  New Posts New Posts RSS Feed - Front Brake Issue
Front Brake Issue
Roadfury View Drop Down
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Topic: Front Brake Issue
    Posted: 11 February 2010 at 6:24pm
So the front brakes on my 85GT are sticking. Both sides. I dont think it's the caliper because the pistons still slide back when you put a c-clamp on them. They also become "unstuck" when you pry between the hub and caliper. The rotors are pretty worn, there is a lip on the outside of them, and the pads are brand new. Also bled one side quick and it was pretty gross, and had some crap in it. Suggestions?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2010 at 6:37pm
In the first thread where you brought up your "sticking" brakes, I suggested you have a look at This thread as it may be relevant.
Take the calipers off and check to see if the sliders are in good shape or not. Lubricate and reassemble.
And you should at least bleed all the calipers until clear fluid comes out.
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2010 at 6:52pm
Thanks Patrick, I did do that, the sliders were fine, i cleaned them up and never-seazed them, i will be doing a more complete bleed job tommorow though
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2010 at 10:42pm
Originally posted by Roadfury Roadfury wrote:
...the sliders were fine, i cleaned them up and never-seazed them
What exactly do you mean by "never-seazed them"?
I hope you didn't apply anti-seize compound to the O-rings and polished surface of the caliper sliders!
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2010 at 3:25am
If you can't press the piston in by hand with the cap off the master, I would replace both front brake hoses.  I see happen a lot the hoses as they get old start to collapse internally, and only allow fluid to move in one direction.
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2010 at 11:41pm
My shop teacher told us to do it that way, and thats what my dad recommend when I did that, I've never heard you shouldn't put never-seaze on the sliders, so I google'd it :P, and it seems to have sorta a 50-50 split of people saying use it vs people saying don't use it.
But anywho, we bled the fronts again and with no pressure applyed to the brake petal after taking your foot off them with the bleeder screw open there was still fluid being pushed out, so I replaced Master cylinder and calipers and problem solved.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2010 at 11:49pm
Are you sure you (or they) aren't referring to putting anti-seize compound on the threads of the caliper slider bolts
It's a special lubricant (such as Sil-Glyde) that goes on the sliders and O-rings, not anti-seize compound!
How To Grease Brake Calipers
Post Options Post Options   Quote Roadfury Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 12:01am
Permatex® Anti-Seize Lubricant
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Temperature range: -60°F to 1600°F (-51°Cto 871°C). Salt, corrosion and moisture resistant – ideal for marine use. Non-aerosol version meets Mil Spec #907E. Aerosol - Level 3*
  anti seize is a lubricant, but yes the teacher demo'd the complete re-assembly with coating the pins in anti-seize, and my dad did the pins on the passenger side with me doing the drivers side right next to him.
What o-rings are you talking about? The rubber boots by the head of the bolt?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 12:03am
I'm not trying to be rude here, but I honestly don't think you should be doing your brakes!!!
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 12:42am
Ummm....I'm going to chime in hear and say it's very common to put anti-seize on caliper slides.  Be they shoulder bolts or otherwise.
Anti-seize compounds are high pressure lubricants that work well on slow moving surfaces like calipers.  They're very thick and dense which makes them stay put and also makes them less likely to run when the calipers get hot..  You need to be careful not to put too much on, just a thin layer is all you need.  You don't want any getting on the pads.
Cheers.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 12:58am
It may be "common", but is it wise to do so? I'd think the last thing you'd want to lubricate the sliders and O-rings with is something that has fine metal particles in it.
I'll have to google this...
[EDIT] I looked around and found nothing from a reputable source that promoted the use of anti-seize compound (normally used on threaded fasteners) on brake caliper sliders and O-rings. If someone has a link, please post it.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 10:30am
Well I am going to chime in here too.  I have always been under the impression that the metal particles in copper coat antisieze would damage the rubber O-Rings that the slides ride on, so I always grease the sliders with bearing/ball joint grease from my grease gun, then use the anti size on the threads only of the caliper bolt.  So far it has always worked good for me doing it that way.  I actually put a few pumps of the grease gun into the caliper slider hole before I push the sliders back in as there is reservoir of sorts inside there.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 12:40pm
I can't comment as to the different make-ups of grease, but all the shops I've ever worked at have told us to grease the slide pins when doing brake jobs as well. Assuming you haven't used up a couple ounces worth, it should never enter the hydraulic system, or get in between the pad and rotor.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 2:03pm
I use a product called Never Seize.  It's a slurry really.  The particles are very very small.
In this specific case, the O rings won't be damaged because the movement is so slow it's basically static.  Grease is fine also.  As long as the lubricant is still rather thick at temperature and stays put, you'll be fine.
The main reason I like this product is it's a VERY high pressure and therefore high temp lubricant.  It stays where you put it under huge loads.  Even regular grease would get pushed away before this stuff moves.
Over kill, you bet. But it certainly won't hurt anything in this application.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 12:22am
No offense Damien, but I'd still like to see something official on the use of anti-seize compound on caliper sliders.
I looked around google and found nothing from a reputable source that promoted the use of anti-seize compound (normally used on threaded fasteners) on brake caliper sliders and O-rings. If someone has a link, please post it.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 8:52pm
Just go to a dealership and ask them what they recommend, I can all-but-garauntee you they'll suggest the use of an anti-sieze compound on the slider bolts. There's literally no danger in using a non-abraisive anti-sieze, whereas there is a danger in not doing so (Binding).
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 9:33pm
Just go to a dealership and ask them what they recommend...
I find it amazing that so far not one link to a reputable site from among the entire internet universe has been supplied by anyone which clearly states that anti-seize compound is perfectly acceptable to use on caliper sliders.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 10:24pm
Patrick, not every mechanics trick is going to be found on the internet.
Perhaps a better way to go for a researcher like yourself is to study up on lubricants.  This way you can develop the base knowledge to make up your own mind.  I assure you the science behind my comments is sound.
Besides, have you actually found a reference that says this product shouldn't be used for this purpose?  If not, what is the basis of your doubt?
Why not take the advice of people that have done this for decades?  Well, at least 2 decades....:)  I've done at least 200 brake jobs in my lifetime and to my knowledge no one has ever had a problem with any of them.
I'm curious, what kind of credentials would someone have to have before you would take their word on something like this?  Some link to a site on the internet seems to me to pale in comparison to an experienced local club contact that has shown me that their head is screwed on right.
Just something to think about, no stress.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 11:02pm
I'm leery of a product being promoted for a specific task when even the manufacturer's Technical Data Sheet mentions nothing about it being used for such a purpose.
Compare the properties of that product to this one...
Permatex® Ceramic Extreme Brake Parts Lubricant
Or this one...
Permatex® Ultra Disc Brake Caliper Lube
Damien, perhaps you could supply a link to the Technical Data Sheet of the particular product that you've been using on caliper sliders.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 11:46pm
Why exactly?
I constantly use products to accomplish tasks they were never designed for.  It's called "thinking out of the box."
Just because the tube says chrome polish doesn't mean it can't polish some other material......like plastic.
Once you understand how the product functions you can then use it in other situations.  It's done all the time.
Again what is the basis behind your doubt?  Just out of habit?
I'd like to know.
