Alternators |
mxracer208 ![]() Member ![]() Joined: 28 October 2009 Location: Canada Status: Offline Points: 68 |
![]() ![]() ![]() ![]() Posted: 31 December 2010 at 12:03pm |
Why are there so many and how do you know which one you
need? |
Non AC 84-86: Low amp two wire. AC 84-86: High amp two wire. Non AC 87-88: Low amp single wire. AC 87-88: High amp single wire.
Really, the gentleman you're buying from should be able to tell you which one you'll need, although you can swap to a higher amp one for speakers, and you can switch over to single wire for ease of access. |
Okay, thanks. Is 80 amps enough for AC?
I believe that's what it is... You could try google, I'm sure it's posted. If not, the good doctor here will know.
