Engine stall??? |
ryanwmitchell ![]() Newbie ![]() ![]() Joined: 28 January 2013 Location: Canada Status: Offline Points: 46 |
![]() ![]() ![]() ![]() Posted: 28 January 2013 at 6:44pm |
basicall what is happening is when i am going slow or start from a stop and
give my engine gas it drops almost all the way out and i have had it shut off completely in traffic, sometimes just when sitting there it stalls. Any idea what i should try to fix or what is happening its not the O2 sensor i changed that and i have also tried unplugging my map sensor that didnt change anything any help would be much appreciated??? |
Ryan, 86 Fiero GT fastback V6 orange and black
auto or standard
bcampbell ![]() Senior Member ![]() ![]() Joined: 14 November 2011 Location: Canada Status: Offline Points: 160 |
Warm, cold, or both?
'89 Firebird 3500T, T56 |
it is an automatic and it does it warm and cold
tcc lock up solenoid
had similar issues unplug it and see it if helps 4 wire plug next to the kickdown cable on the tranny |
Advance your ignition timing, if you have worn ignition parts, it can make your ignition act like it is retarded and cause an automatic Fiero to stall. If the timing helps, then go out and buy a new MSD Cap and Rotor and New Wires and New Plugs, then return your timing to 12 degree's. Other issue can be the IAC but you said it does not have the problem all the time, so I would tend to lean towards the car needing a tune up with "GOOD" parts. |
sweet thanks ill give it a try lol can you describe where the kickdown cable
is lol im kinda new to calling parts by there name ive stripped my fiero down before but dont know the proper names for parts lol i should probs get on learning them |
Thanks capt i will get the timing adjusted and see if that helps and ive
already replaced 3 of the plugs and wires just working at getting to those hard to reach back three haha. and i will take a look at my IAC thanks for all the help!!!!!!! |
http://fierodomain.com/articles/repair-articles/44-how-to-re place-the-tcc-trans-lock-up-solenoid really easy to see if its the problem ...unplug it and go for a drive ...if it still does it then dave may be on to something ( but he is never right )...lol :) |
k ill give it a try once i get my new throttle cable in lol my snapped while
driving so waiting on that from the fiero store but i guess in a couple weeks ill post back on here and tell how it goes thanks again for all the help!!!! much appreciated |
Ive got 2 Autos an had the same Problm!
The link ZeroC posted is a good one,pics a bit crappy but.Dont make the same mistake i made,an had to pull it apart again ? there are TWO components in line. First the lockup solenoid then a pressure switch. change them both.a little tricky getting the pan off-Tight fit- it comes out the top an there 2 brackits to come off , its about 4Hrs with your 3/8 craftmans ratchet set,12mm is the size of the pan bolts i think.Good luck |
Thanks for all the the help i am going to check that out in the next few days
prbably i cleaned my iac it had a little bit of carbon on it or dirt and that seemed to help with the idle to and i pulled and reset codes it says i need a new map but im going to double check that |
Hey there everyone so i figure either the some sensors are working and
then not working or its my transmission that is brokencause sometimes when i shift into gear it makes the car move and i get a kick out of it other times i do not and today when going 30 the engine almost cut out and stalled so not really sure about my transmission on this thing! |
