A and B pins on the connector but that didn't cause the check engine light to flash. However, the check engine light DOES light up with key on, engine off as it should. That indicates that the ECM is at least partially working, I think. I'm just thinking if I could get a datastream that it will help determine if the sensors are getting proper readings and it could also help to indicate any wiring issues. Anyways that's where I've left it for tonight, hopefully tomorrow with a fresh perspective I can make some more progress. |
Can you hear the injectors clicking? IF you have an automotive stethescope and can get to the injectors, use it and the injector clicking should be easily audible. When you say the injector power wire, you mean the one going from the injector to the ecm right (Not the solid +12 one)? If so, you are correct, the wire should go to ground to fire the injector so what you saw is a good thing. I have a handheld scope we can hook up to further analyze this if you want. That way you can actually see the duty cycle, and period of the injector shot.
I don't remember the '7730 needing a-b. It does require a 2 transistor type cable though, where some of the older ecm only require the 1 transistor type. This could be your issue. I can build you one if you want. The one I have is in use on my boat at the moment. I have found Tunerpro to be more finiky than winaldl, but for the '7730 winaldl won't work (too fast).
Search on 3rd gen for some alternative programs that are stand alone. I know I saw some, but I got the tunerpro working.
How did you make out with finding an wideband o2 sensor? I just ordered one which does logging (Zeitronix ZT-2) after I got my last one wet (It died a sad sad death). I'd highly recommed something like it, especially for power enrich settings. I found that I didn't really tune with the ecm, I used the wideband mainly. It is still good to nail down the blm's with a good tune though, so you need it, but it's a little less important.
Chay |
I haven't listened for the injectors and don't have an automotive stethescope
I've tested both wires (to make sure it's getting constant power as well)
The cable I'm using has been known to work with a 7730. It's from aldlcable.com I've also tried using Freescan to get data as that's what I use with my other car. Did I also mention that the fan always turns on with the key in the on position?
I can borrow a wideband from a friend but haven't done so yet. |
Did some more testing today and it looks like all but one
of my injectors are stuck. They don't look dirty but I guess after sitting for a few years they've just gotten stuck. I can get the #5 injector to fire by manually jumping it with a 9V battery but the rest of the injectors aren't opening at all. Another issue is that with the fuel rail out and the engine cranking, it doesn't look like it's firing #5 anyway. It may be computer related because I still can't get a datastream after trying a couple different code masks. I also double checked the pinouts on the ECM connectors and they all appear fine. It doesn't seem normal that the fan always runs with the key in the on position either. Tomorrow I'll take the injectors up to Action Fuel Injection in Nanaimo and hopefully they can get them cleaned for a reasonable price. |
Page <12345> |
