No Frack地 Spark.... AGAIN! |
Author | ||||||||||||||||||
![]() ![]() ![]() ![]() Posted: 02 March 2009 at 4:30pm |
The Car: 86 2m4
Whats happening: Car was running. Then stopped running. After a couple days of head bashing figured out it the pick-up coil. So I replaced the pick up coil and put the distributor back in. Now the car is slightly out of timing, but running. Then I left the right vent/grill off and a bunch of snow went in. Now the car now won't run. I've got electricity to the ignition coil, but nothing past that. And only 1 of the 4 terminals that plug into the ignition coil have power when the ignition is turned to on. When I was initially trying to figure out why it wouldn't run (3 weeks ago) I took the ignition coil into Canadian tire and they checked it and said it was good, and that ignition coils hardly EVER fail. Then I replaced the pick-up coil and it ran. The Details: - The plugs will not spark - It does not spit fuel when I initially turn the key on. - It will spit fuel when I crank the engine. - All the fuses are fine. The Questions: 1. When my pick-up coil was gone it would not spit fuel when I turned over the engine. Will it spit fuel when the engine is turned over if the module is gone? 2. If I take off the wire to the ignition coil (that goes to the distributor) and touch a electricity dummy light to the ignition coil terminal and turn the car over, should there be electricity? Because there isn't. Or would it be too small of a current for a tester light to register? 3. The ignition coil has 2 connections that plug into it. 1 white, 1 black. These both have 2 terminals each. Only the top white has power going to it. And only when the ignition is on. Is that right? 4. If I take a wire off of the terminals from the distributor cap and touch a electricity dummy light to the cap terminal, will it have electricity? 5. If your timing is out slightly or even greatly, would that cause you to not have spark? 6. Any other suggestions, apart from buying new module, cap, rotor, wires, etc. |
I wanna go fast.
Figured why not, so I bought a new ignition control module today. Still no spark.
I wanna go fast.
For anyone else struggling with a similar problem. This is a good site.
http://www.fieros.de/en/articles/ignition.html Just in case the site goes down, this is the write up. The Fiero Ignition Systemby Oliver ScholzThe following is a description of the Fiero's ignition system. It applies mainly to the V6's, but also to the 1984-1986 4 cylinder engines. The 87/88 4 cylinder engines are too different, but 87/88 L4 owners may still want to read on, since they'll see how their engine is superior to the prior years. I'll describe the basic operation, problem areas, and how to fix them. Let me warn you that this may get a little technical... Everything revolves around the crankshaft (literally). This is the base for all timing. When the crankshaft is a few degrees before Top Dead Center (TDC) on the compression stroke, you want the spark to ignite the air fuel mixture, at the precise timing as determined by the ECM. To achieve this, the timing chain connects the camshaft to the crankshaft. Now, the timing chain streches over time, resulting in a timing that can shift with engine load changes. The valve timing changes too, but a few degrees change in the valve timing are not as critical as a timing change in the ignition system. This is one area where timing gears are better: they don't stretch. 88's don't have the problem at all, since the DIS module picks up its timing directly via a pickup on the crank. There is no stretching or wear. If your t-chain is stretched, well, this is not an easy job and is best left to the professional. But let's continue. The camshaft drives the distributor shaft. This is the next area where problems can arise. If the distributor shaft gear wears out there is a bit of play between the distributor shaft gear and the corresponding gear on the camshaft. So, if the engine load changes, the timing can jump a bit (depending on the wear). This can confuse the ECM and can lead to the dreaded "my idle jumps up and down". Now, provided the shaft is rotating with the camshaft, there are 6 (or 4 on the L4) little magnetic "tangs" that rotate around the pickup coil. Each time the tangs of the magnetic pole piece pass by the tangs of the pickup coil, current is induced in the pickup coil. Now, if these tangs are bent, the timing is again incorrect. So make sure these are all in the proper position and don't stick! I've seen engines where mechanics have somehow bent those tangs that the pole piece touches the tangs while rotating... If the mechanic really used too much force, he can also get the pole piece loose, so that it can be rotated without the shaft moving! Anyway, this signal is picked up by the ignition module. That is, if the pickup coil is working correctly. I'd recommend changing the pickup coil every two years or so. If it looks rotten, it probably is. It's also cheap to replace, and since you have to remove the distributor, this is an excellent chance to reset the timing, clean everything up, clean the gunk off the shaft (there is usually quite a bit of gunked up oil on the shaft). You should also use this opportunity to remove any play in the shaft by inserting the proper washers. There was an article on rebuilding the distributor in a recent FOCOA magazine. If the contacts are bad, the coil has internal shorts, if the wires are corroded, the signal coming from the pickup coil will be weak and this can lead to a variety of hard to diagnose engine problems. In short: replace it unless it's new. It's cheap. Now to the ignition module. This is the prime suspect in Fiero ignition problems. Don't leave home without one. I'm serious. I can name a dozen people that have been stranded because this bugger suddenly quit working. Remember: The distributor (especially on the V6) is subjected to a lot of heat, and this tends to wear out electrical things quickly. Also, stay away from aftermarket modules. Granted, they are cheaper, but you get what you pay for. My aftermarket module lasted a whopping 3 months before quitting. And guess when those buggers quit? Not while you are on your driveway, that's for sure! Don't forget to apply the heat dissipative grease that comes with the module! If you do, run to your dealer and order another one, since you are going to need it. Applying that grease is vital on the Fiero's engine. Now, the module has two connectors, with 6 contacts total. One of them is 12V. If there is a bad connection on this line, you get all kinds of weird problems. Engine runs, engine stops, engine misses, etc. Once the ECM has 12V, ground and a proper signal from the pickup coil, it will drive the ignition coil. This will generate spark. These two signals are on the 2 way connector on the distributor module. Next culprit is the ignition coil. It can have shorts and opens, the procedure for checking them is simple and explained in the Helms, Haynes and Chilton manuals. If you get a new one, get one of the performance coils. The stock coil is okay, but a bit on the weak side at higher RPMs. An often overlooked point is the ignition filter. It is next to the distributor and feeds the ignition signal to the tach. If you disconnect it you won't get a tach reading, but it may cure your problems. Simple to check, simple to fix. The secondary side of the ignition coil goes to the distributor again, this time the mechanical part on top. There can be a variety of things wrong with it, ranging from cracked to worn parts. Unless it's new, get a new cap and rotor, they're inexpensive. Needless to say, your ignition wires and plugs need to be in good condition. You can measure the wires (see Helms, Haynes, etc.) and take a look at the plugs, and regap them. Again, simple and described in the manuals. Back to the part I left out. The ECM connection on the distributor module. The distributor sends a reference signal to the ECM. The ECM reads this signal ("Ref") and determines the current RPM from it (it can be verified with a Scantool and is independent from the tach reading on the instrument panel!). Below a certain RPM (as during cranking) the ECM stays out of the ignition module and lets the module do its thing. During this time the ignition module grounds the EST line. If it sees a voltage there if it doesn't expect it to, it will set a code 42. Once the RPM rises high enough, the ECM sends a signal to the module informing it that it wishes to "take over". This is done by the "bypass" signal. It switches the ignition module from internal timing to ECM-controlled timing. With ECM-controlled timing, the ECM waits for a reference pulse, delays it and then sends a signal on the "EST" line to the ignition module to fire the spark. Clear as mud? Again, if the RPM is too low, the distributor module works on its own and generates its own timing. No advance. Once the ECM takes over, it delays the signal it receives from the module and sends it back. What's the fourth input for? Well, it is a ground connection that makes sure that the ECM and the distributor module have the same, good ground. So, there are plenty of things that can go wrong with the Fiero ignition system, but the ECM is rarely one of them, and it's expensive to replace. Mechanics are afraid of electronics, so you often get the "if the engine isn't running right, replace the ECM"-attitude. If that's not it, well we don't know (but made a lot of money by replacing that ECM). Troubleshooting the Fiero ignition system can be frustrating, but most of the things I described can be done by the shadetree mechanic. You need a minimum of tools, including a timing light, and if you troubleshoot systematically, you will usually find the problem and even if you replace all the parts, it will be cheaper than what the shop will charge you for replacing the ECM... |
I wanna go fast.
If I remember correctly, on the low voltage side there are two pinks, and 2 whites. At least that's what my diagram says. In your case subsitute white for pink and black for white.
The connector at the coil is two jumpers! This is not obvious! 1 white comes in and powers up one side of the coil, then it continues out as another white wire to power up the ignition module via the distributor connector. These are obviously critical connections. No power no spark. The black is also an in/out situation, but a bit different. The black alternately switches between ground and no connection (Open or high impedance). This creates primary current flow which then transfomers to a high voltage low current spark on the secondary (Ie: to the distributor). The other black wire continues to the tach filter for the tach signal ending up at the tach signal for the ecm and rpm guage. So, in a nutshell, the 1 wire having power when the connector is disconnected is correct. With it connected, there should be at least 2 wires with power (Whites). A few more bits of info are needed to really teoubleshoot this thing. Simple first: If you connect a plug to the high tension lead from the coil do you get sparks (I.E: get rid of the distributor)? If you do, you have a cap/rotor/wires problem. Otherwise, you are on the right track. If you have a scope or voltmeter with frequency capability you can watch the black wire for 12V to 0V transitions. This will confirm the ig module and coil are doing their thing (On the primary of the coil at least). Question 1: I have no idea the answer. Question 2: I'm not sure I understand. There should be two wires between the coil and the dist. 1 has to be power and the other has to be the switched ground from the ig module. The power wire should light the tester if you connect to the coil side and turn the ig on, but the switched ground will not. Question 3: Sounds like the white is the power in your case. It should be +12 in AND out when the ig is on. Otherwise, the ig mod isn't getting a power supply, and can't work. Question 4: Don't know what you mean here. Question 5: These components are not that smart. You will get a spark regardless of you timing, unless you are so far out that the rotor is not near a cylinder tab, in which case it may fire to ground inside the dist cap. Try isolating the distributor cap, then go from there. Let us know, Chay |
Good Lord that's a brilliant idea! Thank you so much for all the help. The little details about the ignition coil connections are exactly what I've been trying to find out, because I've traced power to the coil, but wasn't sure where to go from there. Thanks again, and I'll keep you posted. |
I wanna go fast.
I did the whole, plug to test out the ignition module thing and no spark. I have since replaced the ignition coil and still no spark. So, I'm going to do this the long way.
Can someone (in point form) explain to me how electricity gets from the battery to the plug. I'm just trying to see if I have a busted wire somewhere or... something. Please correct me where I'm wrong. I know the pick up coil is good because it's new, and the ecm is telling the TBI to spit fuel. Does the power go to the ignition module/pickup coil then the ignition coil? Or the ignition coil then the ignition module/pick-up coil? |
I wanna go fast.
Ok you mentioned that snow had covered that connector near the battery because you left the vent off. I have a couple things to check First, you need I believe a 1/4 socket. Remove the mounting bolt in the middle of that connector, then pull the connector off. Now put it back on. Try to start the car. If no start, there are 2 nuts on a double lug stud below that connector, remove the nuts, pull off the wires on the studs, clean them with a wire brush and put them back on, now try to start the car. If still no start. Go into the cabin and check for a bad fuse anywhere. Even if you have to pull each fuse out one at a time, do it, make sure they are all good. Ok if they are all good, and you have checked all the plugs and wires around the battery. Now this is one hell of a long shot. Remove the coil wire, and test it to see if it is broken. If you have an ohm meter, check the wire for continuity. If you don't fine some way to get voltage to the wire, and use a test light. I would also check the fusible links around the battery. (looks like a piece of wire with a black bulge about 2 inches from the stud on connector near the battery. Hopefully you can figure it out.
There is one more way to go about this. It's kinda hillbilly, so I haven't mentioned it before now.
If you really don't have power to the coil connector (This is where it comes in btw, then it goes to the dist from there), then strip the insulation off the incoming wire from the harness or multipin firewall connector (IE, not the one that goes to the dist, the other one), and run a jumper directly from the battery + to it. It should be the white wire in your case as discused previously. This will definately heat up your ignition system. Then try to start it. If you get it to fire, the power to the coil is your problem. If not, the issue is in the power connector to the dist (Ig module), or the module etc. But you already said you have power to one pin of the coil connector so ?? If the white between the coil and the dist is not heated up, try applying the jumper from the battery + to this wire. Try to start again. This way you can isolate the coil connector white side as the issue. Another way is kinda like what the captain suggests. Remove the plug on the dist. Connect one leg of an ohmmeter to the white wire's pin. Then remove the multi pin connectore at the firewall. Figure out which pin is supposed to feed the white wire. It's on some schematics. Put the other lead of the ohmmeter there. If you get a low reading, then the wiring from the multi pin connector all the way to the distrubutor is ok. Man I wish I were there. I think we'd have you running in .5 hours.
Chay |
Alright Fiero Wizards. I have 12 days before I move and I WILL NOT leave this man behind. So I need to get this running in that time.
Ok, so I took some time today to do some electricity checks. These are the results. ** Just so everyone knows what I'm talking about I took some pictures. Also because of where the volt meter was sitting and where I was standing 1k was the normal resting location. So 1k= No movement or No current. This is not to be confused with 1 which is LOTS of current. The Test Results are at the end. Volt Meter Setup +12V To... Setup Ground To... Setup Ignition Coil Terminal Ignition Coil Plugs 4 Pin Module Plug 2 Pin Module Plug Test Results I noticed on my Ground To../Module Plugs/Key On Test that the left pin of the 2pin Module plug had a loose wire and would read 100 or 0 depending on how I wiggled it. But having someone turn over the car while I wiggled it, still did not create a current from the Ignition Coil Terminal. The Ignition Coil Terminal has a constant 25 current when the key is on, and doesn't change when the engine is turned over. I also checked all 5 of the leads or wires by attached a 12V current in one end and using volt meter on the other. They ranged from 10-5, though they did not carry enough current to light up the test light. *EDIT* Here are the test results in text 1. Ignition Coil Plugs/Unplugged from Coil/Key off
I wanna go fast.
There is a common failure point, with the wire that goes from the coil to the ignition module (the 2 wire one).
Pull that assy off, stuff your ohm meter down each end (one side at a time) and wiggle it all over. If you get any flutter in the reading... you have a broken wire inside the insulation. |
What I don't get, is that some of these don't have an electric current, nor are they grounded. As in Test 5 the 2nd pin in on the 4 pin plug.
Also in test 2. The top right pin has almost the same reading with power and ground. I tested my ignition coil this morning and it was dead. So I replaced it with a tested one, and still no change. So so far I've replaced the ignition coil, pick-up coil, the module 3x, cap/rotor, checked the wires, new plugs, and checked the fuses (which visually look fine). I have talked to handyron, and I think I'm just going to replace the whole engine harness as I must have one or more broken wires. The VERY odd thing about this, is that this ALL started happening at the same time. First the pick-up coil, then the ignition coil, now loose wires. The original module is still fine for all I know. |
I wanna go fast.
All I can say is that you have really confused me. I don't blame you for this, testing electrical devices must be new to you. I'm going to rag on you a bit, all constructive I hope!
Telling me about volts on the ohms scale is a bit nuts. Sorry. Select the range, and report the readings on the right range. I have no clue why you are telling me about current. Do you really mean voltage?
You didn't tell us how you tested the coil, but I bet it's fine. I've never seen one go bad. Ever. Your voltmeter has very poor ranges for working on cars. 0-10VDC is too low, and 250VDC is way too high for accurate readings. You can get by, but it's better to go to CDN tire and spend $20 for a digital with better ranges. Which range did you use for the quoted ohms readings (Where was the selector knob?)? Anyway, I'm not sure if I said this before (My bad), but I believe the plug has to be connected to the coil for the in/out connector to work. I.E. the connection is in the coil, not the plug. They work together. If you remove the connector, don't expect the outgoing white to be +12. Do this:
Connect the black lead of the voltmeter, range 0-250VDC to the battery - post.
Plug in all connectors. Strip a bit of insulation from the incoming and outgoing white wires. Now, check your voltmeter by connecting the red wire to the + battery post. Note the needle position. It should be around the 9 ohms mark (12.5 volts on the 250 V scale). This is what you will be looking for from now on. Go key on and connect the red wire of the voltmeter to one of the stripped portions. Make sure the wire is clean. Sometimes there is a buildup of oxidation. Scrape it until you see shiny metal. You should see the needle move to about 12.5 volts or so, just like at the battery +. If neither wire is showing voltage, then you feed from the fuse is bad for some reason. If one is showing voltage, but not the other, then the connector at the coil is bad. If they are both good, you have no problems with power. If you find one or both missing, connect a wire directly from the battery + post to the wire(s) missing the voltage. Retest with the voltmeter as above to ensure a good connection. Now try to start. Measuring the black connections with type of meter will tell you .....nothing. It's obvious you put in a lot of effort to take and post the pictures. I am trying to help you 'cause I see the commitment. Chay
Never tested anything in my life.
This is why I showed a picture of the volt meter. I had it on 9V Bat and was using the Green numbers at the top. Which I have NO idea what measurement they are. For future reference, should I use "250 ACV" and post the top green numbers? Are the green numbers "Ohms"? Because I'll go out and re-test everything. With those settings and measurements. OR Just tell me what setting to have it on, and what numbers you want me to use for the measurements.
I tested it just like the book showed. The original coil that I pulled gave no measurements of any kind on any of the 3 tests. The other two I have, gave readings just like my book said they should.
Unfortunately for me, this is a $20 CDN Tire volt meter. The Digital ones with better readings were $40 in CDN Tire Abbotsford.
9V Bat, as seen in Volt Meter picture.
Thanks I appreciate the help. I've been working on it every chance I get for the past 3 weeks. I'm not educated in mechanics or anything electrical. So I'm just learning as I go. Again I'm sorry for not specifying a measurement on the Volt Meter. As I really have no idea how to use one, or to read it. That's why I figured I'd just select a constant measurement "9V bat" and measure the volt, or lack thereof in an attempt to find a bad ground or broken wire. However I can't find the information anywhere that tells me if "said" wire should be ground, or +12V, or anything between. So even though I know what my wires are doing, I'm not sure if it's correct. This is why I posted my test in hopes that someone on here would know the electric schematics of a 4cyl Fiero, ignition coil plugs and module plugs. |
I wanna go fast.
"I tested it just like the book showed. The original coil that I pulled gave no measurements of any kind on any of the 3 tests. The other two I have, gave readings just like my book said they should."
Well there's a first time for everything! It's unusual to find a bad one.
For schematics, visit autozone...they have the electrical schematics there. Look at the engine wiring, 4 cyl, 84-86. The colours ar enot right as previously mentioned, but the circuit is correct. They may not mean much to you but if we are looking at the same thing I can explain it to you.
Chay |
I didn't get a chance to work on the Fiero today. However I did pick up a complete wiring harness and spare ECM. This is just in case I find multiple broken wires or try everything else.
I did check out autozone. (This link is the 4cyl section) Very informative site. It looks like if I have a broken wire from my two pin module plug (see circle on schematic) to my ignition coil, that my ignition coil will not spark. **My definition of ignition coil spark: Connecting one end of the lead wire to main ignition coil terminal and plugging in a spark plug in the other end of the wire, then grounding out the plug and turning the car over to see if it will spark.** Because other than my separated coil tests. I'm not sure how isolate the ignition coils functionality. Other than previously stated spark test. Also the lead wire terminal of the ignition coil starts to produce a constant 2V when the key is turned on and continues to stay constant at 2V when the starter is engaged. What I've gleaned thus far... So the spark is created by converting 12V into 20, 000+V via the coils. The module controls the time allowed for the coils to build up said volts. And the distributor sends out these surges of electricity to the corresponding plugs via the plug wires. Where I get fuzzy is the order this all happens. Is it the pick up coil to the module to the ignition coil to the distributor to the plugs? I'll do some more tests on Sunday or Monday and post the results. Hopefully with a proper DCV Voltmeter with a 20V setting! ![]() |
I wanna go fast.
Ok, the generation of a spark is a bit more complicated than that. This is acutally how it works (I'll leave the computer control timing portion out of it):
The black wire (White or brown above) from the coil primary is "grounded' by the ignition module. The ignition module is basically a smart switch, between the bottom side of the ignition coil and ground. Because the other side of the primary on the ignition coil is at +12, a currents begins to flow in the primary of the coil. This current ramps up in a linear fashion due to the inductance of the coil. At a certain point the ignition module opens this 'ground' connection. This means that current can no longer move through the primary. I haven't seen you post the results of the test I asked you to do. Were the two white wires +12?? Chay Now here's the tricky part. The inductance of the primary of the coil REALLY wants to keep that current flowing. It's analogous to a colum of water flowing downhill in a pipe. If you shut a volve at the end of the pipe very quickly, you will get a massive overpressure, because the water doesn't want to stop instantly. The inducance is similar, but it's due to a magnetic field. The coil is actually a small transformer. When the current cannot continue through the primary there is a rapid degredation of the magnetic field...it collapses. The magnetic field collapse induces a voltage on the secondary of the coil. Because this coil has many more windings than the primary, the voltage induced is very high (20kV etc.). Anyway, I could go on and on. There is no benefit to putting the voltmeter on the coil output (High voltage) lead. You may blow up the voltmeter, and if it does spark you will never see it. It's way to fast to pick up. |
Got the car running this afternoon.
Turns out that the black plug which runs from the ignition coil to module had multiple breaks in both wires leading to a degrading of the 12V current in one and a complete break in the other. Went to Ralph's Empire snipped off some new ignition coil plugs from the yellow 87GT w/ a getrag!, spliced them in. And the car fired up first crank. This is of course after I replaced the; module, cap, rotor, pickup coil, ignition coil, plugs, fuses, tested all my plug wires, and did VOM tests on 3/4 of my engine harness!!! Thank you all for the help. PS: CFoss the 2 white wires were not 12V+ at the plug, but were 75% the way up to the ignition coil. Thanks |
I wanna go fast.
Hmmmmmm....... ![]() BTW, you can buy both of those plugs (the coil end, and the module end) with a pigtail on them from Lordco (Pico section) brand new, then you'll probably be good to go for another 20 years. |
Good work. Glad you found the culprit!
Chay |
Yes, the good Dr. was right. Again. ![]() |
I wanna go fast.
