  New Posts New Posts RSS Feed - Fiero spitting out COOLANT
InfernoFiero View Drop Down
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Topic: Fiero spitting out COOLANT
    Posted: 02 July 2011 at 2:02pm
Hello,
I was driving my Fiero two days ago, and I actually dipped into the 4 rpm (fast acceleration) and my car is the 1986 4 cyl version. It was overheating, I pulled over and when I opened the hood of the car I could see the coolant spraying out of the coolant cap. I fortunately pulled over near a mechanic shop, and with just the visual inspection the mechanic concluded that nothing was damaged with the coolant, and all the coolant leak was from the coolant cap. When I opened the hood I observed the coolant was at maximum level, but by the time the mechanic came it was below low. Anyways, I topped off with the coolant I bought from the mechanic, and it was good to go.
Now, today, I was driving on the North Shore hill, stuck in traffic, and my car strangely was overheating AGAIN. I could hear sounds from the front of the car that sounded like "WHIR WHIR WHIR", and I could instantaneously feel it was coolant related. I pulled over once again and I noticed that the coolant was dripping from the cap, and the coolant level was at maximum, and by waiting 10 mins more the coolant was gone to below minimum.
Can anyone give me a rough or even a vague idea of why this is happening? I always check my engine oil and coolant level on a regular basis, and I know no coolant pipe has broke!
I am sorry if I am burden to this forum with such silly Fiero questions!!! Thanks in ADVANCE!
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 6:49pm
Hello.
On this Forum there are no silly Fiero questions.
It sounds like your fan is not working.  Some cars have a heat switch on the motor and some fans are controlled by the computer.  I would check to make sure the electric fan actually functions then if it's ok, then find why it's not getting power.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 7:16pm
I don't know what kind of fan I have.
If my fan has the heat switch I would best check it out by
turning on my car's A/C!
"http://www.calgaryfieros.com/OSGdocs/coolant-fan.html"
But how would I check my fan performance if it is the
electric one?
Thank you!
Colby View Drop Down
Post Options Post Options   Quote Colby Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 7:58pm
I had similar issues with my 86 Duke. If I sat in traffic for too long car would get really hot before the fan turned on and sometimes the coolant would boil out of the reservoir. I bought Rodney Dickman's lower temp fan switch and thermostat and haven't had any issues since. And of course you should verify that your fan is actually coming on when you reach temps that high.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 9:02pm
Hello,
Thanks for your responses! So, I turned on the air
condition for my car for maximum heat, and my fan was
working! So I can acknowledge the fan works!
Should I get this part then
(http://rodneydickman.com/catalog/product_info.php?
cPath=21&products_id=235)? It says its for 84-86 L4 Fiero
but I have no idea what L4 means...
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 9:20pm
So you know your fan works.
I suspect the overheating is not a fan issue at all.
Do you know how to properly "burp" the Fiero's cooling system?
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 9:37pm
What you need to do is let the car idle in the driveway with the front hood open.  Watch the heat gauge as it goes up and up.  Listen for the fan coming on or keep an eye out for it.  Make note when it happens.
Make sure your air conditioning is off.  We want it to come on because the car is getting too hot not because the air conditioning is on.
The Dickman lower temp switch usually ends up masking the real problem and making your car run way too cold.  This will give you bad gas mileage and will eventually start overheating later once the real problem gets bad enough.
If your fan ends up coming on at the right time then you might just need to "burp" the coolant system.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 9:50pm
Is this a good guide on burping the coolant system
(http://www.calgaryfieros.com/OSGdocs/cooling-
system.html)Patrick? Before I do that though, I will double
check the fan by doing what Dawg suggested!
Post Options Post Options   Quote Colby Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2011 at 2:22am
Yes, I agree, it's not necessarily the way to solve a problem with your cooling system. As for the downsides, in my duke at least, the car runs at the same temperature as always and my gas mileage is the same as far as I can tell (I check every tank). Do the V6's need to run warmer or is it possible my car has always run a bit too cold?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2011 at 11:21am
On the V6 I recommend running the stock fan switch and a 180 thermostat.  Running temp on a V6 is usually a tic below the 105 mark (middle) of the gauge.  In traffic long enough mine will creep up to about 108 then the fan comes on and drops it way down quickly.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2011 at 12:19pm
Funny, on my '86 GT (automatic), after many different combinations tried, I decided on the exact opposite. I settled for Dickman's 210° on and 200° off fan switch and the factory 195° thermostat. Overheating was never a problem with this thermostat/fan switch pairing. I now have the same combination with my '84 duke and it works great.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2011 at 12:24pm
Is This a good guide on burping the coolant system, Patrick?
I usually have the nose lower than the back a bit, but yes, these directions are fine.
Quote Burping the cooling system
Here's what I do to purge air from the coolant system.
The trick is to take the thermostat out and leave it out until you are sure that all of the air is purged from the system.
Park on level ground.
  1. Remove both the radiator cap, the thermostat cap, and the thermostat.
  2. Slowly begin pouring your 50/50 mix of coolant into the thermostat opening, carefully watching the radiator opening.
  3. When coolant begins comming out the radiator opening, re-install and tighten the radiator cap, top off the coolant in the thermostat opening, re-install and tighten the thermostat cap.
  4. Start the engine for ~30 seconds then kill the engine.
  5. Remove the thermoststat cap and top the coolant off. Loosen the radiator cap and wiggle it until coolant begins to come out, retighten the cap, top off the coolant in the thermostat opening and re-install the thermostat cap.
  6. Repeat steps 4 & 5 until you are satisfied that all of the air is out of the system. You might want to make a short run to the beer store with the thermostat out, LET THE ENGINE COOL, then repeat steps 4 & 5 again.
  7. Re-install the thermostat.
NOTE: Fiero owners should bleed the coolant system anytime the coolant reservoir runs dry. i.e. system has sucked air into the radiator.
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2011 at 4:31pm
I have the same problem with my 87/stock 2.8.could be a Vaccume leek or water pump isnt moveing coolant quickly vary fast,if i rev it up a bit,over 2000 it cools off real quick.the Eng temp moves to fast,up an down,poor flow,over volume.so i found this an thinking of giving it a try.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2011 at 12:53am
Your water pump is buggered my friend.  Loosen your alternator belt and try and wiggle the pump pulley.  If it moves at all, it needs to be replaced.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 7:31pm
Does a 1984 Fiero have a thermostat? I can't find it, and
it seems to me that online part store sells thermostats for
Fiero from 1985 and above.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 7:42pm
Does a 1984 Fiero have a thermostat? I can't find it...
If you can't find it, it probably doesn't have one installed.
It's (supposed to be) in the same place as with every '84-'88 Fiero... under the coolant fill cap on the engine.
For anyone who's interested, the part number for a Stant SuperStat® 195°F thermostat for a Fiero is 45819
The current price at Lordco is $13.99 (with our club discount).
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 7:54pm
Patrick, could my Fiero be spitting out coolant because I
don't have this part?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 7:56pm
Patrick, could my Fiero be spitting out coolant because I don't have this part?
I suspect it's the other way around. Someone probably removed the thermostat because it was spitting out coolant (overheating). However, that's not the solution.
Did you ever "burp" the system as we advised?
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 7:58pm
No, I haven't. I was about do it right now, until I
realized I didn't have a thermostat. Can I go on with the
procedure of burping the coolant system and just ignore the
directions in regards to the thermostat etc.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 8:00pm
Sure, but don't keep driving it without a thermostat as your engine will never heat up properly (which will kill your gas mileage and it's hard on the engine).
