  New Posts New Posts RSS Feed - Big Brake Booster
Big Brake Booster
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Topic: Big Brake Booster
    Posted: 03 August 2010 at 7:11pm
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2010 at 7:13pm
"Product not listed" brother. As for brakes, I should have a pleasant surprise for you to see next weekend.
Nevermind, you fixed it. lol
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2010 at 7:27pm
Larger Brake Booster $189.99
Click to enlarge
Coming later this fall!
This larger brake booster will significantly increase the braking ability of your 84-88 Pontiac Fiero. This is a direct bolt in replacement.  Some modification to the sheet metal under the brake booster is necessary.
See the whole story on Pennocks:
http://www.fiero.nl/forum/Forum2/HTML/072173.html
Thanks go to Phil from Coventry RI for starting this larger brake booster idea.
 My larger diameter brake boosters will have the correct size/length banjo. No cutting or welding is needed. Typically a brake banjo is 9 mm in diameter. Mine will have a heavy duty 10 mm banjo.
NOTE: Do not add to cart. They are not in stock yet.
Shipping to be determined after I have them in stock.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2010 at 7:39pm
Huh?...lol
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2010 at 7:57pm
Then there is this from FS...I just need part details, need to call Blair:)
http://www.fierostore.com/Product/Detail.aspx?s=56057&lp =56820
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2010 at 8:38pm
Ok, after reading I am going to wait for Rodney's Booster, and I have arrangement for a Big Bore cylinder, install both your good, if one then Booster first, then Cylinder.
Next year:)...Xmas presents:)
