Clutch wont engage |
![]() ![]() ![]() ![]() Posted: 06 June 2008 at 4:31pm |
No matter how may times we bleed the system it won't engage the clutch..... Put in a new slave cylinder today but still nothing!!!!!! Is there a common problem with these? PS its a 4spd 85GT Edited by Roadfury |
Use a power bleeder if you have access to one.
They ARE a PITA to bleed. Took me many many times to get a technique down. If you pull the rod out of the slave - the pedal should be rock hard (DONT push with your FOOT though!!!!!!!!!!!!!!!!!!!!!!!!!! No more pressure than you can get with ONE finger) if you've got all the air out. |
