88 Cradle swap rear brake line |
![]() ![]() ![]() ![]() Posted: 08 September 2008 at 11:26am |
Anyone who has done the swap...any part numbers or suggestions on where to source the longer brake lines needed? Are they Lordco specials or do you have to custom order them from someplace?
Thanks,
Chay |
I used -4 lines, and an inverted flare to -4, and a banjo to -4 adaptor.
THEN... I found out it was WAY cheaper and easier.... to simply bend the flex line to the rear of the axle, and use the stock flex hose! :) |
It's just so crazy it might work.
I'll try it. Thanks, Chay |
