  New Posts New Posts RSS Feed - Synthetic oil?
Synthetic oil?
Boxin' Robin View Drop Down
Post Options Post Options   Quote Boxin' Robin Quote  Post ReplyReply Direct Link To This Post Topic: Synthetic oil?
    Posted: 07 February 2011 at 12:06pm
Any pros and cons of using synthetic oil in my high-mileage 86 GT? The engine has got just over 291,000 km on it. Running perfect and for whatever reason it's getting smoother everyday. I'm putting just under 100 km on it daily. Thanks guys.
Robin
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 12:32pm
Pro: Great oil, can only make things better.
Con:  Expensive
Post Options Post Options   Quote Boxin' Robin Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 4:51pm
What about all these comments I hear about using synthetic oil in older engines will make them leak?
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 4:56pm
It's all nonsense. Viscousity is the same for synthetics and non-synthetics (Which unto itself is a misnomer, all oils these days are at least semi-synthetic), so it wont cause any leaking unless you drop down in viscousity. As Damien said, apart from cost (A Royal Purple change costs $88 including the AC Delco oil filter, that being about the most expensive you can make it), there's literally no downside to synthetics.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 7:28pm
It's all nonsense.
Or is it?
From what I understand, "sludge" from dino oil collects around gaskets and seals (and other places). The reported problem with synthetic oil is that is washes these sludge deposits away from around these (and other) areas. Washing sludge away is not necessarily a bad thing, but it IS a bad thing if the sludge itself is helping to prevent oil from leaking from worn seals and shrunken/cracked gaskets.
It is widely reported that many people DO have problems with oil leaks when they switch over to synthetic oil on an older car, especially one with high mileage.
Having said that, I started using synthetic oil on my '86 GT (190,000 KM) when I bought it three years ago and I haven't had any serious leaks.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 7:34pm
There should still be detergents in any half decent non-synthetic as well. From everything I've learned about oils (And I've done alot of reading up on them), the difference is in molecular stability, nothing more.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 7:44pm
Sign up at Pennock's and console all the guys who've reported oil gushing out of their engines with that info.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 8:39pm
I'm operating under the advice of the chemist we had in for a week from AMS Oil. Believe me, if the guy from AMS tells you his oil isn't all too different from semi-synthetics, you take notice. Besides, people also say you couldn't go from full synthetic back to conventional, but given that my trucks both run a conventional/synthetic cocktail, I take that advice with a grain of salt too.
'Sides, I run Gretchin on synthetic. Hell, for a while I was running her on 5W20. No leaks at all.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2011 at 9:39pm
Besides, people also say you couldn't go from full synthetic back to conventional...
I've never heard that before.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 10:39am
One of the most common wives' tales out there. Once you're go to synthetic, you have to go completely. You can't mix, and your engine is supposed to 'adapt' to the higher quality oil.
I have no doubt some guys have seen their engines start puking oil once they did a change where they went to synthetic, however I suspect that's more a culmination of high mileage/poor maintenance simply culminating at the moment than anything else. Like I said, detergent-wise (The stuff that actually cleans out the gunk supposedly holding it all together) both conventional and synthetic oils have that in them.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 12:13pm
That's ridiculous, as there's nothing to back up an old wive's tale like that (which I've never heard). Synthetic "blends" (mixed synthetic and dino oil) are marketed and sold.
However, engines leaking oil when switched over to synthetic has been reported time and time again. Certainly not in every case, and probably only in a small percentage of cases, but it does happen.
Robin, don't rely on information bandied about by Tristan or myself. Google it and draw your own conclusions.
Post Options Post Options   Quote Boxin' Robin Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 12:29pm
Glad to see that my thread has generated a rather lively discussion. Thanks Patrick and Tristan. I think I will hold off on the synthetic oil for now.
But what about those advertised "high-mileage oil"? Are they really any different from the regular engine oil? I'm not sure if they cost the same or not.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 12:55pm
I know it's ridiculous, especially when you consider there's no such thing as a straight conventional any more. Every oil is chemically altered to some degree, making them all semi-synthetic at the minimum. Which, like I said, flies in the face of the theory that synthetic will suddenly clean so much better.
Kinda strikes me of the whole 'Toyota Gas Pedal' thing: I've just learned to ignore people's reports when it borders on mythical levels of explanations sans scientific study to back it up.
As for the high mileage oil, it's about the same cost as normal oil. It's treated to stay thicker under more conditions (So a 10W-30 would try and stay at 30 weight under more temperatures), and is also higher in zinc content (Which is supposed to aid in valvetrain longevity). I haven't heard any complaints about it yet, but I also can't verify if it works.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 3:02pm
Robin, you've brought up an excellent point. "High-mileage oil" has additives in it, which among other things, helps to swell shrunken/worn gaskets and seals.
The synthetic oil that I've used in my '86 GT is high-mileage synthetic oil!
So perhaps that's why my relatively high-mileage engine hasn't had much of a problem with oil leaks.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 3:05pm
As for the high mileage oil... It's treated to stay thicker under more conditions (So a 10W-30 would try and stay at 30 weight under more temperatures), and is also higher in zinc content...
Gotta link for any of that?
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 5:11pm
I'll see if I can find one, as I said, most of my intel comes from a AMS oil employee. Give me half a sec.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 5:20pm
This is from Castrol's website, but effectively the three main differences between High-Mileage and standard oils are:
  • A custom blend of polymers to better seal against leaks, especially under colder temperatures (The polymers added to the oils are what determine the weights, as well as their behavior).
  • A rubber reconditioner, which inflates or 'baloons' seals, hopefully getting them to re-seal better.
  • And 'metal additives' (This would be the zinc compound the AMS employee mentioned, I assume) to better coat and protect wearing items.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 7:00pm
No offence bud, but I suspect you're making incorrect assumptions.
I doubt 10W-30 high-mileage oil will "stay thicker under more conditions" than regular 10W-30 oil. It's the same weight, and therefore each oil would have the same flow characteristics at any given temperature.
And zinc is in very few (if any) engine oils anymore. It might still be in some oils formulated for diesel engines and yes, it is in some specialized and marketed oil additives. However, I highly doubt the amount of zinc added to high-mileage oils by Castrol or any other company is any different than what they now add (or not add as the case may be) to their regular oil.
For more info on this, have a look Here. (The situation may be even worse now than reported there as their latest "update" appears to be in 2006.)
If (and that's a big "if"), if it turns out that "high-mileage" oil has a high level of zinc in it, then all of us with flat tappets should be using it.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 7:08pm
It is the same weight, but a polymer that expands with a lower thermal energy will thicken to it's 30 weight faster than one with a high thermal requirement, which will stay at 10 weight longer.
As for the article, I find that dubious, given that AMS (which isn't the most expensive oil on the planet) was the one that told me their high mileage uses ZDDP. As for Castrol, I'm not sure what it is they have, but presumably it would be something that accomplishes the same thing, if it isn't ZDDP in reality.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2011 at 7:16pm
Robin, I bet you're sorry now you asked about any of this.
